Go Back   MP3Car.com > Mp3Car Technical > Boat Computers
Old 01-22-2009, 01:00 PM   #1
darth sidious lite
Fiberoptic's Avatar
Fiberoptic will become famous soon enoughFiberoptic will become famous soon enough
Using your M2-atx computer power supply in a 24 volt marine / boat installation
I have a few questions about marine 24 volt systems. I thought the answers might be beneficial to others, so I will be posting both my questions and the answers here in this thread.
  • What is the spike /peak voltage that should be expected in a 24 volt marine or boat environment?
  • According to the spec sheet, clamping will occur at 25-27 volts. What is the exact failure behavior when input voltage exceeds 25-27 volts?
  • How long can the voltage exceed 25-27 volts before clamping occurs?
  • Is there more or less heat generated when operating in 24volts mode vs. 12 volts?
  • At what input voltage will permanent damage occur to the unit?
Fiberoptic is offline   Reply With Quote
Old 01-29-2009, 03:17 PM   #2
darth sidious lite
Fiberoptic's Avatar
From the creator of the M2-atx:
Quote: Originally Posted by Andrei
M2-ATX will work at 24V, but will not work with 24V b atteries (big difference, since 24V batteries are actually 28V)
Try M2-ATX-HV, it can handle up to 32V (Actually will work up to 35V!)
Tags
24v, boat, computer, ituner, m2-atx, marine, mini-box
ATX power supply question dudah85 Power Supplies 3 10-10-2006 05:49 PM
ATX Motherboard... power supply questions msreyes General Hardware Discussion 1 05-09-2006 09:01 AM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 11:32 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
12 V input ATX 250W Computer Power Supply brondel Classified Archive 0 02-18-2003 03:04 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
