The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Car Audio > Car Audio FAQ
Thread Tools Display Modes
Old 07-14-2006, 03:50 PM   #31
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
so the USB sound card has absolutely no power coming to it other than from the USB?
do you have a link to the card (or a model number) that you are using?
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
Old 07-14-2006, 03:55 PM   #32
Vehicle: 2006 Nissan Pathfinder
My Photos: (0)
That's right, the sound card is only powered by USB.
Here is the link http://www.turtlebeach.com/site/prod...dioadv/roadie/
j0hn is offline   Reply With Quote
Old 07-14-2006, 08:58 PM   #33
Vehicle: 04 Honda Element
My Photos: (0)
Quote: Originally Posted by Red GTi VR6
Will -
I've yet to hear of anyone implementing an iPOD in their car and it sound worth a damn, have you?
Nope, and I own a couple. Worthless PoS
Will Albers is offline   Reply With Quote
Old 07-14-2006, 09:03 PM   #34
My Photos: (0)
Im not sure where to begin here. Could be induced noise, could be ground loop.
Have you tried grounding the chassis of the USB sound card? Might be able to ground the power wire (-) of the USB sound card. I cut out my USB sound card because of weird issues like this. Do you hear the static if you plug in a pair of headphones?
What does the internal sound card sound like?
Old 07-15-2006, 01:46 PM   #35
My Photos: (0)
I was worried that the problem might be too goofy to fix. The internal sound card isn't working now, but I haven't messed with it much. I do hear static if I plug in headphones. Identical to the static I hear on the speakers. I will try grounding the USB ground wire to the chassis later today...couldn't hurt.
Old 07-16-2006, 12:33 AM   #36
My Photos: (0)
Well thats your first clue. This is before and has nothing to do with your amp. Lets work on the pc/sound card. Try the grouning of the sounc card chassis.
Old 07-17-2006, 08:39 AM   #37
My Photos: (0)
So I grounded the USB to the chassis and it got rid of the constant static. Now I get more of a popping sound when the bass hits or when the music gets louder. Almost sounds like speaker problems. Will get my headphones from the office and try those out today to see if I get the same thing.
Thanks for your help.
Old 07-17-2006, 09:08 AM   #38
_
My Photos: (73)
have you tuned your system yet?
that could be the sound of your system not being properly tuned thus causing distortion.
http://www.350z-tech.com/zwiki/Tutor...plifier_Tuning
Follow that guide and let us know.
Jan Bennett
Old 07-17-2006, 10:02 PM   #39
My Photos: (0)
cheap pac ground loop isolator connects to output rca jacks for h/u or pc and connects go the inputs from the amp and the the other 2 wires to ground that solves what i like to call the little bird inside the car noise
p&gcustoms is offline   Reply With Quote
Old 07-18-2006, 08:35 AM   #40
My Photos: (0)
I did get a chance to try out the headphones and I get the same thing so it is still between the sound card and the amp. I will get a ground loop isolator and try it out. Anywhere local to get one of those or just order online?
Sponsored Links
Old 07-18-2006, 12:49 PM   #41
My Photos: (0)
If it happens on head phones it is NOT, i repeat NOT, a ground loop between your sound card and amp. The ground loop isolater is not the solution.
You are getting a ground loop between your PC/Sound card and inverter. Ignore all other components. Use headphones as much as possible.
This is what I would try: Ground the cassis of the inverter to the same point you ground the PC. Ground the Chassis of the sound card and chassis of PC to the same point. Ground the USB cable (if possible) to the same point. If you still get popping through the HEADPHONES, i would bet its an issue of inverter quality. Look into a DC to DC power supply to solve your headaches.
There may not be an easy solution to the problem. Again, these components are never designed for automotive use. Its not that the devices are bad, just not designed for what you are trying to do.
Old 07-18-2006, 02:01 PM   #42
My Photos: (0)
Thanks for pointing that out. I suppose I didn't think that through.
Now, since I am using a laptop in a docking station plugged into an inverter, I should just have to ground the inverter to the chassis, correct?
Components not designed for automotive use...what were they thinking?
Old 07-18-2006, 02:34 PM   #43
My Photos: (0)
Carnetix make a 1900 DC-DC power supply. I would bet you can get it to work on your setup really well. It may eliminate a lot of your problems.
Now as far as your question goes, im not sure what you are asking. What i was implying is you want to ground the chassis of all of your components (The metal box surrounding the guts) to the same place where you ground the actual power flow. Its way overkill, but its a simple enough thing to do and can help out in these strange situations. If it works, start removing them and find out where it suddenly kicks back in. That was your problem source.
Anyways, check your power supply of the laptop. If its 19volts output or lower, you can usually modifiy the carnetix 1900 to power the unit perfectly, plus you get to eliminate the inverters. It will even give you shut down controller and 5v source! Look on the classified section to find em less than $100
Good luck
Old 07-18-2006, 08:43 PM   #44
My Photos: (0)
yes me im on lawndale between wayside and telephone i could help u out with that prob
Old 07-19-2006, 04:11 PM   #45
My Photos: (0)
Thumbs up
Hi Will
just wanted to thank you for that thread - it really helped me to eliminate the data-noise i had on my system - which was caused by bad ground cable and/or the stock grounding point was on a piece of metal, which was tacked to the rest of the car
The only noise i have left now is a little whinening where the frequency depends on the engine revs. But that might be my dc-dc inverter which isn't inverting any more (yeah i did a shortcut on the output *doh*) ...
Thanks - this was really the best explaination i have found on the internet so far :-)
Best regards,
Søren
soerenkroeger is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
I tried everything, can't get rid of this ground loop intense General Hardware Discussion 3 07-10-2005 08:58 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
