Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion > Bluetooth Hardware
Old 07-13-2008, 12:26 AM   #1
prodigalsun is an unknown quantity at this point
Bluetooth install error 183
Hi, I have an nlited version of xp on my eee Pc that I'm using for first my carputer project. I have a generic bluetooth dongle that I bought awhile back that I have been trying to install but without luck. Using the cd that came with the dongle I keep on getting errors on install - error code 183. To troubleshoot, I installed the drivers on a my laptop which has full xp and everyhthing worked no problem. I had a more up to date version of bluesoleil and I got the bluetooth install to complete but it doesn't seem to be operating correctly. It will communicate with my Holux m-1000 gps but when I check to see if any gps info is being communicated - nothing (i'm using a program that came with the gps to see if it's picking up co-ordinates). Along with some other tests I did I have come to the conclusion that I don't have the proper drivers and for the drivers to install from that orginal cd I'm missing some xp dependencies that it needs. I have googled and searched here also for a solution but can't really find anything. I'm thinking if I could find out what dependencies are needed I could just install them and go from there. Has someone come across this problem before or could give me some insight?
prodigalsun is offline   Reply With Quote
Old 07-14-2008, 06:48 PM   #2
CoryF is an unknown quantity at this point
I am having the same problem with my install. Have you found out what part of XP that was deleted by Nlite to make this error occur?
Thanks, -CoryF
2001 Camaro SS #2070
CoryF is offline   Reply With Quote
Old 07-15-2008, 03:05 AM   #3
BlueSoleil Error 183
Okay I figured out the problem:
In order to install BlueSoleil in a nLited version of XP you have to make sure that you didn't delete "Modem Support." It is located here: Components-->Hardware Support-->"Modem Support" Create a new ISO with this included and BlueSoleil will install fine without any errors, or it worked for me at least.
Thanks, -CoryF
2007 Audi A4 Symphony II+ my first car PC install gorby Worklogs 0 07-08-2008 02:56 PM
Bluetooth problems their solutions Clintebb Bluetooth Hardware 9 12-26-2007 09:03 AM
18 mile (10KM) range Bluetooth device... rijndael Wireless Communications 5 07-05-2007 03:54 AM
Bluetooth Dongle Not Working correctly KingsDude Wireless Communications 6 05-17-2007 02:30 PM
CSR Bluetooth Dongle - help please Pabs PhoneControl 7 09-23-2005 02:25 AM
