06-08-2005, 01:11 PM
#31
Quote: Originally Posted by FunkDaMonkMan
Look at the Help.htm file that came with the program, and experiment. If you sill have a specific question, then you can start a new thread in this forum or ask here.
excellent,
Thats all I needed to know that it was in the manual/Help !
06-08-2005, 05:42 PM
#32
Quote: Originally Posted by LordSnow
By duration do you mean a delay? That would be most useful for these types of macros.
Sounds good. Keep up the good work!
No, delay can be programmed by the [pause]100 command. Duration will be how long the button is held down. You would probably put down 0 for just a standard click.
I'm not sure if duration would be useful though...
Bruno Speech Recognition - Advanced Speech Recognition designed to control any program. Extra support for FrodoPlayer and Winamp.
06-11-2005, 12:58 AM
#33
Quote: Originally Posted by Nighcrawler
Hey funky man
I've installed BSR 1.31 but when I start it. i get the error:
ERROR!:429
after that. BSR starts with a very tiny screen. and no other options than minimise,questionmark and close.
I can't maximise or enlarge the window..
any idea whats happening?
I am getting the same error, i did install the speech sdk 5.1, but no luck, is there something else that I have to do after install speech sdk5.1?
06-11-2005, 10:20 AM
#34
try un-installing, and re-installing to the default directory.
06-12-2005, 12:36 AM
#35
reinstall Bruno Speech Recognition or the sdk? i did both, still same problem
06-12-2005, 01:40 AM
#36
hm.. are you installing to C:\program files\bruno speech recognition ?
What OS are you using?
Where did you get the SAPI?
06-12-2005, 01:35 PM
#37
yes, i am using xp, and i got the sapi from your help file where it say click here in the requirement section
06-14-2005, 08:42 AM
#38
Hi good program
But Just wanted to konw a few add on possibilities..
1........If i use the command to start Frodo Player -- it sure does. Now my FP is configured to start with MENU screen ON always.. Here on the Menu screen if i give command Radio it works since u have provided a few FP commands. How about if i wanted to start MEDIA or CAMERA from the MENU screen... how do i configure this
2...... If i want to use the Voice recognition for Calculator mode to type in number while i say how do i configure this part...
ex----- ( 152 X 25 = )
Commell LV-677 DC 6 x 6" Mother Board
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
7" InDash Xenarc MTD - X7000 Screen
Gyration Mouse ; GPS Mouse ; ELM Scan ; TPMS
Parrot MK 6000 & iPhone
Re done the carputer...Into the Glove Box !!
06-14-2005, 08:45 AM
#39
HI ok this is funny.. I use the command to start a program.. it does it a few times and then i see THE SPEECH RECOGNITION has stopped all to gether till the time I toggle DISABLE / ENABE voice commands..and it starts functioning ok again for a few times..
also it keeps attempting to recognise FALSE commands and gives outputs of what shes trying to hear.. Like Enable 1 ; Enable 2; Enable 3; PAUSE PAUSE
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
06-14-2005, 09:10 AM
#40
Ok Heres is some kind of Bug .. Maybe not sure..
If i play FP and give a command for NEXT MODE or play .. it some how starts SAYING PAUSE and kepps douing it till the time i exit the SPEECH SOFTWARE.. and if i re start and come to the same point it agan gets stuck on the PAUSE command for ever.. till i exit every thing
why is this so
any help
2.6 GHz; 1 Gb Ram
120 Gb Laptop HD
06-15-2005, 04:47 PM
#41
anything else I should do?
06-15-2005, 09:33 PM
#42
vicky: You should disable master commands in the program settings. That will solve a couple of your problems. As for the computer recognizing itself, I will have to look into that.
Woeful: I'm not sure what your problem is. As soon as I get time I will take a look at the code and see if I can figure it out.
As for v1.4... I've been extremely busy lately... Sorry guys. I'll get back on this project as soon as I can.
06-23-2005, 11:48 PM
#43
Hey guys, when ever I run a full screen visulization, the voice commands seem to be disabled. when the visulization is windowed, everything works great. Anyone else having this problem? Try it and let me know.
Tanks
Pac3R
06-24-2005, 12:01 PM
#44
Is it just the winamp commands that are disabled, or all the commands?
06-24-2005, 10:32 PM
#45
Has trouble reading.
i am trying to use bsr 1.3.1 for the first time and when installing i get that error mentioned earlier "2147200966". Already tried un/re/installing and doing it all over again a few times.
do i have to have something else installed that i am missing?
How do i find out if i have SAPI installed and exactly which version?
| Thread Tools |
| Display Modes |
Linear Mode
