Properties
This is a Major Navigation Module Bug for 1.1.1.6 of StreetDeck Bug Reports
Assigned Unconfirmed to Unassigned
Sinabl
03-13-2008 09:07 PM
After having upgraded to 1.1.1.6, i've noticed that SD keeps crashing everytime i return from hibernate. When i come out of hibernate, there is a black screen with the mouse pointer being visible. Then after about 3-5 minutes, SD will shutdown and will show that mappoint has crashed.
When i restart SD, it spends forever (about 3 mins) in the "Applying Settings" phase.
Why??????? It used to run beautifully before i upgraded to 1.1.1.6. |
Sinabl
03-16-2008 11:15 AM
Check out Initialization Time.
INFO: ************************************************** ******************************
INFO: StreetDeck Application Data Log
INFO: Log started: Friday, March 14, 09:57 AM
INFO: Application Version: 1.1.1.6
INFO: Command Line: -testmode -routexmaudio
INFO: CMappointCtrl::GetClsid - Using StreetDeck control id
INFO:
OnPreCreate - Initialization time 0.109 / 0.109 seconds.
WARNING: UV_GetUpdateList - The system cannot find the path specified. (ERROR=0x00000003)
INFO:
Direct3DCreate9 - Initialization time 0.031 / 0.140 seconds.
INFO:
PreEnumerate - Initialization time 0.000 / 0.140 seconds.
INFO:
Enumerate - Initialization time 0.016 / 0.156 seconds.
INFO:
BrushCreate - Initialization time 0.000 / 0.156 seconds.
INFO:
RenderWindow PreCreate - Initialization time 0.000 / 0.156 seconds.
INFO:
RenderWindow Create - Initialization time 0.015 / 0.171 seconds.
INFO:
Init Loading Logo - Initialization time 0.000 / 0.171 seconds.
INFO: CUVAppData::OnCreate - Navigation controller successfully initialized!
INFO:
Window / Direct3D Create - Initialization time 0.000 / 0.171 seconds.
WARNING: CAuthorize::ReadPhysicalDriveInNTWithZeroRights - DeviceIOControl IOCTL_STORAGE_GET_MEDIA_SERIAL_NUMBER error = The request is not valid for this device.
INFO:
LoadRegInfo - Initialization time 0.016 / 0.187 seconds.
WARNING: UV_GetFileList - The system cannot find the file specified. (ERROR=0x00000002)
INFO:
Init Plugins - Initialization time 0.016 / 0.203 seconds.
INFO:
OneTimeDOne - Initialization time 0.015 / 0.218 seconds.
INFO:
OneTimeSceneInit - Initialization time 0.000 / 0.218 seconds.
INFO:
FindBestWindowedMode - Initialization time 0.000 / 0.218 seconds.
INFO: CDrawWnd::Initialize3DEnvironment...
INFO: CDrawWnd::Initialize3DEnvironment - Successfully created D3D device!
INFO: CRenderEngine::InitDeviceObjects...
INFO:
RenderEngine Init - Initialization time 0.157 / 0.375 seconds.
INFO:
PreInitDeviceObjects - Initialization time 0.062 / 0.437 seconds.
INFO:
StatsFont - Initialization time 0.016 / 0.453 seconds.
INFO: Initializing POI database...
WARNING: CSqlStatement::NextRow - Library used incorrectly
INFO:
OnInitDeviceObjects Start - Initialization time 0.172 / 0.625 seconds.
INFO:
Folder Init - Initialization time 0.140 / 0.765 seconds.
INFO: CSoundController::InitDeviceObjects...
SetFormat(hr=0x08887800INFO: Loading Textures...
INFO: CTextureBag::LoadTextures...
INFO:
Load Textures - Initialization time 0.078 / 0.843 seconds.
INFO:
Load Logo Texture - Initialization time 0.032 / 0.875 seconds.
INFO: Initializing Textures...
INFO:
Initialize Textures - Initialization time 0.000 / 0.875 seconds.
INFO: Initializing Speech Controller...
INFO:
Init Speech - Initialization time 0.000 / 0.875 seconds.
INFO: Initializing Media Event Processor...
INFO:
Init Media Event Processor - Initialization time 0.000 / 0.875 seconds.
INFO: Initializing Volume Control Textures...
INFO:
Init POI DB - Initialization time 0.000 / 0.875 seconds.
INFO:
Init Media Managers - Initialization time 0.000 / 0.875 seconds.
INFO:
Enumerate Apps - Initialization time 0.000 / 0.875 seconds.
INFO: CAppData::LoadSkin - Loading skin Default...
INFO: CAppData::LoadSkin - Loading skin C:\Documents and Settings\CARPC\My Documents\StreetDeck\UI\Skins\Default\Skin.skn...
WARNING: CAppData::SetSystemMetric - The specified skins system metric eSMListNAVDirectionYOffset, 700 is outside the bounds (Min:-500, Max:500) allowed by it. The default value of 0 will be used instead.
INFO: CAppData::LoadSkin - Finished loading skin...
INFO:
Load Skin - Initialization time 0.031 / 0.906 seconds.
INFO: CAppData::OnInitDeviceObjects - Skin successfully loaded!
INFO: CFontBag::InitDeviceObjects...
INFO:
Init FontBag - Initialization time 0.078 / 0.984 seconds.
INFO:
Overlays - Initialization time 0.031 / 1.015 seconds.
INFO:
User Overlays - Initialization time 0.000 / 1.015 seconds.
INFO:
User Modules - Initialization time 0.000 / 1.015 seconds.
INFO:
Volume Modules - Initialization time 0.047 / 1.062 seconds.
INFO:
Voice Modules - Initialization time 0.000 / 1.062 seconds.
INFO:
Relay Modules - Initialization time 0.063 / 1.125 seconds.
INFO:
MsgBox Modules - Initialization time 0.000 / 1.125 seconds.
INFO:
External Apps Modules - Initialization time 0.000 / 1.125 seconds.
INFO:
Tray Overlays - Initialization time 0.000 / 1.125 seconds.
INFO:
EQ Modules - Initialization time 0.000 / 1.125 seconds.
INFO:
General Modules - Initialization time 0.015 / 1.140 seconds.
INFO:
MultiMon Modules - Initialization time 0.000 / 1.140 seconds.
WARNING: CPluginBag::GetPlugin - LoadLibrary - The specified module could not be found. (ERROR=0x0000007e)
WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Documents and Settings\CARPC\My Documents\StreetDeck\Plugins\Input\InputG35SWC.dll )!
WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Documents and Settings\CARPC\My Documents\StreetDeck\Plugins\Input\InputPhidgetsEn coder.dll)!
WARNING: UV_GetFolderList - The system cannot find the path specified. (ERROR=0x00000003)
INFO:
Package Modules - Initialization time 0.125 / 1.265 seconds.
INFO:
Scripting Modules - Initialization time 0.000 / 1.265 seconds.
INFO:
Load Modules - Initialization time 0.000 / 1.265 seconds.
INFO:
CDVDManager - Initialization time 0.000 / 1.265 seconds.
INFO:
CiPodManager - Initialization time 0.000 / 1.265 seconds.
INFO:
CLaunchCastManager - Initialization time 0.000 / 1.265 seconds.
INFO:
CXMRadioManager - Initialization time 0.000 / 1.265 seconds.
INFO:
CRadioManager - Initialization time 0.000 / 1.265 seconds.
INFO:
CTVManager - Initialization time 0.000 / 1.265 seconds.
INFO:
CVideoFileManager - Initialization time 0.000 / 1.265 seconds.
INFO:
CAudioFileManager - Initialization time 0.000 / 1.265 seconds.
INFO:
Media Manager Ontime Scene Init - Initialization time 0.000 / 1.265 seconds.
INFO: CAppData::LoadXMLSettings - Loading XML Settings from C:\Documents and Settings\CARPC\My Documents\StreetDeck\config.xml...
INFO:
Create Class Enum - Initialization time 0.094 / 1.359 seconds.
INFO:
BindToStorage - Initialization time 0.000 / 1.359 seconds.
INFO:
GetDisplayName - Initialization time 0.000 / 1.359 seconds.
INFO: CGirderModule::OnLoadXMLConfig - No plugins were loaded from the girder plugin path!
WARNING: CRelayModule::OnLoadXMLConfig - No plugins were loaded from the Relay plugin path!
INFO:
Load Settings - Initialization time 0.000 / 1.359 seconds.
WARNING: CAppData::SortOverlays - Could not find overlay (CPanelChooserOverlay) to set Z-Order!
WARNING: CAppData::SortOverlays - Could not find overlay ({A42819EF-8B34-48C2-80CF-3B8754FD7F1B}\OverlayTest) to set Z-Order!
WARNING: CAppData::SortOverlays - Could not find overlay ({458E5981-B826-43C6-9D9C-C0C3D0C4EFBE}\ListenForFunctions) to set Z-Order!
WARNING: CAppData::SortOverlays - Could not find overlay ({DE5511FB-CE24-4CB8-8709-C5288EF3A2B9}\VoiceShowRecognitionOverlay) to set Z-Order!
INFO:
Init Skin - Initialization time 0.000 / 1.359 seconds.
INFO:
Overlay Scene Init - Initialization time 0.000 / 1.359 seconds.
INFO:
Module Scene Init - Initialization time 0.016 / 1.375 seconds.
INFO: CDrawWnd::RestoreDeviceObjects...
INFO: CDrawWnd::OnSettingsChange...
WARNING: .\VoiceInputModule.cpp:376 HRCALL Failed!
0x80040154 = hr = m_cpEngine->CreateRecoContext( &m_cpRecoCtxt )
INFO: CNAVGPSController : COM port 6 opened successfully
INFO: Performing CDVDManager startup...
INFO: Performing CiPodManager startup...
INFO: Performing CLaunchCastManager startup...
INFO: Performing CXMRadioManager startup...
INFO: Performing CRadioManager startup...
INFO: Performing CTVManager startup...
INFO: Performing CVideoFileManager startup...
INFO: Performing CAudioFileManager startup...
INFO: Message Box:
Initializing...
Please wait while the media player initializes.
WARNING: UV_GiveWritePermission - GetFileAttributes - The system cannot find the file specified. (ERROR=0x00000002)
WARNING: UV_DeleteFile - DeleteFile - The system cannot find the file specified. (ERROR=0x00000002)
WARNING: UV_DeleteFile - Failed to delete file (C:\Documents and Settings\CARPC\My Documents\StreetDeck\wplB.tmp)!
INFO: Message Box:
TestMode Detected, Continue?
DO NOT OPERATE A VEHICLE WHILE IN TESTMODE. Testmode compromises the safety features. Click yes only if you are running outside a vehicle environment.
WARNING: CNetSyncSettingsModule::OnStartup - Could not open sync settings file (C:\Documents and Settings\CARPC\My Documents\StreetDeck\NetSync.dat) to get encrypted password!
INFO: CMediaEventProcessor::MuteMedia - Unmute Media (0x1), (Combinded: 0x0)
INFO: CDrawWnd::Create - Initialization completed!
INFO: CDrawWnd::Create - Program initialization completed in 10 seconds.
INFO: CStreetDeckApp::InitInstance - Register All Started!
INFO: Loading Sounds...
INFO: CSoundController::LoadSounds...
INFO: CStreetDeckApp::InitInstance - Register All Finished!
INFO: Message Box:
Initializing...
Please wait while navigation initializes.
INFO: CAppData::SaveXMLSettings - Saving XML Settings...
WARNING: UV_DeleteFile - Failed to delete file (C:\Documents and Settings\CARPC\My Documents\StreetDeck\wplE.tmp)!
INFO: CProcessShutdownModule::Exit - The initial shutdown sequence has completed processing. (Shutdown Option = 0)
INFO: Peforming NAV Shutdown...
INFO: Performing XM Shutdown...
INFO: CAppData::PerformShutdown - Shutdown complete!
INFO:
Create Class Enum - Initialization time 2150.406 / 2151.781 seconds.
INFO:
BindToStorage - Initialization time 0.000 / 2151.781 seconds.
INFO:
GetDisplayName - Initialization time 0.000 / 2151.781 seconds.
0x8004503a = hr = m_cpEngine->CreateRecoContext( &m_cpRecoCtxt )
INFO: Performing CAudioFileManager startup... |
Sinabl
03-16-2008 09:25 PM
| I fixed the problem. All i had to do was tell SD to reindex the music. I guess the music database somehow had gotten corrupted earlier. |
