Go Back   MP3Car.com > Mp3Car Technical > Laptops, Netbooks, Tablets, UMPCs, etc. > Asus Eee PC and others: Reviews and Questions
Old 04-08-2009, 09:10 AM   #1
ssm05rsx is an unknown quantity at this point
Auto powering a EEEPC
Hey guys, I have a few questions. I feel bad making a new thread where there are threads of this stuff all over the place
First off, I used to run my CarPC needs with a Acer Aspire One Netbook. Well, the motherboard blew and I just replaced it at my work with a new Asus EEEPC 1000HE and I want to get more in depth with this CAR PC stuff. But I have no idea what the hell I am doing and I don't want to screw anything up, so I'll be taking this slow.
Back when I had my Acer, I didn't have any auto power on stuff, I just always opened the glove box and just hit the power button every time I got in my car... since August, It is getting quite annoying.
I'll get some pictures of my Set-up, I have pictures on another thread but forgot to update it with the finished product.
My 2006 Acura TSX
Now the few questions I have are,
How can I power the laptop in my car?
Should I just Ebay a car charger like I did for my Acer? (BTW if anyone needs a car adapter for an Acer Aspire One, just pay shipping because I really have no use for it anymore.)
What methods can I use to have the laptop turn on when I start the car?
I saw like power-on modules, and don't know which one would be good for this little netbook so I need help. also so Wake-on-lan. Any other options?
Anything else I should look into for my CarPC?
ssm05rsx is offline   Reply With Quote
Old 04-08-2009, 01:17 PM   #2
BigBadWolf is an unknown quantity at this point
Done the research and I it makes me sad to tell you that there is no way I have found to turn the EEE on when power is applied. It does not have the feature in the BIOS.
It does support Wake-on-Lan (WOL) so what I have done is make a loopback with a switch on it that fools the EEE into thinking that there is a network connection when I press the button. This works MOST of the time but not all.
The other option is to wire into the power switch and mount it remotely. If I was better with wiring, I know there is a way I could "hit the power switch" using relays when power is applied.
I power both my Lilliput and EEE from a single cig. lighter adapter which splits off into two because even at max draw together they only pull 2.5 amps (usual is around 1.7amps) which any QUALITY adapter should be able to handle.
BigBadWolf is offline   Reply With Quote
Old 04-12-2009, 12:21 AM   #3
alphaae's Avatar
alphaae is an unknown quantity at this point
Noticed that you said you made a wol connection for your eee I have a 1000h and have been trying to figure out a way to start to of without soldering wires onton the power button can you post up some picks of you wol setup?
Do us all a favor and ram your head into a wall.
alphaae is offline   Reply With Quote
Old 04-12-2009, 09:27 AM   #4
Here's how to do it.
There is no option for WOL in the BIOS, it just seems to be on by default.
Right-click My Computer, select Properties, then Device Manager in the Hardware tab. Find your network card, right-click and click Properties. Go to the Power Management tab and tick the checkbox next to Allow this device to bring the computer out of standby. Now go to the Advanced tab, change Shutdown Wakeup to On. Then change WakeUp Capabilities to ALL.
Get an Rj45 cable and cut one end off. Connect wires 1 & 3 (usually white w/orange stripe and white w/green stripe). Plug your cable in and reboot the computer. Now force it to sleep. When you touch wires 2 & 6 (orange and green wires) your EEE should wake up. Sometimes it's just not this easy and you have to experiment a little.
What I did was use a long piece of telephone wire soldered to wires 2 & 6 and put a push-button on them.
This works 7 times out of 10 but I have yet to figure out why it sometimes refuses to wake up.
Old 04-12-2009, 09:46 AM   #5
alphaae's Avatar
Hey thanks for the help I'll try yeah through the bios on the eee I didn't find a WOL setting. I'll try messing with this when I get home hope it works. I also saw a guy who made a loop back switch like yours using relay switches he wired it to his cars ignition and had it turn on his laptop automatically when he started his car looks cool search rj45 loopback in the forums
Old 04-12-2009, 09:48 AM   #6
alphaae's Avatar
Just a thought do you think maybe the button being pressed timing wise it's not long enough for the computer to recognize a link change? Maybe a switch would work better as in you decided how long the signal is connected until you know it's on. I'm now tech specialist but it could be worth a try. For the pros out there would a switch work better then a button
Old 04-12-2009, 10:56 AM   #7
lacning74's Avatar
lacning74 is an unknown quantity at this point
when i first started, i played around with a loopback switch just like BigBadWold describes, and it did start up my 1000h after i turned on the BIOS option and the network card properties in windows, but it won't work if AC power is lost at all. so unless you plan to keep AC power to the 1000h even when shutdown, it won't work.
i gave in and learned to solder. much more reliable. check my worklog.
2007 Mini Cooper eee PC worklog
lacning74 is offline   Reply With Quote
Old 04-13-2009, 09:22 AM   #8
alphae... a button can be pressed for as long as you want it to so a switch only helps if you're too tired or lazy to hold a button down for a few seconds.
lacning... you may have solved the problem I've been having. When I was running it only on battery, the WOL was pretty reliable. Ever since wiring up a regular 12v supply for my EEE the switch has hardly worked. Therefore when the car is running there is power but when I shut the car off, it's back to battery even though it's in sleep mode. The EEE must be seeing this transition and refusing to react to the wakeup call.
I need to confirm this before I give in and hack my new EEE by soldering to the power switch.
Old 10-17-2009, 08:21 AM   #9
brianteel is an unknown quantity at this point
has this been solved?
brianteel is offline   Reply With Quote
Old 11-07-2009, 01:14 AM   #10
desidriver's Avatar
desidriver is an unknown quantity at this point
i need a car charger for my acer aspire one. Can I have it. Email me at hteashop (at) hotmail.com
thanks
desidriver is offline   Reply With Quote
Old 11-07-2009, 03:12 AM   #11
Scrambles's Avatar
Scrambles is an unknown quantity at this point
are you using Phone or Ethernet, that will make a differ
Quote:
If its not broke, try and fix it.
My First Carputer
Scrambles is offline   Reply With Quote
'05 Nissan Altima- Intel D945GCLF2D Mini-ITX in Center Console (Storage Bin Mod) hexxamillion Worklogs 177 11-19-2009 01:23 AM
Chuck's Skins lots of pics Update 7-16-07 Chuck RR Released Skins 289 03-25-2009 07:06 AM
Monitor not recognized when auto powering on. Ineffigy LCD/Display 0 02-27-2008 04:22 PM
Powering 3.5" ext HD off auto infinitiqx4 General Hardware Discussion 9 04-03-2006 09:17 AM
Powering my 12v laptop auto adapter with the 19v output of a p1900 = flames? derbis Laptops, Netbooks, Tablets, UMPCs, etc. 2 12-08-2005 04:04 PM
