Quote: Originally Posted by Bugbyte
Yeah, use the .ini editor. I originally edited the file directly but later found the editor. It works really well and makes it very easy.
Josh, I like that layout. It will remove the "chain" of events from the edit process. Hopefully, one can add and edit from the view in that window. (I wanted to change the wording of a command the other day and had to delete and re-add it to do so).
Check to make sure it's 7" screen compatible. Those little + deals can sometimes be a bear to click on with a touch screen!
Thankyou, and yes it will get rid of the chain of events, and a lot of unnecessary code.
Yea, i'll make the +'s bigger, and hopefully that can be a user selectable setting.
An edit command would be pretty complicated. Like you said, I would have to have the code save the all the child commands and all of the values, and then create a new command with the changed name. It will be added, but for now if you want to change the name of something I suggest editing it manually.
I plan to do something similiar for the "what can i say" box. It will either be a tree, or a list, I can't decide.
