Go Back   MP3Car.com > Mp3Car Technical > Boat Computers
Old 07-05-2006, 10:53 PM   #46
rotarypower101's Avatar
rotarypower101 is on a distinguished road
Here is a link to my ipod solution.
http://www.pwctoday.com/showthread.php?t=34829
Would love to see what hardware people come up with for viable audio components, they are fairly slim pickings from what I have found.
Haven’t updated the thread with the new hardware I am running currently, but it is functioning nicely.
I would love to see some usable concepts for a jetski’PC other than GPS which would be a very usable feature IMO, but tunes are a pretty good option when cruising, or just having a usable stereo that can be accessed when pulling up to the beach.
rotarypower101 is offline   Reply With Quote
Old 07-06-2006, 07:55 AM   #47
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
Quote: Originally Posted by Sidewalksalvage
basically the question is not "why" (it never is on this site) it is "why NOT!"
For the most part.. just don't ask about using PC speakers on your DooPuter
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 07-13-2006, 10:03 AM   #48
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
Quote: Originally Posted by zacwin
That picture is the same seadoo that I have. Here is what I was thinking of doing.
1. Relocate the gauge to the area below the handle bars (where it says gsx). That will leave me enough room to place a small screen there. Also the hood has a slight overhang to block the reflection of the sun.
2. Remove the front cargo container. This area stays dry even if the whole front end of the doo goes under water. I will build a small system using a laptop hd, slim cd-rom, small atx MB. I plan on contructing a small waterproof case that will fit in the bottom of the cargo container. There are 2 fresh air tubes that run into front of the hull. I can tap into these tubes to displace the heat from the cargo area and mount a large fan under the hood.
3. Mount a waterproof trackball beside the relocated guage.
4. Mount GPS reciever in the area between the handlebars and the hood.
5. Remove the glass from the side mirrors (those mirrors are useless) and fabricate waterproof speakers into the mirror mounts.
I am not doing this because of the "wow" factor. I really would like to have gps because I ride on some large lakes and the speed from the gps is more accurate than the speedometer. Sometimes like to listen to music while I ride.
Things that concern me:
1. Battery- I might have to upgrade the size of the battery for powering the amp,dooputer, and still have cranking amps
2. The chance of something catching fire. The cargo area backs right up to a 15 gallon gas tank
3. Running 60mph and being able to hear the speakers over the sound of the ski and the wind.
4. Amping the audio to a decent listening volume. I don't want it blarring out across the lake but I need to be able to hear it.
5. Quickly controlling the audio level and complete system shutdown for emergencies and getting pulled over by the patrol boats
6. Shock proofing the hd. I love to launch the ski off wakes and sometimes the landings are anything but predictable.
Thanks for your input!!!
Can't you just get one of these??? http://www.garmin.com/products/etrex/
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 07-29-2006, 11:04 PM   #49
BarryWoods's Avatar
BarryWoods is on a distinguished road
You could use a pocket pc. Put it in a waterproof case. http://www.otterbox.com/products/pda_cases/1900/
They make cases for a couple tablet pc's as well. You can still use the touch screen inside the case. I have one of their older cases that I took to Oman for my old iPaq. Kept the dust and crap out of it.
Failure is not an option....
It's installed by default on every version of Windows.
BarryWoods is offline   Reply With Quote
Old 07-30-2006, 12:44 AM   #50
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
strap this sucker on the back
http://froogle.google.com/froogle_ur...AA&gl=us&hl=en
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 07-31-2006, 05:15 PM   #51
Sidewalksalvage's Avatar
Sidewalksalvage is on a distinguished road
HAHAH id like to see that
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
Sidewalksalvage is offline   Reply With Quote
Old 07-31-2006, 07:00 PM   #52
sama's Avatar
sama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud ofsama has much to be proud of
I wonder if that would just make fart noises if it got really wet
///Mputer - Velocity - TomTom - Vision - Bezel - CarPC
sama is offline   Reply With Quote
Old 08-03-2006, 12:43 AM   #53
well its a marine audio component...so it shouldnt fart too much....
now it the jetski flipped...then maybe it might fart some...
Current Progress:
Brown 2010
Old 08-18-2006, 02:29 AM   #54
NiN^_^NiN's Avatar
NiN^_^NiN is on a distinguished road
Thought id give my take on this
You could use a PDA it would solve the touchscreen, space and waterproof issue (using a waterproof bag)
You could also get a MII 6000E which is a 600mhz Fanless mini-itx which i use and submerge it in a air tight container of oil or as tight as u can without the oil spilling.
A guy cools his pc totally in oil without any fans and thats a full motherboard
so a mini-itx thats ment to run without fans would be cooled enough
I use D3 frodoplayer and movies running at the same time on my MII 6000E with no problems at all so it's robust enough for the dooputer.
And you can also get a old PDA and use that as your monitor
If you use sidewindow installed on the PC it turns the PDA into a windows display so you can have frodoplayer or whatever running on the PDA screen and u can also use the PDA's touchscreen as the mouse with this software.
Thats my take on how you could make a dooputer
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
NiN^_^NiN is offline   Reply With Quote
Old 08-20-2006, 03:10 PM   #55
Killa200 is an unknown quantity at this point
if your still working with ideas for cooling, think along the lines of how the engine of the seadoo gets cooled. Its water, but no rad. Why? Who need a rad when you have a billion gallons of water cooled by the enviroment. Now the big issue here is coming up with components to survive that water.
Killa200 is offline   Reply With Quote
Old 09-20-2006, 09:30 PM   #56
senseless228 is on a distinguished road
well, make sure the cointainer with oil has a heatsink of some sort, otherwise it'd be a waste
senseless228 is offline   Reply With Quote
Old 11-11-2006, 10:33 PM   #57
FyreDaug's Avatar
FyreDaug is on a distinguished road
gadam I wish I could win the lottery
FyreDaug is offline   Reply With Quote
Old 11-11-2006, 11:33 PM   #58
pRoFiT's Avatar
pRoFiT will become famous soon enough
Okay cooling is probably the biggest issue on this build. If the pc was sealed water tight. you could buy a water cooling system from http://www.water-cooling.com/ and run the water lines outside the water tight pc. Im sure you could get heat sinks for the hard drive, processor, memory, video card, etc.
As for the oil filled pc...The one thing i remember from those is that the hard drive was not in the oil. I guess it wouldn't matter since the drive is probably air tight also. It may work. Using a small EPIA Via motherboard would probably be the best way to go.
And as for the Bike Pc. I like that idea. Small 12volt battery (from child electric jeep). cheap Laptop. Small 5 inch touch screen or smaller. Maybe headphones for sound. Rear camera Possibly those generators that connect to the wheel. Funny sh#$ though, Last month i was driving to lunch and i saw some guy on a bicycle cruising at 30MPH. He had a helmit and leater jacket on. Funny thing was he wasn't peddling. As i passed him i saw he had a gas engine on the back of it.
Anyways, good luck with the Dooputer. Im working on a floatputer
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline   Reply With Quote
Old 11-12-2006, 08:54 AM   #59
fwaggle is an unknown quantity at this point
Quote: Originally Posted by metwono View Post
that doesn't seem very smart to me - hard drives have tiny vents on them and they need access to that air. that was one of the problems with dunking our mobos in transformer oil for cooling purposes. it'd been suggested to simply cover those vents, but common consensus was they were there for a reason.
the rest of it, sure, great idea. but i'd have used compact flash for storage. :/
fwaggle is offline   Reply With Quote
Old 11-13-2006, 09:35 PM   #60
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
If you have been arround long enough... you would have seen an overclocker using mineral oil and submerging the entire PC in it.... worked just fine.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
