Go Back   MP3Car.com > Mp3Car Technical > Boat Computers
Old 08-24-2009, 03:37 PM   #1
DaveDog's Avatar
DaveDog is on a distinguished road
Talking Audio noise/Ground loop
Finally solved the ground loop on the boat, discovered the solution by chance.
I had to tie the outside (ground) of the RCA audio cables running to the amps to the chassis of the PC.
Things bounced around once and noise disappeared, wiggled things around and noise came back. Looked around found out cables had bounced around enough to touch the chassis.
TruckPC, BoatPC, and CarPC I need a life!
DaveDog is offline   Reply With Quote
Advertisement Sponsored links
Poor audio quality Xenarc MDT-X7000? jconfidence General Hardware Discussion 3 08-11-2008 12:53 AM
Unable to locate source of Audio Ground Loop / Noise phuz General Hardware Discussion 7 05-25-2008 12:01 PM
OEM Navigation Connectors Mr Castulucci General Hardware Discussion 14 07-22-2007 05:31 PM
I tried everything, can't get rid of this ground loop intense General Hardware Discussion 3 07-10-2005 09:58 AM
audio noise and ground loop isolator jdogg1583 Car Audio 11 07-03-2005 11:42 AM
