The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Car Audio > Car Audio FAQ
Thread Tools Display Modes
Old 01-17-2005, 11:02 AM   #16
IntellaWorks's Avatar
Vehicle: 2005 Toyota Tacoma
My Photos: (0)
I'm also now curious about software enhancement, using a PC you could EASILY grab the data from the CD drive and enhance the audio "on the fly" and play the enhanced media off the hardrive while the pc's ripping and enhancing the media from the CD...
You'd have to look at special codec's that are able to improve media from it's original bitrate... but I'm sure there are noise reduction and clearity increasing alogrithims in these codecs already built in. Which you can then apply to say the competetion CD and further enhance that media through software...
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Sponsored Links
Old 01-17-2005, 11:24 AM   #17
emdzey01's Avatar
Vehicle: BMW e39, Acura NSX up next
My Photos: (0)
thanks for your input
thanks guys, im surprised on your opinions and i'm surprised how everyone got into the act...
so yes, i'm joining a car show here in the philippines, and it's basically an all around event (best in paint, best of show, best sound quality, etc.) i would think that we have a shot at best of show, best in paint and best european car, i'm just considering if we have a shot at best sq (i'm in charge of the car's carputer project)..
so here's the thing.. the sound card i'll be using would be a sound blaster digital music, and i've checked and it processes audio at 16-bit, so i guess i'm pretty much done if they're gonna be using a 24-bit encoded cd..
ok so we've already concluded that a carputer can compete with a head unit, provided that a good sound processor is used... so what sound card would be best for competing in an sq event?
emdzey01 is offline   Reply With Quote
Old 01-17-2005, 11:51 AM   #18
My Photos: (0)
Quote: Originally Posted by Red GTi VR6
the CDs that are used in USACi are recorded in 24 bit, most cds are recorded in 16 bit.
i'm not aware of any recording studio that samples at only 16 bits these days; many people are moving to recording directly to computer, so record at whatever rate they chose. previously, DAT at 24 bit was the medium of choice for pros. no matter what the source, it always gets downsampled to 16 bit for an audio cd (it's in the cd spec).
edscholl is offline   Reply With Quote
Old 01-17-2005, 12:09 PM   #19
My Photos: (0)
Assuming your pc has an Open PCI slow Sound Blaster Audiology is a really great card.. but you can do the searching on your own. I suggest at least a 24Bit Sound card with RCA outs. Expect to spend anywhere from 40-100 dollers... I search brielfy but didn't find a card with your needs... You dont need a game port or any of the phone anwsering cabailities.. Just something simple with Dolby digital 5.1 RCA's and 24 bit sound..
Good luck !
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 01-17-2005, 12:43 PM   #20
Vehicle: Bravada - Triplet
My Photos: (0)
IntellaWorks: I am not sure I understand you correctly when you say "on the fly" and "play off the HD", all I know is, in competition, you have to play in real time, meaning, the judge would insert the CD and hit "play", you can't pre-can the CD. Now, your "play" button could do all sort of things, but it must play in real time.
emdzey01: I don't know much about your setup, but, if you have a PCI slot, then you have a lot more options as far as sound cards, if OTOH you are limited to USB input, then try to look at M-Audio USB device, similar to that of SB Audigy, if you can afford it, get both of them and compare the quality, I know for sure that M-Audio has less sampling issues than SB but I am not sure if that is across their entire product line. Again, read as much as you can about M-Audio & SB over that site I mentioned above.
kingtut is offline   Reply With Quote
Sponsored Links
Old 01-17-2005, 01:17 PM   #21
My Photos: (0)
Kingtut: Let me clarify what was thinking. Judge puts in a cd and clicks play, your play button then "on the fly" (programming expression which means no inturuptions, or in real time) Takes the CD media and runs it through an audio codec that can enhance the audio further. Say, by converting the audio into AC3 (if your audio system is set up with a center channel for dolby digital) . While It's converting the audio it can also play what it has converted. (depending on the media you are converting it to) This is all happening in real time behind the scene. Instead of playing the song from the CD its actually playing the rip (from the HD)
I use this now in my car system, If I play an audio CD my puter is actually ripping the song as I play it and compressing it to .mp3... It's also actually playing from the HD instead of the CD. I can get away with this because .mp3 allows you to play the file even though it's unfinished, compression takes only a few seconds per song, the duration it takes for the song to be compressec will never exceed the duration of the song.
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 01-17-2005, 05:41 PM   #22
My Photos: (0)
Interesting idea, I'll do some research on the subject.
Old 01-17-2005, 06:49 PM   #23
My Photos: (0)
Quote: Originally Posted by edscholl
as i said, exactly how much processing do you think you need? it ain't a whole lot if you want to reproduce accurate sound, versus process the sound to make it sound different than the original source. this is because the information (imaging, sound stage, etc) you're using needs limited processing to begin with- it's simply included in the source.
Well, that's the point. A good HU these days does much more than "reproduce accurate sound." It's easy to play a source and make it come out of speakers, the trick is to come as close as possible to making a ridiculously imperfect accoustic evironment (your car) sound as close as possible to a recording studio. Processing power can help.
This is also complicated by the fact that most cars are space limited (like my S2000) so it is not possible to design the kind of loudspeakers you would use in a lager space. Heck, you end up using your doors for speakers in most cars. If your space-limited speakers don't reproduce all frequencies perfectly (and they don't) you need to "process" the sound with an equalizer to compensate for those imperfections.
In cars you also have the problem of reflections and resonance, and further processing can help compensate for that as well.
My Alpine HU has a parametric equalizer, electronic crossovers, and six position time correction. That is "processing" beyond simple playback, and those are things to make the sound sound better in a less-than-perfect environment.
I always used to "center the sound" using the Balance and Fader controls. I had no idea what I was missing until I experienced Time Correction in a car (The proper way to balance sound is with both Time Delay AND Balance/Fader--you want the speakers that are NOT equidistant from your head to SOUND like they are equidistant.)
I think computers have MUCH more capacity to process music than a HU. I think the main limitation will be software, and the expense of good software. To be honest I don't know what all is out there but there are a lot of audio hobbiests and musicians. Combine that with academia and maybe there is some good free or low-cost audio software out there...
And yes, try to go USB with your soundcard. From what I have read it is far better to remove all analog portions of the sound from the noisy electrical environment of the computer. Digital signals are FAR less susceptible to picking up audible noise than analog signals, so keep everything digital inside the computer box, and have the external USB DA converter make it analog just before it enters your amp or preamp.
M-Audio makes some great external audio solutions, (I have the M-Audio Transit and I love it.)
Many computer soundcards are analyzed these days with RightMark Audio Analyzer, a free software package LINK TO FREE SOFTWARE . There is some excellent info at that site, and the user forums have a wealth of knowledge and many reviews.
Good luck!
LATEOTT is offline   Reply With Quote
Old 01-17-2005, 07:11 PM   #24
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
Vehicle: 1995 Lexus SC300 1997 Mazda Miata
My Photos: (0)
You can do all this with the kXProject for creative sounds cards. No USB support though. I wouldn't want to hog the USB bus anyway with audio.
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 01-17-2005, 07:25 PM   #25
My Photos: (0)
Thanks for the link, I'll check it out though it wouldn't work with any of my cards if it is Creative only.
Hog the USB bus??? You know you can actually do video through your USB bus, I think that is more likely to fill USB bandwidth...although from most reports it is electron sucking that is the biggest problem. However, I have never heard of USB soundcards "taking over the USB" and that is not my experience.
Another pleasant development is that modern MoBo chipsets leave the chipset southbridge to handle USB<-->RAM duties so CPU cycles are spared for more important things. What exactly are you saving your USB bandwidth for?
EDIT: And now that I think of it, don't we use USB 2.0 for things like wireless networking, ethernet, video capture, and DVD writing these days??? I hardly think audio is gonna "hog" the interface.
Old 01-17-2005, 07:31 PM   #26
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
I'm one of those people who wouldn't do audio over USB. I looked hard for my 1/8" mic just to avoid it being USB.
Anyway, check out the kXProject. Those are the professional drivers for creative PCI cards.
GammaControl v2.4
SKINbedder v3
Old 01-17-2005, 07:40 PM   #27
My Photos: (0)
To each his own. I actually went to USB because I had no Line-In on my laptop. Now I have that along with optical in/out.
I can see how that might not be an issue with a purpose-built PC. But again, from the tests and reviews I have studied, sound quality is better with external audio devices.
Thanks again for the link.
Old 01-17-2005, 07:48 PM   #28
dingofarmer's Avatar
Vehicle: 1999 Prelude S Spec
My Photos: (0)
I have the M-Audio Sonica, great card, I was running digital, but now am running anolog. Anolog sounds just as clear as the dig did. My prelude is small and my Primeir dex-p1r has time alignment in pro mode, I think I'll flip the Pro switch, get a tape measure and set up the alignment. The Usb do a good job and hogging up some resources, but as long as you have a quick pro, I don't think it would be a problem.
dingofarmer is offline   Reply With Quote
Old 01-17-2005, 07:54 PM   #29
My Village Called
0l33l's CarPC Specs
0l33l's Avatar
My Photos: (0)
Yeh, to each his own. But USB takes more CPU time
Have fun studing the kx project drivers. These drivers give full control over kX based cards. I beleive that they give you more control than the m-audio cards.
GammaControl v2.4
SKINbedder v3
Old 01-17-2005, 09:21 PM   #30
My Photos: (0)
that is absolutely NOT the point if you're into SQ! SQ, from a purely technical perspective, is ALL about accurately reproducing the sound of your source.
Sponsored Links
vB code is On
Trackbacks are Off
Recommendations on head unit or amplifier? (for use with a PC in the car) sofakng Car Audio 15 02-14-2006 11:50 PM
Alternate locations for head unit? Raekwon General MP3Car Discussion 13 04-09-2003 03:02 PM
Anyone using a Clarion DX515/db head unit or know if it will work for my carputer? wysiwyg General Hardware Discussion 0 01-06-2003 01:35 AM
Slot load dvd in a head unit mp3truckstereo General Hardware Discussion 1 09-01-2002 10:17 PM
Anyone using an FM tuner on their carputer instead of a head unit? Szech General Hardware Discussion 2 02-14-2001 02:07 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
