The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Bluetooth Hardware
Thread Tools Display Modes
Old 09-29-2007, 01:10 PM   #1
-zip-'s CarPC Specs
-zip-'s Avatar
Vehicle: 2000 Protege
My Photos: (1)
Bluetooth cellphone using a carputer issues
I have been trying off and on to tie a USB bluetooth dongle into the carputer several times now. It works, I have a push button mic to talk with and my front end ties nicely.
The issue is who ever I am speaking to their voice breaks up. I have a MII 10000 and the dongle is on a shared hub that is not powered.
I was thinking of upgrading the mobo and giving the dongle a dedicated USB connection by purchasing a PCI/USB card.
My most current dongle is a MSI Star Key which is a 2.0 USB device.
My question is do you have a USB Bluetooth dongle, using your cellphone and the carputer as a wireless hands free device. If so does the person speaking cut out, if not what mobo are you using and do you have a dedicated USB port for the dongle.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Sponsored Links
Old 10-06-2007, 12:10 AM   #2
-zip-'s CarPC Specs
-zip-'s Avatar
My Photos: (1)
So, went out and purchased a dedicated PCI USB card 15 bucks at Tiger Direct. Did my research to make sure it supported High Speed USB and was native to XP - no additional drivers to install.
This matched the dongle's max speed 480Mbps. Sure enough it worked, no more cutting out. The conversations are clear on both ends. For the real test, dialed up a few automated answer lines and was recognized every time when I spoke an option.
Also called the wife for her feedback and she said I was clear as a bell but sounded a little distant like on a speaker phone. (no biggie)
The whole thing cost only 40 dollars new dongle and PCI/USB card.
I decided to post back, in case anyone else was doing a hands free install and ran into the same issue. Just need to tweak the volume a bit.
Carputer
Sound Stage
Old 04-19-2008, 01:45 PM   #3
jonessc's CarPC Specs
jonessc's Avatar
Vehicle: BMW 320D M-Sport
My Photos: (0)
I had a similar problem i have a hub in the boot and glove (running off a single 1.1 usb port) the bluetooth dongle was in the boot hub.
I simply moved the bluetooth dongle to the front usb hub, and the sound was perfect again.
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 04-23-2008, 03:01 PM   #4
My Photos: (0)
I had this same problem too! But I am getting rid of the motherboard. My jetway has 6 USB 2.0 ports (or so they say) and my bluetooth was plugged directly into the board. With it just being the only component, it was fine. When other USB devices were plugged in, it broke up. I fault the motherboard and am getting a celeron board instead. I found the jetway had a huge problem in supplying good power to the USB devices which should not be the case if everything is plugged in directly. But, at least this verifies my thoughts.
jjakes24 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
2006 Tacoma Carputer rac3pm Show off your project 8 02-01-2008 10:25 AM
Can't decide if the Carputer approach is right for my needs Ch3rryC0ke Newbie 5 05-31-2007 04:46 PM
FS: Complete Carputer & Bluetooth GPS System mort Classified Archive 7 07-18-2005 07:20 AM
carputer install: I dare you... Cat Monkey General MP3Car Discussion 42 01-27-2005 05:34 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
