Quote: Originally Posted by
mobworld
hi,
Yes I have come to the same conclusion.. keep the Parrot carkit and forget about getting the carpc to handle the phone. For now I will concentrate on getting the carkit to work with tha carpc. Mainly because I'm stuck on how to set/break headset(audio gateway) from within a VB6 /vb.net application.
But I still have one thing I'm wondering about.
I will use microphone from Parrot carkit and use speakers in car. But how to mute the carpc when a call is active ?. It's not like the carpc has a TEL mute connector like the old headunit.
Is the only way to achieve this to get som relays and build a 'black box', which will break carpc speaker connection and set carkit speaker connection, when TEL mute from carkit gets ground ?
Any inputs appriciated
Morten
I don't have that problem at all, as I am using one of the quick connect factory audio adapters that connects to the Parrot box and the factory stereo... it gives power to the Parrot, and physically disconnects the speakers from the stereo while connecting them to it's internal amplifiers while the call is being made... In my case though, I have the Mazda Bose system, so I had to get the pricey line level version since my amps are in the doors and the signal needs to stay line level during mute. Scroll down to the Bose version. (This is basically the black box you were speaking of)
http://www.quickconnectproducts.com/...t.html#QCMZO-1
My car PC is run into the back of my factory deck using a special adapter that tricks the CD changer input to become a new line level input. So basically, I have full stock radio functionality, with an extra line input for the CarPC, and auto-everything-muting to the Bose amps/speakers when the call comes through the Parrot and the call is sent to the speakers.
I am not sure of your current stereo setup, but I think there will be a solution for you out there.
-C
