Go Back   MP3Car.com > Mp3Car Technical > Boat Computers
Old 05-09-2006, 12:27 AM   #1
Teknoledgi's Avatar
Teknoledgi is on a distinguished road
Moisture
I read a while back that you can get a special spray for electrical components like motherboards that protect it from salt spray and moisture.
Anyone know where you can get this stuff
Steve
Lilliput 8" Touchscreen LCD
VIA EPIA MII-12000
60GB 3.5" Hard Drive 5400
512MB DDR PC2700
DVD Drive
802.11G Internal Wireless Card - External 5db Antenna
100m USB Bluetooth Adapter
Nokia N70 Phone
GPS USB Receiver
Centrafuse 1.6
Teknoledgi is offline   Reply With Quote
Old 05-09-2006, 01:24 AM   #2
davida is on a distinguished road
Yeah, I would like to know that too if there is something like that.
David
davida is offline   Reply With Quote
Old 05-09-2006, 02:39 PM   #3
Registered User
nadir_s's Avatar
nadir_s is an unknown quantity at this point
I've read about this stuff before ...
I recommend you use "Stabilant" ...
http://www.stabilant.com/appnt42h.htm
The next step down from this product would probably ur average dielectric products that you find in automotive components.
[ 5-spd 1996 M A X i M A SE ]
nadir_s is offline   Reply With Quote
Old 05-15-2006, 09:02 PM   #4
BassBinDevil's Avatar
BassBinDevil is on a distinguished road
There's "conformal coating" that is applied to circuit boards used in industrial applications. You'd have to be careful not to get it on any connectors or sockets.
I'd try to keep the enclosure sealed if possible; use a liquid cooling system for the CPU (if necessary) so the radiator can be outside the box. If heat in the case is still a problem, cool the case by wrapping a couple of sides in stainless tubing (brazed to the case) and circulating cool seawater through it.
BassBinDevil is offline   Reply With Quote
Old 05-15-2006, 09:27 PM   #5
cdcamaro9534's Avatar
cdcamaro9534 is on a distinguished road
We use conformal coating made by 3M on breath analyzers we ship to Florida. But when u spray it on, you cant get it on the connectors because it will give you a intermittent connection. But the stuff does work as we have tested it in are environmental chamber numerious times before we got are insturmants approved by the FDLE. But it does work, and if anyone wants more info on it, let me know, ill get more info for everyone.
1995 Chevy Camaro
VIA EPIA M10000 Mini-ITX Motherboard
WD80 Hard Drive
WinTV Tuner
Iguidance GPS
Road Runner Frontend w/ Liquid Smoke's skin
Xenarc 700IDT with DVD CDR/RW
cdcamaro9534 is offline   Reply With Quote
Old 05-17-2006, 09:51 PM   #6
VeritasForge is on a distinguished road
More info would be great. I am starting to build stainless enclosures with a NEMA 4 seal for boat applications and would like to offer that spray as well.
-Gordon
VeritasForge is offline   Reply With Quote
Old 06-04-2006, 03:56 PM   #7
lifeboat's Avatar
lifeboat
I found this link while searching for something else:
http://www.marinecomp.com/seasafe.htm
This company uses conformal coating plus something called a VCI (vapor corrosion inhibitor) which is material such as foam that emits a corrosion preventative.
IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
lifeboat is offline   Reply With Quote
Old 09-25-2006, 07:45 AM   #8
1diamond is an unknown quantity at this point
I also know of a company that does coformal coating, they do really good work and are fair priced. I would go with parylene for a conformal coating but there are a number of others such as silicon, epoxy, acrylic, polyurethane. My vote is parylene, nothing can get through it. Anyone need the info let me know
1diamond is offline   Reply With Quote
Old 10-05-2006, 04:12 PM   #9
Ces///M3
I have used Lear chemical research corp's "corrosion block", results seem to be good right now but its still to early to tell. By next season I should know for sure if it was effective or not
Ces///M3 is offline   Reply With Quote
COOL carputer with AC? eduardovdr General Hardware Discussion 43 01-28-2006 07:54 PM
Dry-joints and moisture: Prevention is better than cure. JayKaye General Hardware Discussion 3 05-18-2004 02:01 PM
Condensation slboytoy General Hardware Discussion 5 02-10-2004 03:10 AM
why do ppl think this doesnt work? will2710 General Hardware Discussion 20 12-26-2000 12:23 PM
