The MP3car.com Store
Go Back   MP3Car.com > Project Tracker Directory > StreetDeck Bug Reports Bug Tracker
Properties
This is a Major Unknown / General Bug for 1.1.1.0 of StreetDeck Bug Reports
Assigned Cannot Reproduce to Unassigned
hawk909
12-25-2007 11:29 PM
What version of StreetDeck is this bug report for?
1.0.6.3 and up
Please give a basic description of the issue here.
Crashes/ Gets Error about contacting StreetDeck website for help
Streetdeck Bug Reporting Process
Is the systemt that is listed in your CarPC specs under your user name the same system where you encountered this bug?
Yes
If no, please describe your system here.
Are you able to reproduce this bug at will?
Yes
Please list the steps required to recreate the issue you are reporting
Have tried upgradeing every few times SD comes out with a new upgrade same result with all.
Please provide any relevent information regarding the issue you have encountered.
Just noticed that when I load 1.0.6.3 default skin most if not all of the arrow,general, help buttons did not load but stay greyed out. They loaded normally in my custom skin though.
hawk909
12-25-2007 11:32 PM
hawk909
12-25-2007 11:34 PM
Couldn't figure out how to get the log file to attach so doing a copy paste. Sorry
INFO: ************************************************** ******************************
INFO: StreetDeck Application Data Log
INFO: Log started: Tuesday, December 25, 10:07 PM
INFO: Log set to VERBOSE mode
INFO: Application Version: 1.1.1.0
INFO: Command Line: -verbose -info
INFO: Program Path: (C:\Program Files\StreetDeck)
INFO: Application Data Path: (C:\Documents and Settings\Administrator\My Documents\StreetDeck)
INFO: Music Path: (D:\MP3)
INFO: Unindexed Music Path: (D:\MP3 Audio Files)
INFO: Videos Path: (C:\Documents and Settings\Administrator\My Documents\My Videos)
INFO: Pictures Path: (C:\Documents and Settings\Administrator\My Documents\My Pictures)
INFO: CAppData::OnPreCreate - Finished
INFO: CNAVController::CreateHostWindow - Creating mappoint host window.
INFO: CMappointCtrl::GetClsid - Using mappoint control id
INFO: CNAVController::CreateHostWindow - GetCtrlSite.
INFO: CNAVController::CreateHostWindow - PaneState.
INFO: CNAVController::CreateHostWindow - EnableBusyDialog.
INFO:
OnPreCreate - Initialization time 0.040 / 0.040 seconds.
WARNING: UV_GetUpdateList - The system cannot find the path specified. (ERROR=0x00000003)
INFO: CDrawWnd::Create - DirectX object successfully created!
INFO:
Direct3DCreate9 - Initialization time 0.020 / 0.060 seconds.
INFO:
PreEnumerate - Initialization time 0.000 / 0.060 seconds.
INFO:
Enumerate - Initialization time 0.010 / 0.070 seconds.
INFO:
BrushCreate - Initialization time 0.000 / 0.070 seconds.
INFO:
RenderWindow PreCreate - Initialization time 0.000 / 0.070 seconds.
INFO:
RenderWindow Create - Initialization time 0.010 / 0.080 seconds.
INFO:
Init Loading Logo - Initialization time 0.000 / 0.080 seconds.
INFO: CDrawWnd::Create - Main render window successfully created!
INFO: CDrawWnd::Create - Creating main application...
INFO: CUVAppData::OnCreate - Navigation controller successfully initialized!
INFO:
Window / Direct3D Create - Initialization time 0.010 / 0.090 seconds.
INFO: CAuthorize::ReadIdeDriveAsScsiDriveInNT - Found Drive Serial Number! (serial: NS22T5C29FFB, controller: 0, drive: 0
WARNING: CAuthorize::ReadPhysicalDriveInNTWithZeroRights - DeviceIOControl IOCTL_STORAGE_GET_MEDIA_SERIAL_NUMBER error = The request is not valid for this device.
WARNING: CAuthorize::ReadPhysicalDriveInNTWithZeroRights - DeviceIOControl IOCTL_STORAGE_GET_MEDIA_SERIAL_NUMBER error = The request is not supported for this device.
INFO: CAuthorize::ValidateRegistrationInfo - Validating Registration codes (AFYYGBPY, FSSOYYMK)
INFO:
LoadRegInfo - Initialization time 0.020 / 0.110 seconds.
WARNING: UV_GetFileList - The system cannot find the file specified. (ERROR=0x00000002)
INFO:
Init Plugins - Initialization time 0.000 / 0.110 seconds.
INFO:
OneTimeDOne - Initialization time 0.040 / 0.150 seconds.
INFO:
OneTimeSceneInit - Initialization time 0.000 / 0.150 seconds.
INFO:
FindBestWindowedMode - Initialization time 0.000 / 0.150 seconds.
INFO: CDrawWnd::Initialize3DEnvironment...
INFO: CDrawWnd::Initialize3DEnvironment - Successfully created D3D device!
INFO: CRenderEngine::InitDeviceObjects...
INFO: CRenderEngine::RestoreDeviceObjects...
INFO:
RenderEngine Init - Initialization time 0.091 / 0.241 seconds.
INFO: THREAD ID:1512 = CDrawWnd::LoadingThread
INFO:
PreInitDeviceObjects - Initialization time 0.130 / 0.371 seconds.
INFO:
StatsFont - Initialization time 0.010 / 0.381 seconds.
INFO: Initializing POI database...
WARNING: CPOIDB::Initialize - Could not open POI database file (C:\Program Files\StreetDeck\Maps\Data\USA_SD.mad)!
INFO:
OnInitDeviceObjects Start - Initialization time 0.420 / 0.801 seconds.
WARNING: CInfillOverlay::OnStartup - Error opening infill device hardware (1), trying again! (Audio Open Error, FirmwareComm Open Error)
WARNING: CInfillOverlay::OnStartup - Error opening infill device hardware (2), trying again! (Audio Open Error, FirmwareComm Open Error)
WARNING: CInfillOverlay::OnStartup - Error opening infill device hardware (3), trying again! (Audio Open Error, FirmwareComm Open Error)
INFO: CInfillOverlay::InitDevice - Infill drivers not present (C:\Program Files\StreetDeck\T3devControl.dll or C:\Program Files\StreetDeck\InfillG4Cmd.dll)!
INFO: CAppData::OnInitDeviceObjects - Using skin Default
INFO:
Folder Init - Initialization time 15.573 / 16.374 seconds.
INFO: CSoundController::InitDeviceObjects...
SetFormat(hr=0x08887800INFO: Loading Textures...
INFO: CTextureBag::LoadTextures...
INFO: THREAD ID:1976 = DownloadHttpFile
INFO:
Load Textures - Initialization time 0.110 / 16.484 seconds.
INFO:
Load Logo Texture - Initialization time 0.030 / 16.514 seconds.
INFO: Initializing Textures...
INFO:
Initialize Textures - Initialization time 0.020 / 16.534 seconds.
INFO: Initializing Speech Controller...
INFO:
Init Speech - Initialization time 0.000 / 16.534 seconds.
INFO: Initializing Media Event Processor...
INFO:
Init Media Event Processor - Initialization time 0.000 / 16.534 seconds.
INFO: Initializing Volume Control Textures...
INFO:
Init POI DB - Initialization time 0.000 / 16.534 seconds.
INFO: Initializing media manager CDVDManager device objects...
INFO: Initializing media manager CiPodManager device objects...
INFO: Initializing media manager CLaunchCastManager device objects...
INFO: Initializing media manager CXMRadioManager device objects...
INFO: Initializing media manager CRadioManager device objects...
INFO: Initializing media manager CTVManager device objects...
INFO: Initializing media manager CVideoFileManager device objects...
INFO: Initializing media manager CAudioFileManager device objects...
INFO:
Init Media Managers - Initialization time 0.000 / 16.534 seconds.
INFO:
Enumerate Apps - Initialization time 0.000 / 16.534 seconds.
INFO: CAppData::LoadSkin - Loading skin Default...
INFO: CAppData::LoadSkin - Loading skin C:\Documents and Settings\Administrator\My Documents\StreetDeck\UI\Skins\Default\Skin.skn...
INFO: CAppData::LoadSkin - Loading PanelList...
INFO: CAppData::LoadSkin - Loading OverlayZOrder...
INFO: CAppData::LoadSkin - Loading Colored texture list...
INFO: CAppData::LoadSkin - Loading SystemMetrics...
WARNING: CAppData::SetSystemMetric - The specified skins system metric eSMListNAVDirectionYOffset, 700 is outside the bounds (Min:-500, Max:500) allowed by it. The default value of 0 will be used instead.
INFO: CAppData::LoadSkin - Loading SystemColors...
INFO: CAppData::LoadSkin - Loading SystemFonts...
INFO: CAppData::LoadSkin - Loading ImportedFonts...
INFO: CAppData::LoadSkin - Finished loading skin...
INFO:
Load Skin - Initialization time 0.150 / 16.684 seconds.
INFO: CAppData::OnInitDeviceObjects - Skin successfully loaded!
INFO: CFontBag::InitDeviceObjects...
INFO:
Init FontBag - Initialization time 0.070 / 16.754 seconds.
INFO: Creating CAlwaysVisibleOverlay.
INFO: Creating CNetworkCommOverlay.
INFO: Creating CRemoteMediaDestinationModule.
INFO: Creating CWebServicesOverlay.
INFO: Creating CWSUserNameRenameModule.
INFO: Creating CWSPasswordRenameModule.
INFO: Creating CWebServicesSettingsModule.
INFO: Creating CComboSelectOverlay.
INFO: Creating CMultiMonEnabledOverlay.
INFO: Creating CMediaTimeOverlay.
INFO: Creating CKeyPadNumbersOverlay.
INFO: Creating CKeyPadLettersOverlay.
INFO: Creating CKeyPadWebOverlay.
INFO: Creating CKeyPadAlwaysVisibleOverlay.
INFO: Creating CMediaPlaySpeedOverlay.
INFO:
Overlays - Initialization time 0.070 / 16.824 seconds.
INFO: Creating CUserOverlay0.
INFO: Creating CUserExtendedOverlay0.
INFO: Creating CUserOverlay1.
INFO: Creating CUserExtendedOverlay1.
INFO: Creating CUserOverlay2.
INFO: Creating CUserExtendedOverlay2.
INFO: Creating CUserOverlay3.
INFO: Creating CUserExtendedOverlay3.
INFO: Creating CUserOverlay4.
INFO: Creating CUserExtendedOverlay4.
INFO: Creating CUserOverlay5.
INFO: Creating CUserExtendedOverlay5.
INFO: Creating CUserOverlay6.
INFO: Creating CUserExtendedOverlay6.
INFO: Creating CUserOverlay7.
INFO: Creating CUserExtendedOverlay7.
INFO: Creating CUserOverlay8.
INFO: Creating CUserExtendedOverlay8.
INFO: Creating CUserOverlay9.
INFO: Creating CUserExtendedOverlay9.
INFO:
User Overlays - Initialization time 0.020 / 16.844 seconds.
INFO: Creating CUserModule0.
INFO: Creating CUserModule1.
INFO: Creating CUserModule2.
INFO: Creating CUserModule3.
INFO: Creating CUserModule4.
INFO: Creating CUserModule5.
INFO: Creating CUserModule6.
INFO: Creating CUserModule7.
INFO: Creating CUserModule8.
INFO: Creating CUserModule9.
INFO:
User Modules - Initialization time 0.020 / 16.864 seconds.
INFO: Creating CSafeModulesOverlay.
INFO: Creating CVolumeOverlay.
INFO: Creating CBluetoothConnectedOverlay.
INFO: BT Create
INFO: Creating CBluetoothSettingsModule.
INFO: Creating CBluetoothSettingsModuleWizard.
INFO: Creating CBluetoothVolumeModule.
INFO: Creating CBluetoothPairedDevicesModule.
INFO: Creating CBluetoothPairingModule.
INFO: Creating CBluetoothPairedDeviceStatusModule.
INFO: Creating CBluetoothMainModule.
INFO: Creating CBluetoothOptionsModule.
INFO: Creating CBluetoothPhoneStatusModule.
INFO: Creating CBluetoothDialNumberModule.
INFO: Creating CBluetoothPhoneBookModule.
INFO: Creating CBluetoothPhoneBookEntryModule.
INFO: Creating CBluetoothEditPhoneBookEntryModule.
INFO: Creating CBluetoothImportModule.
INFO: Creating CBluetoothImportCSVModule.
INFO: Creating CBluetoothImportBluetoothModule.
INFO: Creating CListSearchOverlay.
INFO: Creating CBluetoothStartModule.
INFO: Creating CBluetoothActiveCallOverlay.
INFO: Creating CBluetoothIncomingCallOverlay.
INFO: Creating CBluetoothActiveCallModule.
INFO: Creating CBluetoothSendTonesModule.
INFO: Creating CBluetoothCallLogModule.
INFO: Creating CBluetoothVoiceRecognitionOverlay.
INFO: Creating CVolumeModule.
INFO: Creating CAppSoundsModule.
INFO: Creating CEnhancedAudioModule.
INFO: Creating CWMEqualizerModule.
INFO: Creating CBalanceFaderModule.
INFO: Creating CMuteOverlay.
INFO:
Volume Modules - Initialization time 0.191 / 17.055 seconds.
INFO: Creating CVoiceInputModule.
INFO: Creating CVoiceInputSettingsModule.
INFO:
Voice Modules - Initialization time 0.000 / 17.055 seconds.
INFO: Creating CMoveFileModule.
INFO: Creating CRenameModule.
INFO: Creating CGestureModule.
INFO: Creating CGestureSettingsModule.
INFO: Creating CGlyphSettingsModule.
INFO: CGestureModule::LoadGlyphDataHelp - loading glyph data file (C:\Documents and Settings\Administrator\My Documents\StreetDeck\Functions.gdf)...
INFO: CGestureModule::LoadGlyphDataHelp - done loading glyph data file
INFO: Creating CRelayModule.
INFO: Creating CRelaySettingsModule.
INFO: Creating CRelayPluginSettingsModule.
INFO: Creating CConfigureRelayPluginSettingsModule.
INFO: Creating CRelaySetSettingsModule.
INFO: Creating CConfigureRelaySetSettingsModule.
INFO: Creating CRelayRenameModule.
INFO: Creating CChooseRelaysSettingsModule.
INFO:
Relay Modules - Initialization time 0.100 / 17.155 seconds.
INFO: Creating CMediaChangeOverlay.
INFO: Creating FunctionText.
INFO: Creating FileOptionsOverlay.
INFO: Creating CSystemRestoreModule.
INFO: Creating MsgBox.
INFO:
MsgBox Modules - Initialization time 0.020 / 17.175 seconds.
INFO: Creating CExternalAppsModule.
INFO: CExternalAppsModule::OnCreate - No applications were found in the extenal applications shortcut directory (C:\Documents and Settings\Administrator\My Documents\StreetDeck\ShortCuts\ExternalApps).
INFO:
External Apps Modules - Initialization time 0.020 / 17.195 seconds.
INFO:
Tray Overlays - Initialization time 0.000 / 17.195 seconds.
INFO: Creating CFileSearchResultsModule.
INFO: Creating CFileSearchRenameModule.
INFO:
EQ Modules - Initialization time 0.010 / 17.205 seconds.
INFO: Creating CNetSyncSettingsModule.
INFO: Creating CNetComputerBrowserModule.
INFO: Creating CUserNameRenameModule.
INFO: Creating CPasswordRenameModule.
INFO: Creating CNetShareBrowserModule.
INFO: Creating CRipMediaSettingsModule.
INFO: Creating CRipMediaTransferModule.
INFO: Creating CRipMediaSelectTypeModule.
INFO: Creating CMediaDestinationRename.
INFO: Creating CRipMediaOverlay.
INFO: Creating CStartupSettingsModule.
INFO: Creating CStartupSettingsModuleWizard.
INFO: CStartupSettingsModule::OnNeedWizardProperties - Retrived hardware code: AFYYGBPY, Check Code: FSSOYYMK
INFO: Creating CShutdownSettingsModule.
INFO: Creating CDisplaySettingsModule.
INFO: Creating CDisplaySettingsModuleWizard.
INFO: Creating CCalibrateDisplayModule.
INFO: Creating CInputSettingsModule.
INFO: Creating CKeyboardSettingsModule.
INFO: Creating CInputOptionsSettingsModule.
INFO: Creating CGeneralSettingsModule.
INFO:
General Modules - Initialization time 0.150 / 17.355 seconds.
INFO: Creating CShortcutsModule.
INFO: Creating CSetTimeSettingsModule.
INFO: Creating CSetTimeSettingsModuleWizard.
INFO: Creating CSkinSettingsModule.
INFO: Creating CColorSettingsModule.
INFO: Creating CMultiMonSettingsModule.
INFO:
MultiMon Modules - Initialization time 0.030 / 17.385 seconds.
INFO: Creating CMainSettingsModule.
INFO: Creating CSyncSourceModule.
INFO: Creating CSimpleSettingsModule.
INFO: Creating CSystemInformationModule.
INFO: Creating CStartModule.
INFO: Creating CYahooSearchModule.
INFO: Creating CShutdownModule.
INFO: Creating CProcessShutdownModule.
INFO: Creating CHelpModule.
INFO: Creating CAboutModule.
INFO: Creating CMusicStartModule.
INFO: Creating CMusicModule.
INFO: Creating CMusicSettingsModule.
INFO: Creating CMusicSearchModule.
INFO: Creating CMusicSearchResultsModule.
INFO: Creating CMusicPlaylistModule.
INFO: Creating CMusicArtistStringColModule.
INFO: Creating CMusicAlbumStringColModule.
INFO: Creating CMusicSongStringColModule.
INFO: Creating CMusicGenreStringColModule.
INFO: Creating CMusicArtistAlbumModule.
INFO: Creating CMusicSelectFolderModule.
INFO: Creating CMusicNowPlayingModule.
INFO: Creating CMusicLoadedOverlay.
INFO: Creating CMusicPlaylistContentsModule.
INFO: Creating CMusicVMODStartModule.
INFO: Creating CVisualizationModule.
INFO: Creating CVisTitleOverlay.
INFO: Creating CVisAlbumArtOverlay.
INFO: Creating CRipMediaMusicModule.
INFO: Creating CiPodModule.
INFO: Creating the iPod module
INFO: Creating CHDRadioModule.
INFO: Creating CRadioSettingsModule.
INFO: Creating CHDRadioKeypadOverlay.
INFO: Creating CLaunchCastModule.
INFO: Creating CLCUserNameRenameModule.
INFO: Creating CLCPasswordRenameModule.
INFO: Creating CLaunchCastLoadedOverlay.
INFO: Creating CLaunchCastSettingsModule.
INFO: Creating CLaunchCastStationGuideModule.
INFO: Creating CLaunchCastFilterStationsModule.
INFO: Creating CXMRadioModule.
INFO: Creating CXMRadioChooseStationsModule.
INFO: Creating CXMRadioStatusModule.
INFO: Creating CXMRadioStationListModule.
INFO: Creating CXMRadioSettingsModule.
INFO: Creating CXMRadioSettingsModuleWizard.
INFO: Creating CGirderModule.
WARNING: CPluginBag::GetPlugin - LoadLibrary - The specified module could not be found. (ERROR=0x0000007e)
WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Documents and Settings\Administrator\My Documents\StreetDeck\Plugins\Input\InputG35SWC.dll )!
WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Documents and Settings\Administrator\My Documents\StreetDeck\Plugins\Input\InputPhidgetsEn coder.dll)!
INFO: Creating CGirderSettingsModule.
INFO: Creating CGirderPluginSettingsModule.
INFO: Creating CPicturesModule.
INFO: Creating CPictureSettingsModule.
INFO: Creating CRipMediaPicturesModule.
INFO: Creating CSlideshowModule.
INFO: Creating CSlideshowOverlay.
INFO: Creating CVideosModule.
INFO: Creating CVideoSettingsModule.
INFO: Creating CFullScreenVideoFileModule.
INFO: Creating CFullscreenVideoOverlay.
INFO: Creating CFullscreenVideoInfoOverlay.
INFO: Creating CFullscreenVideoStoppedInfoOverlay.
INFO: Creating CFullscreenVideoResumeInfoOverlay.
INFO: Creating CFullScreenDVDModule.
INFO: Creating CDVDSettingsModule.
INFO: Creating CDVDOptionsModule.
INFO: Creating CFullscreenDVDOverlay.
INFO: Creating CDVDSelectSubPictureStreamModule.
INFO: Creating CDVDInfoModule.
INFO: Creating CDVDSelectAudioStreamModule.
INFO: Creating CFullScreenTVModule.
INFO: Creating CFullscreenTVOverlay.
INFO: Creating CTVChannelChangeOverlay.
INFO: Creating CTVPropOverlay.
INFO: Creating CTVOptionsModule.
INFO: Creating CRearviewCameraModule.
INFO: Creating CRearviewCameraOverlay.
INFO: Creating CRearCameraPropOverlay.
INFO: Creating CRearviewCameraSettingsModule.
INFO: Creating CConfigureRearviewCameraSettingsModule.
INFO: Creating CVehicleModule.
INFO: Creating CVehicleSettingsModule.
INFO: Creating CRelayControlModule.
INFO: Creating COBDIISettingsModule.
INFO: Creating CVehicleGraphOBDIIModule.
INFO: Creating CDiagnosticsModule.
INFO: Creating CDiagnosticsViewCodeModule.
INFO: Creating CNAVStartModule.
INFO: Creating CNAVStatusModule.
INFO: Creating CNAVFindAddress.
INFO: Creating CNAVFindPlaceModule.
INFO: Creating CNAVDBFindPlaceModule.
INFO: Creating CNAVFindNearbyModule.
INFO: Creating CNAVPOIModule.
INFO: Creating CNAVCustomPOIModule.
INFO: Creating CNAVMapModule.
INFO: Creating CNAVFullScreenModule.
INFO: Creating CNAVFullscreenOverlay.
INFO: Creating CNAVViewFullscreenOverlay.
INFO: Creating CNAVViewDirectionOverlay.
INFO: Creating CNAVViewListOverlay.
INFO: Creating CNAVViewStatusOverlay.
INFO: Creating CNAVGPSTrackingOverlay.
INFO: Creating CNAVClickedLocationOverlay.
INFO: Creating CNAVVirtualEarthOverlay.
INFO: Creating CNAVScrollMapOverlay.
INFO: Creating CNAVMapOnlyModule.
INFO: Creating CNAVStreetSettingsModule.
INFO: Creating CNAVDirectionsModule.
INFO: Creating CNAVRouteTypeModule.
INFO: Creating CNAVFavoritesRenameModule.
INFO: Creating CNAVSettingsModule.
INFO: Creating CNAVSettingsModuleWizard.
INFO: CSpeechController::OnSettingsChange
WARNING: UV_GetFolderList - The system cannot find the path specified. (ERROR=0x00000003)
INFO: Creating CNAVFindLatLongModule.
INFO: Creating CNAVFindResultsModule.
INFO: Creating CRipMediaPOIModule.
INFO: Creating CNAVShowRouteModule.
INFO: Creating CNAVFindPlacesListModule.
INFO: Creating CNAVCurrentDirectionOverlay.
INFO: Creating CRipMediaVideosModule.
INFO: Creating CUpdateListModule.
INFO: Creating CPackageListModule.
INFO: Creating CAddPackageModule.
INFO:
Package Modules - Initialization time 0.801 / 18.186 seconds.
INFO: Creating CScriptListModule.
INFO: Creating CScriptRemoveModule.
INFO:
Scripting Modules - Initialization time 0.020 / 18.206 seconds.
INFO:
Load Modules - Initialization time 0.000 / 18.206 seconds.
INFO: Media manager CDVDManager scene initialization...
INFO: Creating CDVDManagerOverlay.
INFO: Creating CDVDManagerExtendedOverlay.
INFO: Creating CDVDTray.
INFO:
CDVDManager - Initialization time 0.000 / 18.206 seconds.
INFO: Media manager CiPodManager scene initialization...
INFO: Creating CiPodManagerOverlay.
INFO: Creating CiPodManagerExtendedOverlay.
INFO: Creating CiPodMusicTray.
INFO:
CiPodManager - Initialization time 0.020 / 18.226 seconds.
INFO: Media manager CLaunchCastManager scene initialization...
INFO: Creating CLaunchCastManagerOverlay.
INFO: Creating CLaunchCastManagerExtendedOverlay.
INFO: Creating CLaunchCastTray.
INFO:
CLaunchCastManager - Initialization time 0.000 / 18.226 seconds.
INFO: Media manager CXMRadioManager scene initialization...
INFO: Creating CXMRadioManagerOverlay.
INFO: Creating CXMRadioManagerExtendedOverlay.
INFO: Creating CSatRadioTray.
INFO:
CXMRadioManager - Initialization time 0.040 / 18.266 seconds.
INFO: Media manager CRadioManager scene initialization...
INFO: Creating CRadioManagerOverlay.
INFO: Creating CRadioManagerExtendedOverlay.
INFO: Creating CRadioTray.
INFO:
CRadioManager - Initialization time 0.021 / 18.287 seconds.
INFO: Media manager CTVManager scene initialization...
INFO: Creating CTVManagerOverlay.
INFO: Creating CTVManagerExtendedOverlay.
INFO: Creating CTVTray.
INFO:
CTVManager - Initialization time 0.000 / 18.287 seconds.
INFO: Media manager CVideoFileManager scene initialization...
INFO: Creating CVideoFileManagerOverlay.
INFO: Creating CVideoFileManagerExtendedOverlay.
INFO: Creating CVideoTray.
INFO:
CVideoFileManager - Initialization time 0.000 / 18.287 seconds.
INFO: Media manager CAudioFileManager scene initialization...
INFO: Creating CAudioFileManagerOverlay.
INFO: Creating CAudioFileManagerExtendedOverlay.
INFO: Creating CMusicTray.
INFO:
CAudioFileManager - Initialization time 0.010 / 18.297 seconds.
INFO:
Media Manager Ontime Scene Init - Initialization time 0.020 / 18.317 seconds.
INFO: CAppData::LoadXMLSettings - Loading XML Settings from C:\Documents and Settings\Administrator\My Documents\StreetDeck\config.xml...
INFO: CGirderModule::OnLoadXMLConfig - No plugins were loaded from the girder plugin path!
WARNING: CRelayModule::OnLoadXMLConfig - No plugins were loaded from the Relay plugin path!
INFO:
Load Settings - Initialization time 0.140 / 18.457 seconds.
WARNING: CAppData::SortOverlays - Could not find overlay (CPanelChooserOverlay) to set Z-Order!
WARNING: CAppData::SortOverlays - Could not find overlay ({A42819EF-8B34-48C2-80CF-3B8754FD7F1B}\OverlayTest) to set Z-Order!
WARNING: CAppData::SortOverlays - Could not find overlay ({458E5981-B826-43C6-9D9C-C0C3D0C4EFBE}\ListenForFunctions) to set Z-Order!
WARNING: CAppData::SortOverlays - Could not find overlay ({DE5511FB-CE24-4CB8-8709-C5288EF3A2B9}\VoiceShowRecognitionOverlay) to set Z-Order!
INFO:
Init Skin - Initialization time 0.010 / 18.467 seconds.
INFO: Overlay CDVDManagerExtendedOverlay scene initialization...
INFO: Overlay CNAVScrollMapOverlay scene initialization...
INFO: Overlay CFullscreenTVOverlay scene initialization...
INFO: Overlay CFullscreenDVDOverlay scene initialization...
INFO: Overlay CFullscreenVideoStoppedInfoOverlay scene initialization...
INFO: Overlay CFullscreenVideoOverlay scene initialization...
INFO: Overlay CMuteOverlay scene initialization...
INFO: Overlay CUserOverlay3 scene initialization...
INFO: Overlay CUserExtendedOverlay2 scene initialization...
INFO: Overlay CTVManagerOverlay scene initialization...
INFO: Overlay FileOptionsOverlay scene initialization...
INFO: Overlay CKeyPadNumbersOverlay scene initialization...
INFO: Overlay CMultiMonEnabledOverlay scene initialization...
INFO: Overlay CComboSelectOverlay scene initialization...
INFO: Overlay CRearCameraPropOverlay scene initialization...
INFO: Overlay CFunctionNameOverlay scene initialization...
INFO: Overlay CUserExtendedOverlay5 scene initialization...
INFO: Overlay CWebServicesOverlay scene initialization...
INFO: Overlay CDVDTray scene initialization...
INFO: Overlay CTVChannelChangeOverlay scene initialization...
INFO: Overlay CListSearchOverlay scene initialization...
INFO: Overlay CUserOverlay4 scene initialization...
INFO: Overlay CiPodManagerExtendedOverlay scene initialization...
INFO: Overlay CNAVViewDirectionOverlay scene initialization...
INFO: Overlay CSafeModulesOverlay scene initialization...
INFO: Overlay CUserExtendedOverlay4 scene initialization...
INFO: Overlay CFullscreenVideoInfoOverlay scene initialization...
INFO: Overlay CSlideshowOverlay scene initialization...
INFO: Overlay CMediaChangeOverlay scene initialization...
INFO: Overlay CVolumeOverlay scene initialization...
INFO: Overlay CUserOverlay5 scene initialization...
INFO: Overlay CSatRadioTray scene initialization...
INFO: Overlay CXMRadioManagerOverlay scene initialization...
INFO: Overlay CNAVFullscreenOverlay scene initialization...
INFO: Overlay CBluetoothIncomingCallOverlay scene initialization...
INFO: Overlay CUserExtendedOverlay7 scene initialization...
INFO: Overlay CRadioManagerExtendedOverlay scene initialization...
INFO: Overlay CUserOverlay6 scene initialization...
INFO: Overlay CRadioManagerOverlay scene initialization...
INFO: Overlay CDVDManagerOverlay scene initialization...
INFO: Overlay CNAVClickedLocationOverlay scene initialization...
INFO: Overlay CLaunchCastLoadedOverlay scene initialization...
INFO: Overlay CUserExtendedOverlay6 scene initialization...
INFO: Overlay CMediaTimeOverlay scene initialization...
INFO: Overlay CVideoTray scene initialization...
INFO: Overlay CTVTray scene initialization...
INFO: Overlay CRadioTray scene initialization...
INFO: Overlay CLaunchCastTray scene initialization...
INFO: Overlay CNAVGPSTrackingOverlay scene initialization...
INFO: Overlay CNAVViewFullscreenOverlay scene initialization...
INFO: Overlay CVisTitleOverlay scene initialization...
INFO: Overlay CGestureModule scene initialization...
INFO: Overlay CBluetoothVoiceRecognitionOverlay scene initialization...
INFO: Overlay CUserOverlay7 scene initialization...
INFO: Overlay CMusicTray scene initialization...
INFO: Overlay CiPodMusicTray scene initialization...
INFO: Overlay CBluetoothConnectedOverlay scene initialization...
INFO: Overlay CUserExtendedOverlay9 scene initialization...
INFO: Overlay CNetworkCommOverlay scene initialization...
INFO: Overlay CAlwaysVisibleOverlay scene initialization...
INFO: Overlay CUserExtendedOverlay1 scene initialization...
INFO: Overlay CUserOverlay0 scene initialization...
INFO: Overlay CAudioFileManagerExtendedOverlay scene initialization...
INFO: Overlay CVideoFileManagerOverlay scene initialization...
INFO: Overlay CLaunchCastManagerExtendedOverlay scene initialization...
INFO: Overlay CLaunchCastManagerOverlay scene initialization...
INFO: Overlay CTVPropOverlay scene initialization...
INFO: Overlay CHDRadioKeypadOverlay scene initialization...
INFO: Overlay CUserExtendedOverlay8 scene initialization...
INFO: Overlay CUserOverlay8 scene initialization...
INFO: Overlay CVideoFileManagerExtendedOverlay scene initialization...
INFO: Overlay CNAVCurrentDirectionOverlay scene initialization...
INFO: Overlay CNAVViewListOverlay scene initialization...
INFO: Overlay CVoiceInputModule scene initialization...
INFO: Overlay CBluetoothActiveCallOverlay scene initialization...
INFO: Overlay CUserOverlay1 scene initialization...
INFO: Overlay CUserExtendedOverlay0 scene initialization...
INFO: Overlay CMediaPlaySpeedOverlay scene initialization...
INFO: Overlay CKeyPadLettersOverlay scene initialization...
INFO: Overlay CNAVViewStatusOverlay scene initialization...
INFO: Overlay CRearviewCameraOverlay scene initialization...
INFO: Overlay CFullscreenVideoResumeInfoOverlay scene initialization...
INFO: Overlay CRipMediaOverlay scene initialization...
INFO: Overlay CUserOverlay9 scene initialization...
INFO: Overlay CTVManagerExtendedOverlay scene initialization...
INFO: Overlay CNAVVirtualEarthOverlay scene initialization...
INFO: Overlay CGirderModule scene initialization...
INFO: Overlay CMusicLoadedOverlay scene initialization...
INFO: Overlay CUserExtendedOverlay3 scene initialization...
INFO: Overlay CUserOverlay2 scene initialization...
INFO: Overlay CKeyPadWebOverlay scene initialization...
INFO: Overlay CAudioFileManagerOverlay scene initialization...
INFO: Overlay CXMRadioManagerExtendedOverlay scene initialization...
INFO: Overlay CiPodManagerOverlay scene initialization...
INFO: Overlay CVisAlbumArtOverlay scene initialization...
INFO: Overlay CRelayModule scene initialization...
INFO: Overlay CKeyPadAlwaysVisibleOverlay scene initialization...
INFO:
Overlay Scene Init - Initialization time 0.040 / 18.507 seconds.
INFO: Module CNAVFindResultsModule scene initialization...
INFO: Module CNAVFavoritesRenameModule scene initialization...
INFO: Module CNAVStreetSettingsModule scene initialization...
INFO: Module CNAVMapOnlyModule scene initialization...
INFO: Module CTVOptionsModule scene initialization...
INFO: Module CStartModule scene initialization...
INFO: Module CRipMediaTransferModule scene initialization...
INFO: Module CNetSyncSettingsModule scene initialization...
INFO: Module CUserModule8 scene initialization...
INFO: Module CWSUserNameRenameModule scene initialization...
INFO: Module CRemoteMediaDestinationModule scene initialization...
INFO: Module CScriptRemoveModule scene initialization...
INFO: Module CNAVFindPlacesListModule scene initialization...
INFO: Module CFullScreenDVDModule scene initialization...
INFO: Module CLCPasswordRenameModule scene initialization...
INFO: Module CShutdownSettingsModule scene initialization...
INFO: Module CVolumeModule scene initialization...
INFO: Module CBluetoothSettingsModule scene initialization...
INFO: Module CBluetoothPairedDevicesModule scene initialization...
INFO: Module CNAVPOIModule scene initialization...
INFO: Module CDiagnosticsViewCodeModule scene initialization...
INFO: Module CHelpModule scene initialization...
INFO: Module CYahooSearchModule scene initialization...
INFO: Module CMediaDestinationRename scene initialization...
INFO: Module CRipMediaSettingsModule scene initialization...
INFO: Module CNetComputerBrowserModule scene initialization...
INFO: Module CBluetoothSendTonesModule scene initialization...
INFO: Module CBluetoothStartModule scene initialization...
INFO: Module CNAVShowRouteModule scene initialization...
INFO: Module CRipMediaPOIModule scene initialization...
INFO: Module CNAVMapModule scene initialization...
INFO: Module CFullScreenTVModule scene initialization...
INFO: Module CFullScreenVideoFileModule scene initialization...
INFO: Module CMusicVMODStartModule scene initialization...
INFO: Module CMusicArtistStringColModule scene initialization...
INFO: Module CMusicPlaylistModule scene initialization...
INFO: Module CGeneralSettingsModule scene initialization...
INFO: Module CRenameModule scene initialization...
INFO: Module CBluetoothPhoneBookEntryModule scene initialization...
INFO: Module CUserModule5 scene initialization...
INFO: Module CNAVFindPlaceModule scene initialization...
INFO: Module CNAVDBFindPlaceModule scene initialization...
INFO: Module CRearviewCameraModule scene initialization...
INFO: Module CRearviewCameraSettingsModule scene initialization...
INFO: Module CDVDSelectSubPictureStreamModule scene initialization...
INFO: Module CPictureSettingsModule scene initialization...
INFO: Module CMusicSelectFolderModule scene initialization...
INFO: Module CExternalAppsModule scene initialization...
INFO: Module CRelayPluginSettingsModule scene initialization...
INFO: Module CBluetoothImportBluetoothModule scene initialization...
INFO: Module CUserModule4 scene initialization...
INFO: Module CNAVSettingsModule scene initialization...
INFO: Module COBDIISettingsModule scene initialization...
INFO: Module CMusicPlaylistContentsModule scene initialization...
INFO: Module CMainSettingsModule scene initialization...
INFO: Module CSyncSourceModule scene initialization...
INFO: Module CMultiMonSettingsModule scene initialization...
INFO: Module CCalibrateDisplayModule scene initialization...
INFO: Module CStartupSettingsModuleWizard scene initialization...
INFO: Module CSystemRestoreModule scene initialization...
INFO: Module CBalanceFaderModule scene initialization...
INFO: Module CBluetoothPhoneBookModule scene initialization...
INFO: Module CBluetoothPairedDeviceStatusModule scene initialization...
INFO: Module CUserModule7 scene initialization...
INFO: Module CDiagnosticsModule scene initialization...
INFO: Module CXMRadioChooseStationsModule scene initialization...
INFO: Module CShutdownModule scene initialization...
INFO: Module CDisplaySettingsModule scene initialization...
INFO: Module CConfigureRelayPluginSettingsModule scene initialization...
INFO: Module CUserModule6 scene initialization...
INFO: Module CNAVRouteTypeModule scene initialization...
INFO: Module CHDRadioModule scene initialization...
INFO: Module CiPodModule scene initialization...
INFO: Module CRipMediaMusicModule scene initialization...
INFO: Module CMusicSettingsModule scene initialization...
INFO: Module CShortcutsModule scene initialization...
INFO: Module CChooseRelaysSettingsModule scene initialization...
INFO: Module CBluetoothImportModule scene initialization...
INFO: Module CUserModule1 scene initialization...
INFO: Module CNAVFindAddress scene initialization...
INFO: Module CVehicleModule scene initialization...
INFO: Module CDVDInfoModule scene initialization...
INFO: Module CVideoSettingsModule scene initialization...
INFO: Module CXMRadioSettingsModule scene initialization...
INFO: Module CVisualizationModule scene initialization...
INFO: Module CColorSettingsModule scene initialization...
INFO: Module CWMEqualizerModule scene initialization...
INFO: Module CBluetoothImportCSVModule scene initialization...
INFO: Module CUserModule0 scene initialization...
INFO: Module CPackageListModule scene initialization...
INFO: Module CVehicleSettingsModule scene initialization...
INFO: Module CDVDSelectAudioStreamModule scene initialization...
INFO: Module CXMRadioSettingsModuleWizard scene initialization...
INFO: Module CRadioSettingsModule scene initialization...
INFO: Module CSystemInformationModule scene initialization...
INFO: Module CKeyboardSettingsModule scene initialization...
INFO: Module CNetShareBrowserModule scene initialization...
INFO: Module CBluetoothVolumeModule scene initialization...
INFO: Module CBluetoothSettingsModuleWizard scene initialization...
INFO: Module CUserModule3 scene initialization...
INFO: Module CRipMediaVideosModule scene initialization...
INFO: Module CNAVFullScreenModule scene initialization...
INFO: Module CPicturesModule scene initialization...
INFO: Module CGirderPluginSettingsModule scene initialization...
INFO: Module CLCUserNameRenameModule scene initialization...
INFO: Module CAboutModule scene initialization...
INFO: Module CProcessShutdownModule scene initialization...
INFO: Module CSkinSettingsModule scene initialization...
INFO: Module CUserNameRenameModule scene initialization...
INFO: Module CFileSearchRenameModule scene initialization...
INFO: Module CBluetoothCallLogModule scene initialization...
INFO: Module CBluetoothMainModule scene initialization...
INFO: Module CUserModule2 scene initialization...
INFO: Module CAddPackageModule scene initialization...
INFO: Module CNAVCustomPOIModule scene initialization...
INFO: Module CLaunchCastFilterStationsModule scene initialization...
INFO: Module CMusicAlbumStringColModule scene initialization...
INFO: Module CVoiceInputSettingsModule scene initialization...
INFO: Module CBluetoothEditPhoneBookEntryModule scene initialization...
INFO: Module CConfigureRearviewCameraSettingsModule scene initialization...
INFO: Module CGirderSettingsModule scene initialization...
INFO: Module CLaunchCastModule scene initialization...
INFO: Module CMusicNowPlayingModule scene initialization...
INFO: Module CMusicSearchModule scene initialization...
INFO: Module CMusicSearchResultsModule scene initialization...
INFO: Module CSetTimeSettingsModule scene initialization...
INFO: Module CStartupSettingsModule scene initialization...
INFO: Module CFileSearchResultsModule scene initialization...
INFO: Module CGestureSettingsModule scene initialization...
INFO: Module CEnhancedAudioModule scene initialization...
INFO: Module CBluetoothPhoneStatusModule scene initialization...
INFO: Module CBluetoothPairingModule scene initialization...
INFO: Module CWebServicesSettingsModule scene initialization...
INFO: Module CScriptListModule scene initialization...
INFO: Module CUpdateListModule scene initialization...
INFO: Module CNAVSettingsModuleWizard scene initialization...
INFO: Module CNAVFindNearbyModule scene initialization...
INFO: Module CNAVStatusModule scene initialization...
INFO: Module CDVDOptionsModule scene initialization...
INFO: Module CLaunchCastSettingsModule scene initialization...
INFO: Module CInputOptionsSettingsModule scene initialization...
INFO: Module CMoveFileModule scene initialization...
INFO: Module CVehicleGraphOBDIIModule scene initialization...
INFO: Module CDVDSettingsModule scene initialization...
INFO: Module CMusicSongStringColModule scene initialization...
INFO: Module CMusicModule scene initialization...
INFO: Module CInputSettingsModule scene initialization...
INFO: Module CPasswordRenameModule scene initialization...
INFO: Module CConfigureRelaySetSettingsModule scene initialization...
INFO: Module CBluetoothActiveCallModule scene initialization...
INFO: Module CWSPasswordRenameModule scene initialization...
INFO: Module CNAVStartModule scene initialization...
INFO: Module CNAVFindLatLongModule scene initialization...
INFO: Module CNAVDirectionsModule scene initialization...
INFO: Module CXMRadioModule scene initialization...
INFO: Module CDisplaySettingsModuleWizard scene initialization...
INFO: Module CRipMediaSelectTypeModule scene initialization...
INFO: Module CRelaySettingsModule scene initialization...
INFO: Module CRelaySetSettingsModule scene initialization...
INFO: Module CGlyphSettingsModule scene initialization...
INFO: Module CAppSoundsModule scene initialization...
INFO: Module CBluetoothDialNumberModule scene initialization...
INFO: Module CRelayControlModule scene initialization...
INFO: Module CVideosModule scene initialization...
INFO: Module CSlideshowModule scene initialization...
INFO: Module CRipMediaPicturesModule scene initialization...
INFO: Module CXMRadioStationListModule scene initialization...
INFO: Module CXMRadioStatusModule scene initialization...
INFO: Module CLaunchCastStationGuideModule scene initialization...
INFO: Module CMusicStartModule scene initialization...
INFO: Module CMusicGenreStringColModule scene initialization...
INFO: Module CMusicArtistAlbumModule scene initialization...
INFO: Module CSimpleSettingsModule scene initialization...
INFO: Module CSetTimeSettingsModuleWizard scene initialization...
INFO: Module CRelayRenameModule scene initialization...
INFO: Module CBluetoothOptionsModule scene initialization...
INFO: Module CUserModule9 scene initialization...
INFO:
Module Scene Init - Initialization time 0.070 / 18.577 seconds.
INFO: CDrawWnd::RestoreDeviceObjects...
INFO: CDrawWnd::RestoreDeviceObjects - SetTransform
INFO: CDrawWnd::RestoreDeviceObjects - GetRenderTarget
WARNING: .\DrawWnd.cpp:2171 HRCALL Failed!
0x80004005 = MD_OnRestoreDeviceObjects()
INFO: CFontBag::RestoreDeviceObjects...
INFO: CD3DBitmapFont::AllocBatchData - Creating Vertex Shaders
INFO: CD3DBitmapFont::AllocBatchData - Creating Vertex Buffer
INFO: CD3DBitmapFont::AllocBatchData - Creating Index Buffer
INFO: CD3DBitmapFont::AllocBatchData - Checking for alpha blend support
INFO: CD3DBitmapFont::AllocBatchData - Setting Render States
INFO: CD3DBitmapFont::AllocBatchData - Successfully set render states
INFO: Restoring overlay CDVDManagerExtendedOverlay device objects...
INFO: Restoring overlay CNAVScrollMapOverlay device objects...
INFO: Restoring overlay CFullscreenTVOverlay device objects...
INFO: Restoring overlay CFullscreenDVDOverlay device objects...
INFO: Restoring overlay CFullscreenVideoStoppedInfoOverlay device objects...
INFO: Restoring overlay CFullscreenVideoOverlay device objects...
INFO: Restoring overlay CMuteOverlay device objects...
INFO: Restoring overlay CUserOverlay3 device objects...
INFO: Restoring overlay CUserExtendedOverlay2 device objects...
INFO: Restoring overlay CTVManagerOverlay device objects...
INFO: Restoring overlay FileOptionsOverlay device objects...
INFO: Restoring overlay CKeyPadNumbersOverlay device objects...
INFO: Restoring overlay CMultiMonEnabledOverlay device objects...
INFO: Restoring overlay CComboSelectOverlay device objects...
INFO: Restoring overlay CRearCameraPropOverlay device objects...
INFO: Restoring overlay CFunctionNameOverlay device objects...
INFO: Restoring overlay CUserExtendedOverlay5 device objects...
INFO: Restoring overlay CWebServicesOverlay device objects...
INFO: Restoring overlay CDVDTray device objects...
INFO: Restoring overlay CTVChannelChangeOverlay device objects...
INFO: Restoring overlay CListSearchOverlay device objects...
INFO: Restoring overlay CUserOverlay4 device objects...
INFO: Restoring overlay CiPodManagerExtendedOverlay device objects...
INFO: Restoring overlay CNAVViewDirectionOverlay device objects...
INFO: Restoring overlay CSafeModulesOverlay device objects...
INFO: Restoring overlay CUserExtendedOverlay4 device objects...
INFO: Restoring overlay CFullscreenVideoInfoOverlay device objects...
INFO: Restoring overlay CSlideshowOverlay device objects...
INFO: Restoring overlay CMediaChangeOverlay device objects...
INFO: Restoring overlay CVolumeOverlay device objects...
INFO: Restoring overlay CUserOverlay5 device objects...
INFO: Restoring overlay CSatRadioTray device objects...
INFO: Restoring overlay CXMRadioManagerOverlay device objects...
INFO: Restoring overlay CNAVFullscreenOverlay device objects...
INFO: Restoring overlay CBluetoothIncomingCallOverlay device objects...
INFO: Restoring overlay CUserExtendedOverlay7 device objects...
INFO: Restoring overlay CRadioManagerExtendedOverlay device objects...
INFO: Restoring overlay CUserOverlay6 device objects...
INFO: Restoring overlay CRadioManagerOverlay device objects...
INFO: Restoring overlay CDVDManagerOverlay device objects...
INFO: Restoring overlay CNAVClickedLocationOverlay device objects...
INFO: Restoring overlay CLaunchCastLoadedOverlay device objects...
INFO: Restoring overlay CUserExtendedOverlay6 device objects...
INFO: Restoring overlay CMediaTimeOverlay device objects...
INFO: Restoring overlay CVideoTray device objects...
INFO: Restoring overlay CTVTray device objects...
INFO: Restoring overlay CRadioTray device objects...
INFO: Restoring overlay CLaunchCastTray device objects...
INFO: Restoring overlay CNAVGPSTrackingOverlay device objects...
INFO: Restoring overlay CNAVViewFullscreenOverlay device objects...
INFO: Restoring overlay CVisTitleOverlay device objects...
INFO: Restoring overlay CGestureModule device objects...
INFO: Restoring overlay CBluetoothVoiceRecognitionOverlay device objects...
INFO: Restoring overlay CUserOverlay7 device objects...
INFO: Restoring overlay CMusicTray device objects...
INFO: Restoring overlay CiPodMusicTray device objects...
INFO: Restoring overlay CBluetoothConnectedOverlay device objects...
INFO: Restoring overlay CUserExtendedOverlay9 device objects...
INFO: Restoring overlay CNetworkCommOverlay device objects...
INFO: Restoring overlay CAlwaysVisibleOverlay device objects...
INFO: Restoring overlay CUserExtendedOverlay1 device objects...
INFO: Restoring overlay CUserOverlay0 device objects...
INFO: Restoring overlay CAudioFileManagerExtendedOverlay device objects...
INFO: Restoring overlay CVideoFileManagerOverlay device objects...
INFO: Restoring overlay CLaunchCastManagerExtendedOverlay device objects...
INFO: Restoring overlay CLaunchCastManagerOverlay device objects...
INFO: Restoring overlay CTVPropOverlay device objects...
INFO: Restoring overlay CHDRadioKeypadOverlay device objects...
INFO: Restoring overlay CUserExtendedOverlay8 device objects...
INFO: Restoring overlay CUserOverlay8 device objects...
INFO: Restoring overlay CVideoFileManagerExtendedOverlay device objects...
INFO: Restoring overlay CNAVCurrentDirectionOverlay device objects...
INFO: Restoring overlay CNAVViewListOverlay device objects...
INFO: Restoring overlay CVoiceInputModule device objects...
INFO: Restoring overlay CBluetoothActiveCallOverlay device objects...
INFO: Restoring overlay CUserOverlay1 device objects...
INFO: Restoring overlay CUserExtendedOverlay0 device objects...
INFO: Restoring overlay CMediaPlaySpeedOverlay device objects...
INFO: Restoring overlay CKeyPadLettersOverlay device objects...
INFO: Restoring overlay CNAVViewStatusOverlay device objects...
INFO: Restoring overlay CRearviewCameraOverlay device objects...
INFO: Restoring overlay CFullscreenVideoResumeInfoOverlay device objects...
INFO: Restoring overlay CRipMediaOverlay device objects...
INFO: Restoring overlay CUserOverlay9 device objects...
INFO: Restoring overlay CTVManagerExtendedOverlay device objects...
INFO: Restoring overlay CNAVVirtualEarthOverlay device objects...
INFO: Restoring overlay CGirderModule device objects...
INFO: Restoring overlay CMusicLoadedOverlay device objects...
INFO: Restoring overlay CUserExtendedOverlay3 device objects...
INFO: Restoring overlay CUserOverlay2 device objects...
INFO: Restoring overlay CKeyPadWebOverlay device objects...
INFO: Restoring overlay CAudioFileManagerOverlay device objects...
INFO: Restoring overlay CXMRadioManagerExtendedOverlay device objects...
INFO: Restoring overlay CiPodManagerOverlay device objects...
INFO: Restoring overlay CVisAlbumArtOverlay device objects...
INFO: Restoring overlay CRelayModule device objects...
INFO: Restoring overlay CKeyPadAlwaysVisibleOverlay device objects...
INFO: Restoring module CNAVFindResultsModule device objects...
INFO: Restoring module CNAVFavoritesRenameModule device objects...
INFO: Restoring module CNAVStreetSettingsModule device objects...
INFO: Restoring module CNAVMapOnlyModule device objects...
INFO: Restoring module CTVOptionsModule device objects...
INFO: Restoring module CStartModule device objects...
INFO: Restoring module CRipMediaTransferModule device objects...
INFO: Restoring module CNetSyncSettingsModule device objects...
INFO: Restoring module CUserModule8 device objects...
INFO: Restoring module CWSUserNameRenameModule device objects...
INFO: Restoring module CRemoteMediaDestinationModule device objects...
INFO: Restoring module CScriptRemoveModule device objects...
INFO: Restoring module CNAVFindPlacesListModule device objects...
INFO: Restoring module CFullScreenDVDModule device objects...
INFO: Restoring module CLCPasswordRenameModule device objects...
INFO: Restoring module CShutdownSettingsModule device objects...
INFO: Restoring module CVolumeModule device objects...
INFO: Restoring module CBluetoothSettingsModule device objects...
INFO: Restoring module CBluetoothPairedDevicesModule device objects...
INFO: Restoring module CNAVPOIModule device objects...
INFO: Restoring module CDiagnosticsViewCodeModule device objects...
INFO: Restoring module CHelpModule device objects...
INFO: Restoring module CYahooSearchModule device objects...
INFO: Restoring module CMediaDestinationRename device objects...
INFO: Restoring module CRipMediaSettingsModule device objects...
INFO: Restoring module CNetComputerBrowserModule device objects...
INFO: Restoring module CBluetoothSendTonesModule device objects...
INFO: Restoring module CBluetoothStartModule device objects...
INFO: Restoring module CNAVShowRouteModule device objects...
INFO: Restoring module CRipMediaPOIModule device objects...
INFO: Restoring module CNAVMapModule device objects...
INFO: Restoring module CFullScreenTVModule device objects...
INFO: Restoring module CFullScreenVideoFileModule device objects...
INFO: Restoring module CMusicVMODStartModule device objects...
INFO: Restoring module CMusicArtistStringColModule device objects...
INFO: Restoring module CMusicPlaylistModule device objects...
INFO: Restoring module CGeneralSettingsModule device objects...
INFO: Restoring module CRenameModule device objects...
INFO: Restoring module CBluetoothPhoneBookEntryModule device objects...
INFO: Restoring module CUserModule5 device objects...
INFO: Restoring module CNAVFindPlaceModule device objects...
INFO: Restoring module CNAVDBFindPlaceModule device objects...
INFO: Restoring module CRearviewCameraModule device objects...
INFO: Restoring module CRearviewCameraSettingsModule device objects...
INFO: Restoring module CDVDSelectSubPictureStreamModule device objects...
INFO: Restoring module CPictureSettingsModule device objects...
INFO: Restoring module CMusicSelectFolderModule device objects...
INFO: Restoring module CExternalAppsModule device objects...
INFO: Restoring module CRelayPluginSettingsModule device objects...
INFO: Restoring module CBluetoothImportBluetoothModule device objects...
INFO: Restoring module CUserModule4 device objects...
INFO: Restoring module CNAVSettingsModule device objects...
INFO: Restoring module COBDIISettingsModule device objects...
INFO: Restoring module CMusicPlaylistContentsModule device objects...
INFO: Restoring module CMainSettingsModule device objects...
INFO: Restoring module CSyncSourceModule device objects...
INFO: Restoring module CMultiMonSettingsModule device objects...
INFO: Restoring module CCalibrateDisplayModule device objects...
INFO: Restoring module CStartupSettingsModuleWizard device objects...
INFO: Restoring module CSystemRestoreModule device objects...
INFO: Restoring module CBalanceFaderModule device objects...
INFO: Restoring module CBluetoothPhoneBookModule device objects...
INFO: Restoring module CBluetoothPairedDeviceStatusModule device objects...
INFO: Restoring module CUserModule7 device objects...
INFO: Restoring module CDiagnosticsModule device objects...
INFO: Restoring module CXMRadioChooseStationsModule device objects...
INFO: Restoring module CShutdownModule device objects...
INFO: Restoring module CDisplaySettingsModule device objects...
INFO: Restoring module CConfigureRelayPluginSettingsModule device objects...
INFO: Restoring module CUserModule6 device objects...
INFO: Restoring module CNAVRouteTypeModule device objects...
INFO: Restoring module CHDRadioModule device objects...
INFO: Restoring module CiPodModule device objects...
INFO: Restoring module CRipMediaMusicModule device objects...
INFO: Restoring module CMusicSettingsModule device objects...
INFO: Restoring module CShortcutsModule device objects...
INFO: Restoring module CChooseRelaysSettingsModule device objects...
INFO: Restoring module CBluetoothImportModule device objects...
INFO: Restoring module CUserModule1 device objects...
INFO: Restoring module CNAVFindAddress device objects...
INFO: Restoring module CVehicleModule device objects...
INFO: Restoring module CDVDInfoModule device objects...
INFO: Restoring module CVideoSettingsModule device objects...
INFO: Restoring module CXMRadioSettingsModule device objects...
INFO: Restoring module CVisualizationModule device objects...
INFO: Restoring module CColorSettingsModule device objects...
INFO: Restoring module CWMEqualizerModule device objects...
INFO: Restoring module CBluetoothImportCSVModule device objects...
INFO: Restoring module CUserModule0 device objects...
INFO: Restoring module CPackageListModule device objects...
INFO: Restoring module CVehicleSettingsModule device objects...
INFO: Restoring module CDVDSelectAudioStreamModule device objects...
INFO: Restoring module CXMRadioSettingsModuleWizard device objects...
INFO: Restoring module CRadioSettingsModule device objects...
INFO: Restoring module CSystemInformationModule device objects...
INFO: Restoring module CKeyboardSettingsModule device objects...
INFO: Restoring module CNetShareBrowserModule device objects...
INFO: Restoring module CBluetoothVolumeModule device objects...
INFO: Restoring module CBluetoothSettingsModuleWizard device objects...
INFO: Restoring module CUserModule3 device objects...
INFO: Restoring module CRipMediaVideosModule device objects...
INFO: Restoring module CNAVFullScreenModule device objects...
INFO: Restoring module CPicturesModule device objects...
INFO: Restoring module CGirderPluginSettingsModule device objects...
INFO: Restoring module CLCUserNameRenameModule device objects...
INFO: Restoring module CAboutModule device objects...
INFO: Restoring module CProcessShutdownModule device objects...
INFO: Restoring module CSkinSettingsModule device objects...
INFO: Restoring module CUserNameRenameModule device objects...
INFO: Restoring module CFileSearchRenameModule device objects...
INFO: Restoring module CBluetoothCallLogModule device objects...
INFO: Restoring module CBluetoothMainModule device objects...
INFO: Restoring module CUserModule2 device objects...
INFO: Restoring module CAddPackageModule device objects...
INFO: Restoring module CNAVCustomPOIModule device objects...
INFO: Restoring module CLaunchCastFilterStationsModule device objects...
INFO: Restoring module CMusicAlbumStringColModule device objects...
INFO: Restoring module CVoiceInputSettingsModule device objects...
INFO: Restoring module CBluetoothEditPhoneBookEntryModule device objects...
INFO: Restoring module CConfigureRearviewCameraSettingsModule device objects...
INFO: Restoring module CGirderSettingsModule device objects...
INFO: Restoring module CLaunchCastModule device objects...
INFO: Restoring module CMusicNowPlayingModule device objects...
INFO: Restoring module CMusicSearchModule device objects...
INFO: Restoring module CMusicSearchResultsModule device objects...
INFO: Restoring module CSetTimeSettingsModule device objects...
INFO: Restoring module CStartupSettingsModule device objects...
INFO: Restoring module CFileSearchResultsModule device objects...
INFO: Restoring module CGestureSettingsModule device objects...
INFO: Restoring module CEnhancedAudioModule device objects...
INFO: Restoring module CBluetoothPhoneStatusModule device objects...
INFO: Restoring module CBluetoothPairingModule device objects...
INFO: Restoring module CWebServicesSettingsModule device objects...
INFO: Restoring module CScriptListModule device objects...
INFO: Restoring module CUpdateListModule device objects...
INFO: Restoring module CNAVSettingsModuleWizard device objects...
INFO: Restoring module CNAVFindNearbyModule device objects...
INFO: Restoring module CNAVStatusModule device objects...
INFO: Restoring module CDVDOptionsModule device objects...
INFO: Restoring module CLaunchCastSettingsModule device objects...
INFO: Restoring module CInputOptionsSettingsModule device objects...
INFO: Restoring module CMoveFileModule device objects...
INFO: Restoring module CVehicleGraphOBDIIModule device objects...
INFO: Restoring module CDVDSettingsModule device objects...
INFO: Restoring module CMusicSongStringColModule device objects...
INFO: Restoring module CMusicModule device objects...
INFO: Restoring module CInputSettingsModule device objects...
INFO: Restoring module CPasswordRenameModule device objects...
INFO: Restoring module CConfigureRelaySetSettingsModule device objects...
INFO: Restoring module CBluetoothActiveCallModule device objects...
INFO: Restoring module CWSPasswordRenameModule device objects...
INFO: Restoring module CNAVStartModule device objects...
INFO: Restoring module CNAVFindLatLongModule device objects...
INFO: Restoring module CNAVDirectionsModule device objects...
INFO: Restoring module CXMRadioModule device objects...
INFO: Restoring module CDisplaySettingsModuleWizard device objects...
INFO: Restoring module CRipMediaSelectTypeModule device objects...
INFO: Restoring module CRelaySettingsModule device objects...
INFO: Restoring module CRelaySetSettingsModule device objects...
INFO: Restoring module CGlyphSettingsModule device objects...
INFO: Restoring module CAppSoundsModule device objects...
INFO: Restoring module CBluetoothDialNumberModule device objects...
INFO: Restoring module CRelayControlModule device objects...
INFO: Restoring module CVideosModule device objects...
INFO: Restoring module CSlideshowModule device objects...
INFO: Restoring module CRipMediaPicturesModule device objects...
INFO: Restoring module CXMRadioStationListModule device objects...
INFO: Restoring module CXMRadioStatusModule device objects...
INFO: Restoring module CLaunchCastStationGuideModule device objects...
INFO: Restoring module CMusicStartModule device objects...
INFO: Restoring module CMusicGenreStringColModule device objects...
INFO: Restoring module CMusicArtistAlbumModule device objects...
INFO: Restoring module CSimpleSettingsModule device objects...
INFO: Restoring module CSetTimeSettingsModuleWizard device objects...
INFO: Restoring module CRelayRenameModule device objects...
INFO: Restoring module CBluetoothOptionsModule device objects...
INFO: Restoring module CUserModule9 device objects...
INFO: Restoring media manager CDVDManager device objects...
INFO: Restoring media manager CiPodManager device objects...
INFO: Restoring media manager CLaunchCastManager device objects...
INFO: Restoring media manager CXMRadioManager device objects...
INFO: Restoring media manager CRadioManager device objects...
INFO: Restoring media manager CTVManager device objects...
INFO: Restoring media manager CVideoFileManager device objects...
INFO: Restoring media manager CAudioFileManager device objects...
INFO: CAppData::Exec - Executing Module CStartModule
INFO: CDrawWnd::OnSettingsChange...
INFO: CSoundController::OnSettingsChange
INFO: CAppData::OnSettingsChange - Setting thread execution state...
INFO: Applying settings change to module CNAVFindResultsModule...
INFO: Applying settings change to module CNAVFavoritesRenameModule...
INFO: Applying settings change to module CNAVStreetSettingsModule...
INFO: Applying settings change to module CNAVMapOnlyModule...
INFO: Applying settings change to module CTVOptionsModule...
INFO: Applying settings change to module CStartModule...
INFO: Applying settings change to module CRipMediaTransferModule...
INFO: Applying settings change to module CNetSyncSettingsModule...
INFO: Applying settings change to module CUserModule8...
INFO: Applying settings change to module CWSUserNameRenameModule...
INFO: Applying settings change to module CRemoteMediaDestinationModule...
INFO: Applying settings change to module CScriptRemoveModule...
INFO: Applying settings change to module CNAVFindPlacesListModule...
INFO: Applying settings change to module CFullScreenDVDModule...
INFO: Applying settings change to module CLCPasswordRenameModule...
INFO: Applying settings change to module CShutdownSettingsModule...
INFO: Applying settings change to module CVolumeModule...
INFO: Applying settings change to module CBluetoothSettingsModule...
INFO: Applying settings change to module CBluetoothPairedDevicesModule...
INFO: Applying settings change to module CNAVPOIModule...
INFO: Applying settings change to module CDiagnosticsViewCodeModule...
INFO: Applying settings change to module CHelpModule...
INFO: Applying settings change to module CYahooSearchModule...
INFO: Applying settings change to module CMediaDestinationRename...
INFO: Applying settings change to module CRipMediaSettingsModule...
INFO: Applying settings change to module CNetComputerBrowserModule...
INFO: Applying settings change to module CBluetoothSendTonesModule...
INFO: Applying settings change to module CBluetoothStartModule...
INFO: Applying settings change to module CNAVShowRouteModule...
INFO: Applying settings change to module CRipMediaPOIModule...
INFO: Applying settings change to module CNAVMapModule...
INFO: Applying settings change to module CFullScreenTVModule...
INFO: Applying settings change to module CFullScreenVideoFileModule...
INFO: Applying settings change to module CMusicVMODStartModule...
INFO: Applying settings change to module CMusicArtistStringColModule...
INFO: Applying settings change to module CMusicPlaylistModule...
INFO: Applying settings change to module CGeneralSettingsModule...
INFO: Applying settings change to module CRenameModule...
INFO: Applying settings change to module CBluetoothPhoneBookEntryModule...
INFO: Applying settings change to module CUserModule5...
INFO: Applying settings change to module CNAVFindPlaceModule...
INFO: Applying settings change to module CNAVDBFindPlaceModule...
INFO: Applying settings change to module CRearviewCameraModule...
INFO: Applying settings change to module CRearviewCameraSettingsModule...
INFO: Applying settings change to module CDVDSelectSubPictureStreamModule...
INFO: Applying settings change to module CPictureSettingsModule...
INFO: Applying settings change to module CMusicSelectFolderModule...
INFO: Applying settings change to module CExternalAppsModule...
INFO: Applying settings change to module CRelayPluginSettingsModule...
INFO: Applying settings change to module CBluetoothImportBluetoothModule...
INFO: Applying settings change to module CUserModule4...
INFO: Applying settings change to module CNAVSettingsModule...
INFO: Applying settings change to module COBDIISettingsModule...
INFO: Applying settings change to module CMusicPlaylistContentsModule...
INFO: Applying settings change to module CMainSettingsModule...
INFO: Applying settings change to module CSyncSourceModule...
INFO: Applying settings change to module CMultiMonSettingsModule...
INFO: Applying settings change to module CCalibrateDisplayModule...
INFO: Applying settings change to module CStartupSettingsModuleWizard...
INFO: Applying settings change to module CSystemRestoreModule...
INFO: Applying settings change to module CBalanceFaderModule...
INFO: Applying settings change to module CBluetoothPhoneBookModule...
INFO: Applying settings change to module CBluetoothPairedDeviceStatusModule...
INFO: Applying settings change to module CUserModule7...
INFO: Applying settings change to module CDiagnosticsModule...
INFO: Applying settings change to module CXMRadioChooseStationsModule...
INFO: Applying settings change to module CShutdownModule...
INFO: Applying settings change to module CDisplaySettingsModule...
INFO: Applying settings change to module CConfigureRelayPluginSettingsModule...
INFO: Applying settings change to module CUserModule6...
INFO: Applying settings change to module CNAVRouteTypeModule...
INFO: Applying settings change to module CHDRadioModule...
INFO: Applying settings change to module CiPodModule...
INFO: Applying settings change to module CRipMediaMusicModule...
INFO: Applying settings change to module CMusicSettingsModule...
INFO: Applying settings change to module CShortcutsModule...
INFO: Applying settings change to module CChooseRelaysSettingsModule...
INFO: Applying settings change to module CBluetoothImportModule...
INFO: Applying settings change to module CUserModule1...
INFO: Applying settings change to module CNAVFindAddress...
INFO: Applying settings change to module CVehicleModule...
INFO: Applying settings change to module CDVDInfoModule...
INFO: Applying settings change to module CVideoSettingsModule...
INFO: Applying settings change to module CXMRadioSettingsModule...
INFO: Applying settings change to module CVisualizationModule...
INFO: Applying settings change to module CColorSettingsModule...
INFO: Applying settings change to module CWMEqualizerModule...
INFO: Applying settings change to module CBluetoothImportCSVModule...
INFO: Applying settings change to module CUserModule0...
INFO: Applying settings change to module CPackageListModule...
INFO: Applying settings change to module CVehicleSettingsModule...
INFO: Applying settings change to module CDVDSelectAudioStreamModule...
INFO: Applying settings change to module CXMRadioSettingsModuleWizard...
INFO: Applying settings change to module CRadioSettingsModule...
INFO: Applying settings change to module CSystemInformationModule...
INFO: Applying settings change to module CKeyboardSettingsModule...
INFO: Applying settings change to module CNetShareBrowserModule...
INFO: Applying settings change to module CBluetoothVolumeModule...
INFO: Applying settings change to module CBluetoothSettingsModuleWizard...
INFO: Applying settings change to module CUserModule3...
INFO: Applying settings change to module CRipMediaVideosModule...
INFO: Applying settings change to module CNAVFullScreenModule...
INFO: Applying settings change to module CPicturesModule...
INFO: Applying settings change to module CGirderPluginSettingsModule...
INFO: Applying settings change to module CLCUserNameRenameModule...
INFO: Applying settings change to module CAboutModule...
INFO: Applying settings change to module CProcessShutdownModule...
INFO: Applying settings change to module CSkinSettingsModule...
INFO: Applying settings change to module CUserNameRenameModule...
INFO: Applying settings change to module CFileSearchRenameModule...
INFO: Applying settings change to module CBluetoothCallLogModule...
INFO: Applying settings change to module CBluetoothMainModule...
INFO: Applying settings change to module CUserModule2...
INFO: Applying settings change to module CAddPackageModule...
INFO: Applying settings change to module CNAVCustomPOIModule...
INFO: Applying settings change to module CLaunchCastFilterStationsModule...
INFO: Applying settings change to module CMusicAlbumStringColModule...
INFO: Applying settings change to module CVoiceInputSettingsModule...
INFO: Applying settings change to module CBluetoothEditPhoneBookEntryModule...
INFO: Applying settings change to module CConfigureRearviewCameraSettingsModule...
INFO: Applying settings change to module CGirderSettingsModule...
INFO: Applying settings change to module CLaunchCastModule...
INFO: Applying settings change to module CMusicNowPlayingModule...
INFO: Applying settings change to module CMusicSearchModule...
INFO: Applying settings change to module CMusicSearchResultsModule...
INFO: Applying settings change to module CSetTimeSettingsModule...
INFO: Applying settings change to module CStartupSettingsModule...
INFO: Applying settings change to module CFileSearchResultsModule...
INFO: Applying settings change to module CGestureSettingsModule...
INFO: Applying settings change to module CEnhancedAudioModule...
INFO: Applying settings change to module CBluetoothPhoneStatusModule...
INFO: Applying settings change to module CBluetoothPairingModule...
INFO: Applying settings change to module CWebServicesSettingsModule...
INFO: Applying settings change to module CScriptListModule...
INFO: Applying settings change to module CUpdateListModule...
INFO: Applying settings change to module CNAVSettingsModuleWizard...
INFO: Applying settings change to module CNAVFindNearbyModule...
INFO: Applying settings change to module CNAVStatusModule...
INFO: Applying settings change to module CDVDOptionsModule...
INFO: Applying settings change to module CLaunchCastSettingsModule...
INFO: Applying settings change to module CInputOptionsSettingsModule...
INFO: Applying settings change to module CMoveFileModule...
INFO: Applying settings change to module CVehicleGraphOBDIIModule...
INFO: Applying settings change to module CDVDSettingsModule...
INFO: Applying settings change to module CMusicSongStringColModule...
INFO: Applying settings change to module CMusicModule...
INFO: Applying settings change to module CInputSettingsModule...
INFO: Applying settings change to module CPasswordRenameModule...
INFO: Applying settings change to module CConfigureRelaySetSettingsModule...
INFO: Applying settings change to module CBluetoothActiveCallModule...
INFO: Applying settings change to module CWSPasswordRenameModule...
INFO: Applying settings change to module CNAVStartModule...
INFO: Applying settings change to module CNAVFindLatLongModule...
INFO: Applying settings change to module CNAVDirectionsModule...
INFO: Applying settings change to module CXMRadioModule...
INFO: Applying settings change to module CDisplaySettingsModuleWizard...
INFO: Applying settings change to module CRipMediaSelectTypeModule...
INFO: Applying settings change to module CRelaySettingsModule...
INFO: Applying settings change to module CRelaySetSettingsModule...
INFO: Applying settings change to module CGlyphSettingsModule...
INFO: Applying settings change to module CAppSoundsModule...
INFO: Applying settings change to module CBluetoothDialNumberModule...
INFO: Applying settings change to module CRelayControlModule...
INFO: Applying settings change to module CVideosModule...
INFO: Applying settings change to module CSlideshowModule...
INFO: Applying settings change to module CRipMediaPicturesModule...
INFO: Applying settings change to module CXMRadioStationListModule...
INFO: Applying settings change to module CXMRadioStatusModule...
INFO: Applying settings change to module CLaunchCastStationGuideModule...
INFO: Applying settings change to module CMusicStartModule...
INFO: Applying settings change to module CMusicGenreStringColModule...
INFO: Applying settings change to module CMusicArtistAlbumModule...
INFO: Applying settings change to module CSimpleSettingsModule...
INFO: Applying settings change to module CSetTimeSettingsModuleWizard...
INFO: Applying settings change to module CRelayRenameModule...
INFO: Applying settings change to module CBluetoothOptionsModule...
INFO: Applying settings change to module CUserModule9...
INFO: Applying settings change to overlay CDVDManagerExtendedOverlay...
INFO: Applying settings change to overlay CNAVScrollMapOverlay...
INFO: Applying settings change to overlay CFullscreenTVOverlay...
INFO: Applying settings change to overlay CFullscreenDVDOverlay...
INFO: Applying settings change to overlay CFullscreenVideoStoppedInfoOverlay...
INFO: Applying settings change to overlay CFullscreenVideoOverlay...
INFO: Applying settings change to overlay CMuteOverlay...
INFO: Applying settings change to overlay CUserOverlay3...
INFO: Applying settings change to overlay CUserExtendedOverlay2...
INFO: Applying settings change to overlay CTVManagerOverlay...
INFO: Applying settings change to overlay FileOptionsOverlay...
INFO: Applying settings change to overlay CKeyPadNumbersOverlay...
INFO: Applying settings change to overlay CMultiMonEnabledOverlay...
INFO: Applying settings change to overlay CComboSelectOverlay...
INFO: Applying settings change to overlay CRearCameraPropOverlay...
INFO: Applying settings change to overlay CFunctionNameOverlay...
INFO: Applying settings change to overlay CUserExtendedOverlay5...
INFO: Applying settings change to overlay CWebServicesOverlay...
INFO: Applying settings change to overlay CDVDTray...
INFO: Applying settings change to overlay CTVChannelChangeOverlay...
INFO: Applying settings change to overlay CListSearchOverlay...
INFO: Applying settings change to overlay CUserOverlay4...
INFO: Applying settings change to overlay CiPodManagerExtendedOverlay...
INFO: Applying settings change to overlay CNAVViewDirectionOverlay...
INFO: Applying settings change to overlay CSafeModulesOverlay...
INFO: Applying settings change to overlay CUserExtendedOverlay4...
INFO: Applying settings change to overlay CFullscreenVideoInfoOverlay...
INFO: Applying settings change to overlay CSlideshowOverlay...
INFO: Applying settings change to overlay CMediaChangeOverlay...
INFO: Applying settings change to overlay CVolumeOverlay...
INFO: Applying settings change to overlay CUserOverlay5...
INFO: Applying settings change to overlay CSatRadioTray...
INFO: Applying settings change to overlay CXMRadioManagerOverlay...
INFO: Applying settings change to overlay CNAVFullscreenOverlay...
INFO: Applying settings change to overlay CBluetoothIncomingCallOverlay...
INFO: Applying settings change to overlay CUserExtendedOverlay7...
INFO: Applying settings change to overlay CRadioManagerExtendedOverlay...
INFO: Applying settings change to overlay CUserOverlay6...
INFO: Applying settings change to overlay CRadioManagerOverlay...
INFO: Applying settings change to overlay CDVDManagerOverlay...
INFO: Applying settings change to overlay CNAVClickedLocationOverlay...
INFO: Applying settings change to overlay CLaunchCastLoadedOverlay...
INFO: Applying settings change to overlay CUserExtendedOverlay6...
INFO: Applying settings change to overlay CMediaTimeOverlay...
INFO: Applying settings change to overlay CVideoTray...
INFO: Applying settings change to overlay CTVTray...
INFO: Applying settings change to overlay CRadioTray...
INFO: Applying settings change to overlay CLaunchCastTray...
INFO: Applying settings change to overlay CNAVGPSTrackingOverlay...
INFO: Applying settings change to overlay CNAVViewFullscreenOverlay...
INFO: Applying settings change to overlay CVisTitleOverlay...
INFO: Applying settings change to overlay CGestureModule...
INFO: Applying settings change to overlay CBluetoothVoiceRecognitionOverlay...
INFO: Applying settings change to overlay CUserOverlay7...
INFO: Applying settings change to overlay CMusicTray...
INFO: Applying settings change to overlay CiPodMusicTray...
INFO: Applying settings change to overlay CBluetoothConnectedOverlay...
INFO: Applying settings change to overlay CUserExtendedOverlay9...
INFO: Applying settings change to overlay CNetworkCommOverlay...
INFO: Applying settings change to overlay CAlwaysVisibleOverlay...
INFO: Applying settings change to overlay CUserExtendedOverlay1...
INFO: Applying settings change to overlay CUserOverlay0...
INFO: Applying settings change to overlay CAudioFileManagerExtendedOverlay...
INFO: Applying settings change to overlay CVideoFileManagerOverlay...
INFO: Applying settings change to overlay CLaunchCastManagerExtendedOverlay...
INFO: Applying settings change to overlay CLaunchCastManagerOverlay...
INFO: Applying settings change to overlay CTVPropOverlay...
INFO: Applying settings change to overlay CHDRadioKeypadOverlay...
INFO: Applying settings change to overlay CUserExtendedOverlay8...
INFO: Applying settings change to overlay CUserOverlay8...
INFO: Applying settings change to overlay CVideoFileManagerExtendedOverlay...
INFO: Applying settings change to overlay CNAVCurrentDirectionOverlay...
INFO: Applying settings change to overlay CNAVViewListOverlay...
INFO: Applying settings change to overlay CVoiceInputModule...
INFO: Applying settings change to overlay CBluetoothActiveCallOverlay...
INFO: Applying settings change to overlay CUserOverlay1...
INFO: Applying settings change to overlay CUserExtendedOverlay0...
INFO: Applying settings change to overlay CMediaPlaySpeedOverlay...
INFO: Applying settings change to overlay CKeyPadLettersOverlay...
INFO: Applying settings change to overlay CNAVViewStatusOverlay...
INFO: Applying settings change to overlay CRearviewCameraOverlay...
INFO: Applying settings change to overlay CFullscreenVideoResumeInfoOverlay...
INFO: Applying settings change to overlay CRipMediaOverlay...
INFO: Applying settings change to overlay CUserOverlay9...
INFO: Applying settings change to overlay CTVManagerExtendedOverlay...
INFO: Applying settings change to overlay CNAVVirtualEarthOverlay...
INFO: Applying settings change to overlay CGirderModule...
INFO: Applying settings change to overlay CMusicLoadedOverlay...
INFO: Applying settings change to overlay CUserExtendedOverlay3...
INFO: Applying settings change to overlay CUserOverlay2...
INFO: Applying settings change to overlay CKeyPadWebOverlay...
INFO: Applying settings change to overlay CAudioFileManagerOverlay...
INFO: Applying settings change to overlay CXMRadioManagerExtendedOverlay...
INFO: Applying settings change to overlay CiPodManagerOverlay...
INFO: Applying settings change to overlay CVisAlbumArtOverlay...
INFO: Applying settings change to overlay CRelayModule...
INFO: Applying settings change to overlay CKeyPadAlwaysVisibleOverlay...
INFO: Applying settings change to media manager CDVDManager...
INFO: Applying settings change to media manager CiPodManager...
INFO: Applying settings change to media manager CLaunchCastManager...
INFO: Applying settings change to media manager CXMRadioManager...
INFO: Applying settings change to media manager CRadioManager...
INFO: Applying settings change to media manager CTVManager...
INFO: Applying settings change to media manager CVideoFileManager...
INFO: Applying settings change to media manager CAudioFileManager...
INFO: CAudioFileManager::OnSettingsChange - Could not set volume, audio interface has not been created yet!
INFO: Performing GPS Startup...
INFO: CNAVGPSController : COM port 9 opened successfully
INFO: THREAD ID:228 = CNAVGPSController::Thread
INFO: GPS Startup Completed
INFO: Finished Applying Settings
INFO: CUVAppData::OnSettingsChange - Done.
INFO: Performing CDVDManager startup...
INFO: Performing CiPodManager startup...
INFO: Performing CLaunchCastManager startup...
INFO: Performing CXMRadioManager startup...
INFO: Performing CRadioManager startup...
INFO: Performing CTVManager startup...
INFO: Performing CVideoFileManager startup...
INFO: Performing CAudioFileManager startup...
INFO: Performing CDVDManagerExtendedOverlay startup...
INFO: Performing CNAVScrollMapOverlay startup...
INFO: Performing CFullscreenTVOverlay startup...
INFO: Performing CFullscreenDVDOverlay startup...
INFO: Performing CFullscreenVideoStoppedInfoOverlay startup...
INFO: Performing CFullscreenVideoOverlay startup...
INFO: Performing CMuteOverlay startup...
INFO: Performing CUserOverlay3 startup...
INFO: Performing CUserExtendedOverlay2 startup...
INFO: Performing CTVManagerOverlay startup...
INFO: Performing FileOptionsOverlay startup...
INFO: Performing CKeyPadNumbersOverlay startup...
INFO: Performing CMultiMonEnabledOverlay startup...
INFO: Performing CComboSelectOverlay startup...
INFO: Performing CRearCameraPropOverlay startup...
INFO: Performing CFunctionNameOverlay startup...
INFO: Performing CUserExtendedOverlay5 startup...
INFO: Performing CWebServicesOverlay startup...
INFO: Performing CDVDTray startup...
INFO: Performing CTVChannelChangeOverlay startup...
INFO: Performing CListSearchOverlay startup...
INFO: Performing CUserOverlay4 startup...
INFO: Performing CiPodManagerExtendedOverlay startup...
INFO: Performing CNAVViewDirectionOverlay startup...
INFO: Performing CSafeModulesOverlay startup...
INFO: Performing CUserExtendedOverlay4 startup...
INFO: Performing CFullscreenVideoInfoOverlay startup...
INFO: Performing CSlideshowOverlay startup...
INFO: Performing CMediaChangeOverlay startup...
INFO: Performing CVolumeOverlay startup...
INFO: Performing CUserOverlay5 startup...
INFO: Performing CSatRadioTray startup...
INFO: Performing CXMRadioManagerOverlay startup...
INFO: Performing CNAVFullscreenOverlay startup...
INFO: Performing CBluetoothIncomingCallOverlay startup...
INFO: Performing CUserExtendedOverlay7 startup...
INFO: Performing CRadioManagerExtendedOverlay startup...
INFO: Performing CUserOverlay6 startup...
INFO: Performing CRadioManagerOverlay startup...
INFO: Performing CDVDManagerOverlay startup...
INFO: Performing CNAVClickedLocationOverlay startup...
INFO: Performing CLaunchCastLoadedOverlay startup...
INFO: Performing CUserExtendedOverlay6 startup...
INFO: Performing CMediaTimeOverlay startup...
INFO: Performing CVideoTray startup...
INFO: Performing CTVTray startup...
INFO: Performing CRadioTray startup...
INFO: Performing CLaunchCastTray startup...
INFO: Performing CNAVGPSTrackingOverlay startup...
INFO: Performing CNAVViewFullscreenOverlay startup...
INFO: Performing CVisTitleOverlay startup...
INFO: Performing CGestureModule startup...
INFO: Performing CBluetoothVoiceRecognitionOverlay startup...
INFO: Performing CUserOverlay7 startup...
INFO: Performing CMusicTray startup...
INFO: Performing CiPodMusicTray startup...
INFO: Performing CBluetoothConnectedOverlay startup...
INFO: Performing CUserExtendedOverlay9 startup...
INFO: Performing CNetworkCommOverlay startup...
INFO: THREAD ID:236 = CSenderThread::StaticSendingThread
INFO: THREAD ID:240 = CNetworkCommOverlay::StaticCheckInternetThread
INFO: Performing CAlwaysVisibleOverlay startup...
INFO: Performing CUserExtendedOverlay1 startup...
INFO: Performing CUserOverlay0 startup...
INFO: Performing CAudioFileManagerExtendedOverlay startup...
INFO: Performing CVideoFileManagerOverlay startup...
INFO: Performing CLaunchCastManagerExtendedOverlay startup...
INFO: Performing CLaunchCastManagerOverlay startup...
INFO: Performing CTVPropOverlay startup...
INFO: Performing CHDRadioKeypadOverlay startup...
INFO: Performing CUserExtendedOverlay8 startup...
INFO: Performing CUserOverlay8 startup...
INFO: Performing CVideoFileManagerExtendedOverlay startup...
INFO: Performing CNAVCurrentDirectionOverlay startup...
INFO: Performing CNAVViewListOverlay startup...
INFO: Performing CVoiceInputModule startup...
WARNING: CNetworkCommOverlay::CheckInternetThread - Ping - The requested name is valid and was found in the database, but it does not have the correct associated data being resolved for. (ERROR=0x00002afc)
INFO: Performing CBluetoothActiveCallOverlay startup...
INFO: Performing CUserOverlay1 startup...
INFO: Performing CUserExtendedOverlay0 startup...
INFO: Performing CMediaPlaySpeedOverlay startup...
INFO: Performing CKeyPadLettersOverlay startup...
INFO: Performing CNAVViewStatusOverlay startup...
INFO: Performing CRearviewCameraOverlay startup...
INFO: Performing CFullscreenVideoResumeInfoOverlay startup...
INFO: Performing CRipMediaOverlay startup...
INFO: Performing CUserOverlay9 startup...
INFO: Performing CTVManagerExtendedOverlay startup...
INFO: Performing CNAVVirtualEarthOverlay startup...
INFO: Performing CGirderModule startup...
INFO: Performing CMusicLoadedOverlay startup...
INFO: Performing CUserExtendedOverlay3 startup...
INFO: Performing CUserOverlay2 startup...
INFO: Performing CKeyPadWebOverlay startup...
INFO: Performing CAudioFileManagerOverlay startup...
INFO: Performing CXMRadioManagerExtendedOverlay startup...
INFO: Performing CiPodManagerOverlay startup...
INFO: Performing CVisAlbumArtOverlay startup...
INFO: Performing CRelayModule startup...
INFO: Performing CKeyPadAlwaysVisibleOverlay startup...
INFO: Performing CNAVFindResultsModule startup...
INFO: Performing CNAVFavoritesRenameModule startup...
INFO: Performing CNAVStreetSettingsModule startup...
INFO: Performing CNAVMapOnlyModule startup...
INFO: Performing CTVOptionsModule startup...
INFO: Performing CStartModule startup...
INFO: Performing CRipMediaTransferModule startup...
INFO: Performing CNetSyncSettingsModule startup...
WARNING: CNetSyncSettingsModule::OnStartup - Could not open sync settings file (C:\Documents and Settings\Administrator\My Documents\StreetDeck\NetSync.dat) to get encrypted password!
INFO: Performing CUserModule8 startup...
INFO: Performing CWSUserNameRenameModule startup...
INFO: Performing CRemoteMediaDestinationModule startup...
INFO: Performing CScriptRemoveModule startup...
INFO: Performing CNAVFindPlacesListModule startup...
INFO: Performing CFullScreenDVDModule startup...
INFO: Performing CLCPasswordRenameModule startup...
INFO: Performing CShutdownSettingsModule startup...
INFO: Performing CVolumeModule startup...
INFO: Performing CBluetoothSettingsModule startup...
INFO: Performing CBluetoothPairedDevicesModule startup...
INFO: Performing CNAVPOIModule startup...
INFO: Performing CDiagnosticsViewCodeModule startup...
INFO: Performing CHelpModule startup...
INFO: Performing CYahooSearchModule startup...
INFO: Performing CMediaDestinationRename startup...
INFO: Performing CRipMediaSettingsModule startup...
INFO: Performing CNetComputerBrowserModule startup...
INFO: Performing CBluetoothSendTonesModule startup...
INFO: Performing CBluetoothStartModule startup...
INFO: Performing CNAVShowRouteModule startup...
INFO: Performing CRipMediaPOIModule startup...
INFO: Performing CNAVMapModule startup...
INFO: Performing CFullScreenTVModule startup...
INFO: Performing CFullScreenVideoFileModule startup...
INFO: Performing CMusicVMODStartModule startup...
INFO: Performing CMusicArtistStringColModule startup...
INFO: Performing CMusicPlaylistModule startup...
INFO: Performing CGeneralSettingsModule startup...
INFO: Performing CRenameModule startup...
INFO: Performing CBluetoothPhoneBookEntryModule startup...
INFO: Performing CUserModule5 startup...
INFO: Performing CNAVFindPlaceModule startup...
INFO: Performing CNAVDBFindPlaceModule startup...
INFO: Performing CRearviewCameraModule startup...
INFO: Performing CRearviewCameraSettingsModule startup...
INFO: Performing CDVDSelectSubPictureStreamModule startup...
INFO: Performing CPictureSettingsModule startup...
INFO: Performing CMusicSelectFolderModule startup...
INFO: Performing CExternalAppsModule startup...
INFO: Performing CRelayPluginSettingsModule startup...
INFO: Performing CBluetoothImportBluetoothModule startup...
INFO: Performing CUserModule4 startup...
INFO: Performing CNAVSettingsModule startup...
INFO: Performing COBDIISettingsModule startup...
INFO: Performing CMusicPlaylistContentsModule startup...
INFO: Performing CMainSettingsModule startup...
INFO: Performing CSyncSourceModule startup...
INFO: Performing CMultiMonSettingsModule startup...
INFO: Performing CCalibrateDisplayModule startup...
INFO: Performing CStartupSettingsModuleWizard startup...
INFO: Performing CSystemRestoreModule startup...
INFO: Performing CBalanceFaderModule startup...
INFO: Performing CBluetoothPhoneBookModule startup...
INFO: Performing CBluetoothPairedDeviceStatusModule startup...
INFO: Performing CUserModule7 startup...
INFO: Performing CDiagnosticsModule startup...
INFO: Performing CXMRadioChooseStationsModule startup...
INFO: Performing CShutdownModule startup...
INFO: Performing CDisplaySettingsModule startup...
INFO: Performing CConfigureRelayPluginSettingsModule startup...
INFO: Performing CUserModule6 startup...
INFO: Performing CNAVRouteTypeModule startup...
INFO: Performing CHDRadioModule startup...
INFO: Performing CiPodModule startup...
INFO: Performing CRipMediaMusicModule startup...
INFO: Performing CMusicSettingsModule startup...
INFO: Performing CShortcutsModule startup...
INFO: Performing CChooseRelaysSettingsModule startup...
INFO: Performing CBluetoothImportModule startup...
INFO: Performing CUserModule1 startup...
INFO: Performing CNAVFindAddress startup...
INFO: Performing CVehicleModule startup...
INFO: Performing CDVDInfoModule startup...
INFO: Performing CVideoSettingsModule startup...
INFO: Performing CXMRadioSettingsModule startup...
INFO: Performing CVisualizationModule startup...
INFO: Performing CColorSettingsModule startup...
INFO: Performing CWMEqualizerModule startup...
INFO: Performing CBluetoothImportCSVModule startup...
INFO: Performing CUserModule0 startup...
INFO: Performing CPackageListModule startup...
INFO: Performing CVehicleSettingsModule startup...
INFO: Performing CDVDSelectAudioStreamModule startup...
INFO: Performing CXMRadioSettingsModuleWizard startup...
INFO: Performing CRadioSettingsModule startup...
INFO: Performing CSystemInformationModule startup...
INFO: Performing CKeyboardSettingsModule startup...
INFO: Performing CNetShareBrowserModule startup...
INFO: Performing CBluetoothVolumeModule startup...
INFO: Performing CBluetoothSettingsModuleWizard startup...
INFO: Performing CUserModule3 startup...
INFO: Performing CRipMediaVideosModule startup...
INFO: Performing CNAVFullScreenModule startup...
INFO: Performing CPicturesModule startup...
INFO: Performing CGirderPluginSettingsModule startup...
INFO: Performing CLCUserNameRenameModule startup...
INFO: Performing CAboutModule startup...
INFO: Performing CProcessShutdownModule startup...
INFO: Performing CSkinSettingsModule startup...
INFO: Performing CUserNameRenameModule startup...
INFO: Performing CFileSearchRenameModule startup...
INFO: Performing CBluetoothCallLogModule startup...
INFO: Performing CBluetoothMainModule startup...
INFO: Performing CUserModule2 startup...
INFO: Performing CAddPackageModule startup...
INFO: Performing CNAVCustomPOIModule startup...
INFO: Performing CLaunchCastFilterStationsModule startup...
INFO: Performing CMusicAlbumStringColModule startup...
INFO: Performing CVoiceInputSettingsModule startup...
INFO: Performing CBluetoothEditPhoneBookEntryModule startup...
INFO: Performing CConfigureRearviewCameraSettingsModule startup...
INFO: Performing CGirderSettingsModule startup...
INFO: Performing CLaunchCastModule startup...
INFO: Performing CMusicNowPlayingModule startup...
INFO: Performing CMusicSearchModule startup...
INFO: Performing CMusicSearchResultsModule startup...
INFO: Performing CSetTimeSettingsModule startup...
INFO: Performing CStartupSettingsModule startup...
INFO: Performing CFileSearchResultsModule startup...
INFO: Performing CGestureSettingsModule startup...
INFO: Performing CEnhancedAudioModule startup...
INFO: Performing CBluetoothPhoneStatusModule startup...
INFO: Performing CBluetoothPairingModule startup...
INFO: Performing CWebServicesSettingsModule startup...
INFO: Performing CScriptListModule startup...
INFO: Performing CUpdateListModule startup...
INFO: Performing CNAVSettingsModuleWizard startup...
INFO: Performing CNAVFindNearbyModule startup...
INFO: Performing CNAVStatusModule startup...
INFO: Performing CDVDOptionsModule startup...
INFO: Performing CLaunchCastSettingsModule startup...
INFO: Performing CInputOptionsSettingsModule startup...
INFO: Performing CMoveFileModule startup...
INFO: Performing CVehicleGraphOBDIIModule startup...
INFO: Performing CDVDSettingsModule startup...
INFO: Performing CMusicSongStringColModule startup...
INFO: Performing CMusicModule startup...
INFO: Performing CInputSettingsModule startup...
INFO: Performing CPasswordRenameModule startup...
INFO: Performing CConfigureRelaySetSettingsModule startup...
INFO: Performing CBluetoothActiveCallModule startup...
INFO: Performing CWSPasswordRenameModule startup...
INFO: Performing CNAVStartModule startup...
INFO: Performing CNAVFindLatLongModule startup...
INFO: Performing CNAVDirectionsModule startup...
INFO: Performing CXMRadioModule startup...
INFO: Performing CDisplaySettingsModuleWizard startup...
INFO: Performing CRipMediaSelectTypeModule startup...
INFO: Performing CRelaySettingsModule startup...
INFO: Performing CRelaySetSettingsModule startup...
INFO: Performing CGlyphSettingsModule startup...
INFO: Performing CAppSoundsModule startup...
INFO: Performing CBluetoothDialNumberModule startup...
INFO: Performing CRelayControlModule startup...
INFO: Performing CVideosModule startup...
INFO: Performing CSlideshowModule startup...
INFO: Performing CRipMediaPicturesModule startup...
INFO: Performing CXMRadioStationListModule startup...
INFO: Performing CXMRadioStatusModule startup...
INFO: Performing CLaunchCastStationGuideModule startup...
INFO: Performing CMusicStartModule startup...
INFO: Performing CMusicGenreStringColModule startup...
INFO: Performing CMusicArtistAlbumModule startup...
INFO: Performing CSimpleSettingsModule startup...
INFO: Performing CSetTimeSettingsModuleWizard startup...
INFO: Performing CRelayRenameModule startup...
INFO: Performing CBluetoothOptionsModule startup...
INFO: Performing CUserModule9 startup...
WARNING: CAppData::ShowWizards - Wizard module CConfigureRearviewCameraSettingsModuleWizard is not registered!
INFO: CDrawWnd::Create - Initialization completed!
INFO: CDrawWnd::Create - Program initialization completed in 20 seconds.
INFO: CUVAppData::OnDeviceChange - DeviceChangeEnd
INFO: CStreetDeckApp::InitInstance - Register All Started!
INFO: CStreetDeckApp::InitInstance - Register All Finished!
Aquaman
01-02-2008 12:15 PM
Hi Hawk909,
I had a similar problem. After updating to any version above 1.0.6.3, SD crashed, apparently when in the process of applying settings (at least the bottom status line displayed that message just before the crash.) I tried reinstalling SD from the DVD and updating from there to 1.1.1.0 (or any intermediate version) ... same results. What I did finally was:
0. Clean installation from SD DVD and updated to 1.1.1.0.
1. After the update, rebooted the system without restarting SD and removed the StreetDeck directory from My Documents.
2. Downloaded the 1.1.1.0 sdu file and reapplied it. The windows installer fired up and asked me for the SD software DVD. Mounted it and the update process continued.
3. Restarted SD and voila, it started and works like a charm.
Hope this helps.
hawk909
02-02-2008 08:22 PM
http://www.mp3car.com/vbulletin/stre...1-1-0-0-a.html
Since God of Cpu deceided this is Cannot Reproduce. I have tried to get hold of that poster but I haven't heard anything from him here.
Sponsored Links
The MP3car.com Store
SEO by vBSEO 3.1.0
Ad Management by RedTyger
