Go Back   MP3Car.com > Mp3Car Technical > Car Audio > Car Audio FAQ
Old 08-20-2008, 11:43 PM   #1
stonestatue's Avatar
stonestatue is on a distinguished road
Optimum connection from car pc to amp.
I intend to go headless and run my car pc directly to my speakers through a 41hz.com amp 9 kit.
I have read this thread and have determined that it says to essentially splice the output of the green jack on the sound card to each input on the amp.
The particular question I had was how many channels it sends out that way. I was wanting to support as many channel outputs as mp3 files would put out. If it puts out two channels, would the green audio jack put out two channels? If so, how? I was thinking that each channel would need its own jack.
The reason I am contemplating all this is because of all the hype over 5.1 surround. After doing some research, I have concluded that mp3 files most commonly put out two channels (stereo)(somebody correct me if I'm wrong), so it wouldn't really be necessary to accommodate more than two channels, since the mp3 files would only be sending out two channels anyway.
To sum up, how do I take advantage of the two channels sent out by the mp3 files? Do I need a sound card one jack per channel, or will a standard three jack on board audio from the motherboard work?
Self proclaimed environmentalist.
stonestatue is offline   Reply With Quote
Old 08-21-2008, 01:22 AM   #2
Oops, I accidentally posted this twice. Some mod, please delete this.
Old 08-21-2008, 01:31 AM   #3
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
I deleted your other thread.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 08-21-2008, 01:49 AM   #4
greatwhite's Avatar
greatwhite is an unknown quantity at this point
I run front sound stage only, essentially 2.1 sound. I use an Audigy 4 card and only make use of the front outs (well rears actually, as I use KXdrivers which swaps the outputs to take advantage of ac97) and the subwoofer channel.
I've heard (had) 5.1 in the car, it just doesn't seem to sound as good as a 2.1 setup (to me at least, in a car enviroment). Unless you're watching dvd's, I personally don't see a great need for 5.1 in the car. I listen to music when driving and I want the sound stage in front of me like at a concert.
2.1 gives me this. "I don't go to a concert and turn my back to the stage" is the concept here.
I am, however, considering installing a couple rear drivers to give a little "fill", but I'm not completely sold on that yet.
Personal choice rules here when considering 5.1/7.1/4.1/2.1 etc...........
Keep in mind, if you're using "downloaded" Mp3's, they're usually low quality stuff (low bitrate) anyways. Flac for me!
A decent sound card (most on board chips as well) will have at least a left and right channel from the front and/or rear output. Just grad a decent 3.5mm to RCA cable and you're "good to go"..............
Good luck.
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 08-21-2008, 01:54 AM   #5
Thanks for the reply and thanks for deleting the thread.
What about the sub(s)? Does that need a separate channel itself or can it utilize the left channel (or right channel) as I have read?
Old 08-21-2008, 02:02 AM   #6
greatwhite's Avatar
Sorry, can't help you there..............don't know.
As I stated above, I use the sub-out channel on my card.
Cheers
Leonardo Da Vinci
what type of amp for my car pc.. tanners Car Audio 3 04-18-2007 02:53 PM
Car PC & Bose/Philips CCR800 Aux input Gamer64 Car Audio 1 01-25-2007 04:13 PM
Installing car PC in 1996 Honda Civic PredatorCoder Newbie 8 08-18-2005 08:58 AM
