The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Boat Computers
Thread Tools Display Modes
Old 03-28-2007, 11:00 AM   #16
My Photos: (0)
I live aboard and have been for 2.5 years. I have had servers, 4 mac minis, 3 laptops, and a bunch of odds and ends. Nothing like this has ever happened to me.
I think you got a bad machine dude!!!!
BTW using a mac mini with a touch screen and GPSNAVX is amazing!!!!!!!I use AMP as m front end and use gpsnavx for navigation. Pump the output to google earth for geoblogging,
talk2dug is offline   Reply With Quote
Sponsored Links
Old 03-30-2007, 12:02 PM   #17
My Photos: (0)
I second talk2Dug. I also live aboard full time, have 2 laptops and 2 desktop. The oldest is around 4 years old and is a standard micro-atx with standard desktop parts (except for an industrial 12v power supply). So far no issues related to moisture. I do keep these machines in the cabin but am working on a touch screen in the cockpit for charting with a mini-itx AMD Geode based pc below.
Oh, let me add. We took the 4 year old computer offshore via Bermuda to the Caribbean. So I could say we were not inland with it. I also know a few offshore sailors who swear by pc's aboard.
Evergreen is offline   Reply With Quote
Old 04-25-2007, 05:57 PM   #18
Registered User
Vehicle: 2000 Ford Mustang
My Photos: (0)
perhaps it was the "ultrasonic tank" that caused the damage to the cpu
StangBoyCIC is offline   Reply With Quote
Old 04-25-2007, 06:20 PM   #19
shotgunefx's Avatar
Vehicle: 2002 Chrysler Sebring Coupe LXI
My Photos: (30)
Don't know if it's worth it for a shot at preventitive maintenence, but I've read posts (for instance) where people used boeshield T-9 to save laptops dropped in the bilge, etc, wonder if it would help as a preventitive measure.
shotgunefx is offline   Reply With Quote
Old 04-27-2007, 02:55 PM   #20
My Photos: (0)
I repair CF-72 toughbook based nautical GPS units for a living. I've never seen corrosion inside a pc that *was not* caused from actual immersion.
24/7/365.25
I fault the pc.
CapnBoost is offline   Reply With Quote
Sponsored Links
Old 04-27-2007, 04:01 PM   #21
FLAC is for flacid
parksgm's CarPC Specs
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
Sounds like the most likely culprit, given the scenario.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 10-02-2007, 03:42 PM   #22
My Photos: (0)
bermuda to caribbean?
can I please be your deckhand?
i'm in cape canaveral so next time you fuel up that bad boy I can jump aboard
Snortonnorton is offline   Reply With Quote
Old 10-02-2007, 05:12 PM   #23
My Photos: (0)
Quote: Originally Posted by Blauvster View Post
If the pins crumbled off the CPU it's an Intel or AMD problem Sony doesn't make the CPU.
Intel's problem.......Sony only use Intel CPUs........then again it can be expected....Intel are crap!
The computer guy immersed the laptop in an ultrasonic tank?? wtf.....bit overkill!
All he had to do was remove the heatsink and fan and get vacuuming!
BiG K is offline   Reply With Quote
Old 10-18-2007, 12:12 AM   #24
vxcarpc's Avatar
Vehicle: 2002 LS1 Holden VXII Commodore Wagon
My Photos: (0)
Maybe you need to build a completely sealed, water cooled pc for your boat so that no sea air can get near the components..
CAR INFO HERE
"He who dies with the most toys, wins".
vxcarpc is offline   Reply With Quote
Old 10-20-2007, 12:02 PM   #25
Striker37's CarPC Specs
Striker37's Avatar
Vehicle: 1968 Striker 37 SportFish
My Photos: (0)
If you got fuzz on your circuit board,it wasnt because of the salt air or the dew.its was caused by faulty solder that sony used.for any kind of surface mount technology low alpha lead solder HAS to be used.this lead is in high demand as theres not much of it left on the market so big companies shortcut thier solder at YOUR expense.if you dont know what low alpha lead is.its lead that was mined before 1940.in the year 2001 1 lb of this low alpha lead was worth $180.00 a pound.today it is more scarce so its worth alot more.IBM bought 5 tons of this lead in 2002.if you buy a IBM laptop you can bet you wont see any fuzz anywhere on the board.Im in the shipwreck treasure biz.i find this low alpha lead in 30 pound ingots all the time and i sell it for high prices.
Millions of dollars of Spanish treasure await those who would dare brave the eye of the hurricane.
Striker37 is offline   Reply With Quote
Old 04-10-2008, 05:10 PM   #26
My Photos: (0)
Yikes.
Old thread and all, but somehow I stumbled onto it.
Electronic computer components should never be immersed in an ultrasonic tank. Thats an extremely harsh cleaning process that will rip the tiny leads right off of a motherboard. Some of them even get hot enough to melt the coating off the pcb, which is what happened here.
Corrosion cannot damage a motherboard's leads. Motherboards are made of silicon with a non conductive semi organic (well back in the day, Ive no clue what they use now) outer coating that's protected from corrosion.
Corrosion can damage the capacitors, but it's impossible that is what happened.
The machine was also turning on initially - If the leads and CPU pins were damaged by corrosion, you wouldn't have even made it up to the windows splash screen.
No, what happened was either a random software deal or a tiny bit of salt water got inside. Best way to clean it is with a strong dispersed spray of water to rid any potential salt, let it dry in the open for a day minimum and then apply WD-40 or Stabilant 2 to displace the rest of the water.
Sorry, old thread, but I couldn't help responding!
MargeJ is offline   Reply With Quote
Old 05-28-2008, 03:01 PM   #27
Talon's Avatar
Vehicle: 2001 Lotus Esprit V8 / 2001 Lincoln LS
My Photos: (0)
I'll resurrect the thread again. I have several computers that spend their entire lives aboard my boat (41 ft Rinker) and I have never had any problems with them. Two of them are tied into the NMEA network so I can share the nav / video / radar etc. among any of the displays. I can't understand how a laptop could corrode that quickly...
www.carolinacarclubs.com
Talon is offline   Reply With Quote
Old 05-28-2008, 10:23 PM   #28
quantum's Avatar
My Photos: (4)
Add me to the floating PC club. I'll be putting a PC in my 19ft bowrider his summer for sure. Always freshwater, so salt won't be an issue.
It won't need to be a quad-core or anything like that, just something simple for GPS, tunes, weather, etc. Will probably use the same type I put in the last Caddy (see worklog in below). The boat PC will also be removable so I can take it out if I want, and a few other considerations I have thought out are already in the works, stay tuned...
I'll be doing this as soon as I put the carPC in the new Caddy, which is also a summer project. Tandem PC installs, I LOVE it! Glad I bought 3 of everything.
Current Project ('02 Cadillac)
http://www.mp3car.com/vbulletin/fabr...xson-pics.html
First PC Install (Car sold 06/08)
Summer '07 : Caddy-puter 2.0 with smaller, better and way more cooler stuff!
quantum is offline   Reply With Quote
Old 06-05-2008, 10:24 AM   #29
My Photos: (0)
new Install on a BOAT....
I posted this to the Newbie Forum, but maybe you guys are a better source..
Mac mini install on a BOAT
Hello all.......
We live on our 37' sailboat ("Duet", thus the aboard-duet handle) in the harbor here at Avalon, Catalina Island off Southern CA. I have joined the Mac community after going thru 3 PCs. Here is the set"
- Intel mini 1.83 Core2Duo/Bluetooth keyboard & Mouse/Leopard
- 37" Visio HDTV Display
- P-1900 Carnetix Power Supply
- KVH C-3 DirecTV Mobile antenna & Receiver
- XM Radio
- 4 group-27 Deep-cycle 12v Batteries w/110W solar panel
- Honda 3Kv generator
- 1000W Inverter/50A battery charger
As you can see, the boat is more than just a vehicle, we live on her 24/7/365. All the above are on board now, but not married together. I just joined this forum today, but I anticipate asking you all for some answers to some questions that are unique to a 'marine' installation.
Anyway, hello to all.
Dave
Please post here or my email : avalonduet@yahoo.com Thanks
Dave
aboardduet is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Is my PC not getting enough power? vairu General Hardware Discussion 22 09-08-2007 10:40 PM
New to Car PC, here is my setup. BarinaHum Newbie 6 11-06-2006 08:16 PM
using in dash dvd player and tft with pc? tdali General MP3Car Discussion 5 10-12-2006 10:15 PM
For Sale for all you aussies. Complete mp3 car pc Holden__V8 Classified Archive 20 04-09-2005 05:30 AM
Security idea - hide the HU jaeger General MP3Car Discussion 17 08-23-2004 12:17 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
