Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc. > Asus Eee PC and others: Reviews and Questions
Old 03-24-2009, 07:24 PM   #1
hexxamillion's Avatar
hexxamillion is on a distinguished road
Shutdown Controller vs. Regulator for EEEPC, which is deal?
I have seen many posts on here about regulators and shutdown controllers. It gets confusing after a while for a newbie. In order to support power to my eeepc in the car do I really need a regulator or will a unit such as this be sufficient: http://store.mp3car.com/M2_ATX_160W_..._p/pwr-015.htm
I read in another post that suggested this unit. I just want to know if this would be sufficient. I also read over the manual posted in the mp3car store. Any suggestions?
hexxamillion is offline   Reply With Quote
Old 03-24-2009, 07:52 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
The M2ATX is not the best solution for your EEE PC. The M2ATX is designed for a desktop-style motherboard that is ATX-compliant.
I suggest reading this FAQ: http://www.mp3car.com/vbulletin/advf...iew&advfaqid=6
It should help shed some light on different power supplies for vehicle use and what types of systems they are best suited for.
There are other FAQs about power supplies, as well: http://www.mp3car.com/vbulletin/advfaq.php
You want a regulator that puts out the same DC voltage as the power brick that you use to plug it into the wall at home.
Chances are there is a Carnetix model that will meet your needs quite nicely.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 03-24-2009, 08:15 PM   #3
Thanks for the reply. I will read the faq links.
Old 03-25-2009, 04:04 AM   #4
NSFW is an unknown quantity at this point
Or get a 12v-120v inverter and plug in the laptop's regular power supply.
Not the most elegant solution, but it's been working well for me for over a year.
Or see if http://epowersupply.us has something. That's what I'm doing next.
NSFW is offline   Reply With Quote
Old 03-25-2009, 07:25 AM   #5
Inverters can jack up battery charging systems.
It's not the best idea.
But an inverter is an option. Not the most efficient or elegant option, but an option nonetheless.
Old 04-04-2009, 03:05 AM   #6
alphaae's Avatar
alphaae is an unknown quantity at this point
Just a question about what you mentioned before I recently got myself a Asus H1000 and was thinking about putting an invertor and just plugging in the regular power supply. Do you care to elaborate about how an invertor can mess up your battery charging system. Thanks for the help in advance.
Do us all a favor and ram your head into a wall.
alphaae is offline   Reply With Quote
Old 04-04-2009, 07:21 AM   #7
CuzMan1 is an unknown quantity at this point
why not jus get an eeepc cigarette lighter charger? that's what i've got running mine.........
CuzMan1 is offline   Reply With Quote
Old 04-04-2009, 09:16 AM   #8
To put it quite simply:
The inverter's wave pattern is a square wave. batteries like those in laptops and cellphones and digitial cameras do not work well with the square wave that an inverter puts out.
The inverter can damage the laptop battery and/or the battery charging circuit inside the laptop.
This is a much better solution, as the auto adapter is made to accept the unregulated 12v from the car.
You could wire this directly to the battery if you wanted, and many members do just that.
Holux GPS Trouble mangus580 StreetDeck 34 11-26-2007 09:56 PM
Shutdown controller screwc149 Power Supplies 1 11-22-2006 11:38 AM
Shutdown Controller with Opus 150 ps albysure Power Supplies 3 08-20-2006 12:57 AM
Power supply, Invert and shutdown controller or DC-DC PSU? pinoybboy Newbie 2 12-05-2004 02:51 AM
High power PSU with shutdown controller lookinco Power Supplies 12 08-25-2004 01:00 AM
