The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Car Audio > Car Audio FAQ
Thread Tools Display Modes
Old 05-06-2006, 09:28 AM   #61
JasonWW's CarPC Specs
Vehicle: 99 Trans Am
My Photos: (0)
I promised someone a few months ago I'd have some pics of my H700 controller and here they finally are. The H700 is green and orange. The 6 green chicklets buttons on the left are actually bulbs not LED's and have green gelcaps over them. I think they would be easy to change color.
I'm still trying to find a way to change the volume with a button. Anyone know about these rotary encoder things Alpine used?
1999 Black Pontiac Trans Am
CarPC's in F-bodies
How to tune your sound system
How To Relocate Climate Controls on the 97-02 F-body Cars
(AMD Sempron 3000+, Opus 150)
Car PC system is out, Alpine system is in.
JasonWW is offline   Reply With Quote
Sponsored Links
Old 06-01-2006, 06:05 PM   #62
kujosan's Avatar
My Photos: (0)
To those using an optical cable from the computer to the H70X:
When playing stereo music (winamp, RR, CF, etc...) does the music get upmixed to 5.1 and played across all 5.1 speakers? If so what does the upmixing, the soundcard, or the H70X ? Is one soundcard better than another in terms of optical out?
Thanks!
kujosan is offline   Reply With Quote
Old 06-01-2006, 06:07 PM   #63
3onDubs's Avatar
Vehicle: 2004/BMW/325i
My Photos: (0)
The H701 does the upmixing and all of the sound processing
There is nothing better than the H701 (for the price).
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 06-01-2006, 07:13 PM   #64
My Photos: (0)
Some sound cards CAN upmix it, but it may use too many resources or too many CPU cycles which could slow the computer. There's not much point though. The H70X can upmix stereo using the Dolby Digital technology, so that's the better way to do it.
On 5.1 music or soundtracks you can use a player like Power DVD and set it to output 5.1 and it will.
On different soundcards, some have better S/N ratios than others, some have higher sampling rates and there are a few other little things, but overall, the digital outputs are going to sound much better than the soundcards D/A converters analog out. With analog outputs there are many more differences as far as sound quality. Digital tends to reduce those differences. Try a $30 Chaintech AV-710 for starters. You can try more expensive cards if you want, but the AV-710 sounds real sweet, plus it can hibernate well if you use that feature on yor PC.
CarPC's in F-bodies
Old 06-13-2006, 02:56 PM   #65
My Photos: (0)
701 Problems
Hello,
I am new to the forum, but have the 701, 310 and 701 controller. The problem that I have is when playing DVD's, the audio output is significantly reduced as compared to any other media source. There is a single optical output from the 310 to the 701 and of course the AI-Net connection. If you mess with the levels enough, it comes out to be almost 10dB difference in output. (digital is that much less) Have any of you experienced this and if so, what have you done to alleviate the problem?
Thanks,
-RW
RyanW is offline   Reply With Quote
Old 06-13-2006, 03:16 PM   #66
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
first off welcome RyanW
what is the 310? is it the IVA-310?
I've not experienced this problem. It seems to lean more towards a windows setting, but I'm not sure.
Have you tried messing with all of the volumes on the computer? I'm sure you have, I just want to check first.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 06-13-2006, 03:32 PM   #67
My Photos: (0)
Yes, the IVA-D310. I am not currently using a laptop to "feed" the 701, but I noticed a discussion on here regarding some of the issues, so I thought this may be a good place to ask.
-Ryan
Old 06-13-2006, 03:47 PM   #68
_
My Photos: (73)
there should be a function to increase that sound level in the head unit. you might need to scroll through the menus, etc to find it.
Also, one thing to consider is that many times DVDs are quieter because of the dynamic range of movies.
music is fairly constant in volume, while movies are in quite the extremes. the compression comes into play here too.
Jan Bennett
Old 06-13-2006, 03:55 PM   #69
My Photos: (0)
I have literally been through each option an the bottom line is the DVD output (either in DTS or Dolby Digital) is about 10db less than PCM output. You can have a DVD playing and switch between PCM and Dolby Digital while a song is playing and it will sound great in PCM mode and be inaudible in DD mode. This is with everything set equal on the levels. Even when you "boost" the DVD levels through the roof and reduce PCM levels down low, they are only getting "close", but the digital signal completely lacks low end. Weird stuff.
-Ryan
Old 06-13-2006, 04:00 PM   #70
_
My Photos: (73)
very strange indeed, I'm running the optic signal from PC to 701 the analog to amps and I've not noticed this.
Did you install this unit on your own or did you have someone install it?
Jan Bennett
Sponsored Links
Old 06-13-2006, 04:19 PM   #71
My Photos: (0)
I am going to try a different source unit to isolate the problem in either the head unit or the processor. I did install it myself... and I work for one of the major car audio manufacturers, so expertise is abundant around here. Unfortunately no one around here uses this product. The best info always comes from those out in the field who are using the product anyway!
-Ryan
Old 06-13-2006, 04:22 PM   #72
_
My Photos: (73)
reallllly
which manufacturer might that be?
I'm guessing it's not sony/pioneer/kenwood/etc since you're running the alpine HU...so a manufacturer who doesn't make a HU then....
hrmmmmm
hehehe
Jan Bennett
Old 06-13-2006, 04:32 PM   #73
Laptop, Tablets, UMPC Moderator
turbocad6's CarPC Specs
turbocad6's Avatar
Vehicle: 2002 pontiac montana
My Photos: (71)
I have the 300, which is the one before the 301, it has the same problem...
everything else I set to max out at like 21 & the dvd's will push the same volume at like 29..... there all like this... I think it has to do with the dolby...
MY NEWEST INSTALL:modded infiniti fx with big screen - "If my typing sucks it's probably because I'm driving....................."
turbocad6 is offline   Reply With Quote
Old 06-13-2006, 04:41 PM   #74
_
My Photos: (73)
and you haven't found ANYTHING to solve this problem turbo?
Jan Bennett
Old 06-13-2006, 04:42 PM   #75
My Photos: (0)
Turbo- exactly. This may just be "one of those things". I will do some testing later this week and see what we come up with.
VR6- straight north of you about 250 miles. That is all that I can say.
-Ryan
Sponsored Links
vB code is On
Trackbacks are Off
can a carputer replace a high end av dedicated system? turbocad6 Car Audio 85 07-09-2007 04:44 AM
alpine skin questions hakhawk RR Skins 10 07-04-2005 05:48 PM
MP3 --> ALPINE head unit questions WozzaWozza Car Audio 12 06-09-2005 10:46 AM
FS: Alpine Amps, Subs, 6.5" Monitors coachreed Classified Archive 0 04-03-2005 01:13 PM
Alpine / PC Challenges all around... acitrano General Hardware Discussion 5 11-10-2000 07:45 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
