Quote: Originally Posted by
Bugbyte
Rather than a worm gear, have you considered a captured nut with threaded rod through it? Connect the threaded rod to the motor via a piece of silicon tubing over the motor shaft and rod. The captured nut can be attached to the vertical side of the PS one case or, if possible in the center of the back of the base.
As long as you have it track smoothly, there's no reason you wouldn't be able to use limit switches to operate the motor.
my workup works along that principal finding a motor in that case with enough torque and operating at 12v was my reason for not going that route.
treetop777
Take a look at the slide mechanism of a cd-rom drive.
for the slides yes it will work for the motor power to lift it... it is not strong enough even with an old cdrom drive...
I'm hoping actuators will be easier im getting a bit discouraged and am looking for the easierst solution at this point
