Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Bluetooth Hardware
Old 06-30-2007, 06:50 PM   #16
wywywywy is on a distinguished road
The Belkin arrived a few days ago.
Sorted the problem straight away!
Since then I've not had a single problem.
wywywywy is offline   Reply With Quote
Old 08-01-2007, 04:38 AM   #17
Dwaine is on a distinguished road
I have tried to figure out this problem without much success. The blue tooth adapter works fine if the carpc gets rebooted by myself. If the carpc power supply shuts the computer down, then the adapter needs to be reinserted.
I guess I should buy another usb adapter. I like the MSI one.
2003 Black Impala
Dwaine is offline   Reply With Quote
Old 08-06-2007, 05:36 AM   #18
isamu is on a distinguished road
Having the EXACT same problem Dwaine. May have to ditch this Micro$oft Mouse dongle and go with the Belkin.
isamu is offline   Reply With Quote
Old 09-07-2007, 11:26 PM   #19
I bought the dlink bluetooth adapter. The issue has disappeared. Bluetooth is working great now.
Why do some adapters have this problem?
2003 Black Impala
Old 10-09-2007, 11:57 PM   #20
Clintebb is an unknown quantity at this point
i would try devcon again.. i had the exact same issue, dev manager shows it there fine, but widcomm drivers say its disabled, unplugging it and pluging it back in again works fine. same as when i run devcon it fixes it too. i havent tried restarting a device via devcon but writing a script to make devcon disable the device then enable the device works great. have ou tried this? another thing to note is to make the script pause until the device is disabled otherwise it won't work.
heres the script i made using autohotkey, the stuff in brackets after each line should be deleted, i just added it here to say what each line does. the pause at the end can be made smaller or not there, trial and error will tell you. also you may need to change the code for the device, i used pid_200a as it was part of the pid of my device, and didnt interfere with any other devices. there is info around here for hwo to use devcon.. if you are like me just type devcon /? and work it out from there. i think i used something like devcon find *usb* and that listed all usb devices, and from there looked for something in their codes that was unique to the bluetooth adapter, the * on either side indicated "(any number of any characters)pid_200a(any number of any characters)
runwait devcon disable *pid_200a* (disables bluetooth adapter)
runwait devcon enable *pid_200a* (enables bluetooth adapter)
sleep, 10000 (pause for 10 seconds to give time for bluetooth software to load and enable the adapter before starting xport)
run c:\xport3\xport.exe
anyways if u need any more help just ask.
www.opticalnote.com
Clintebb is offline   Reply With Quote
Old 07-30-2008, 06:19 AM   #21
I just bought another bluetooth adapter. The d-link bluetooth adapter fixed all my problems.
Dwaine
2003 Black Impala
FAQ: How do I power my DC-DC PSU on my workbench? DarquePervert The FAQ Emporium 54 08-04-2009 10:11 PM
Finalizing Power Supply Options Nstyle Power Supplies 2 04-01-2007 04:40 PM
****Celica Carbon Fiber Car Computer Finished**** hombredelassrta Show off your project 47 09-02-2006 03:22 PM
Power Supply/OPUS Kill Switch SpaceMonkey Power Supplies 8 08-11-2006 11:58 AM
Blue Power ButtoN? Daven General Hardware Discussion 10 03-14-2005 05:45 PM
