Go Back   MP3Car.com > Mp3Car Technical > Boat Computers
Old 11-07-2006, 08:02 PM   #1
Ceasar_Choppy is an unknown quantity at this point
Low power computer for the boat
Thought I'd revive the Boat forum with a question or two.
I'd like to build and install a mini-ITX based computer with a 10 or 12" touch screen on the boat. Unlike a car, however, I don't necessarily have the space issues, but I would have the environmental issues.
Comp would mostly be for navigation, (chartplotting and AIS monitoring) and some system monitoring software while underway. I'd also like to run DVDs etc., wouldn't do that very often underway.
My biggest concern is amp draw @ 12v. From what I can piece together after reading through here and other sites is that I'm looking at a 2.5A - 3A draw with the itx and touch screen. With this type of draw, is really worth going this route or should I just get a laptop with a DC-DC power supply and if I want the touch screen, add that to the laptop?
I do some racing and extensive cruising so draw on the batteries without having to charge the batteries every hour is a concern for me. I've got other systems that are already drawing an average of 5 amps which allow me to run for about 24 hours before I need a recharge.
Anyone have any idea what a laptop draws normally for comparison?
Thanks!
Ceasar_Choppy is offline   Reply With Quote
Old 11-11-2006, 11:04 PM   #2
miwise's Avatar
miwise is an unknown quantity at this point
Depends on the laptop. Mine draws around 3 to 4 amps (but that's considering the 15" monitor). Some draw less, some more. Biggest variable would probably be the cpu. AMDs I believe tend to draw more current (at least they used to) than the intel line, but it's not going to be significant. I would probably say at least 2.5 amps, though, if you consider the monitor. The bottom of my laptops say 3.15 amps.
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
miwise is offline   Reply With Quote
Old 11-13-2006, 10:46 PM   #3
Thanks miwise. Hmmm. It is tough to get any info like this for laptops, but I guess I can start based on the CPU.
When you say the bottom of your laptop says 3.15A, what are you referring to?
Old 03-02-2007, 07:38 AM   #4
terryking's Avatar
terryking is an unknown quantity at this point
Hi Choppy, The continuous power issue is one I am looking at too, in sailing cruising. Do you have any onboard wind or solar power?? You need to actually measure the current drawn by your laptop or ITX. A decent digital multimeter will measure up to 5 to 10 amps (My Elenco does 10). Then you can see what happens as the system slows down / powers down the hard drive etc... Right now I'm looking for info like that on some VIA Mini-ITX boards...
Regards, Terry King ...On The Mediterranean in Carthage
****FOUND this: Take a look at:
http://www.epiacenter.com/powersim/p...mulator_v2.htm
for a 'spreadsheet-like' calculator for the VIA boards...
terryking is offline   Reply With Quote
Old 03-20-2007, 01:08 PM   #5
jbors's Avatar
jbors is on a distinguished road
Why not to use PDA like AXIM x51v for instance ? It has 640x480 video output and you can use its touchscreen to control things.
Will not be able to use DVD though
Car pc integration with ease
Car mediacenter
jbors is offline   Reply With Quote
Old 03-30-2007, 01:56 PM   #6
Evergreen is an unknown quantity at this point
What I am finding with my installation is the CPU is only a portion of the power equiation. The more you are hoping to use this computer for the more power it will take. Do you want to watch the occasional DVD, play MP3's, connect to a SSB for email, Satphone, WIFI, cordless keyboard, MUX, AIS, the list goes on. With and AMD Geode 1750 mini-itx board, 120gb laptop drive and 1gb sitck of ram I draw about 3.9 amps. Some of that might come from USB attachments, I am looking into how to power them down with out unplugging them as some will not be needed offshore.
Evergreen is offline   Reply With Quote
Old 09-04-2007, 10:50 PM   #7
Extide is an unknown quantity at this point
I just booted up my carpc with my multi meter watching the current -- 2.5A-2.9A while booting up and ~1.6A-1.7A idle/playing music/FMRadio
Its an Intel Pentium M 1.5Ghz
i915Chipset Mobo
1Gb DDR2
60GB 5400RPM laptop HD
I am also running lower than stock voltage on the cpu (~0.86v as opposed to 1.35v)
Not Bad
Car: 2004 GTI VR6 24v Turbo 2.8L, GT35R, 630cc, Unitronic, Bosch 044, etc, etc..
Main PC: Q9550@4Ghz, 8GB DDR2, Asus P5Q-E, Win 7 x64 RTM, Scythe Mugen2, 128GB G.Skill Falcon, 2x ATI4850 512MB Crossfire, Auzentech X-Fi Forte, Grado Labs SR-80
Extide is offline   Reply With Quote
The "Official" low profile card post lakorai General Hardware Discussion 8 05-22-2005 09:49 PM
Options for Newbies for powering CarPC... RoyN Power Supplies 4 04-23-2005 05:00 PM
Inverter low power alarm vadik29 Power Supplies 12 03-07-2005 08:01 PM
low power, always on system.. HELP!! turbocad6 General Hardware Discussion 0 01-25-2005 02:00 PM
portawattz 140 wont power up my computer.... TimW General Hardware Discussion 14 04-10-2000 09:14 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
