Go Back   MP3Car.com > Mp3Car Technical > Car Audio > Car Audio FAQ
Old 07-28-2006, 11:55 AM   #61
nemo1's Avatar
nemo1 is on a distinguished road
Nomader,
I have tried to ground them together but failed. The noise is still there, maybe I have grounded the wrong wire. From your diagram part C is different from mine, so I just find the only black cable and ground it to the same point as I did for CPU case. Could it be the grounding of the case is not good enough that is causing the problem. After that I used the isolator and the sound goes away.
When I increase the volume from the HU, seems like the volume level is unchanged. If I have input to the HU thru AUX, shouldn't the volume increase when I increase volume of HU? I have connected output of sound card to the female RCA of my HU. There is another stereo like mini jack, don't know what is it for and should I connect output to that input.
I can't find the manual for my HU. Model is HEIDELBERG CM127, only found HEIDELBERG CD
Please Help
Please Help.
nemo1 is offline   Reply With Quote
Old 07-29-2006, 10:47 AM   #62
Nomader's Avatar
Nomader is on a distinguished road
when you use the Aux in of the HU the volume should increase.. have not seen that before. the mini jack should be the AUX in.. i think the RCA are the low level OUT to output sound to go to an amplifier.. try the mini jack.. but strangely you have sound when you use the rca??!!
Nomader is offline   Reply With Quote
Old 07-29-2006, 06:31 PM   #63
Nomader's Avatar
another thing i noticed is that you should place your ground loop isolator as far as possible from the HU and the PC.. whenever it comes within a distance of 30-40 cm to either of them it starts to bring noise!!!
today i removed the hard disk noise from my setup... don't ask me how but I just muted the CD volume knob in windows volume control!!!! now no more Hard disk noise as well
Old 07-30-2006, 08:14 AM   #64
nemo1's Avatar
Using the mini jack gives very low volume. Using the RCA and the sound level is high.
I have found the ground wire for my HU, connect it to where I ground my PC casing and the noise goes away but not all of them. I have also noticed that using the ground loop isolator actually decreases the sound level.
The noise is still there although suppressed a lot. How can I reduce it even more? Could it be the grounding of the components in my PC. I have to make sure a good contact for all the components to CPU casing right?
Nomader how do you find out noise is coming from hard disk? I would like to try on mine setup.
Thanks!!
Old 07-30-2006, 11:21 AM   #65
Nomader's Avatar
Thanks!!
hard disk noise is different.. it sounds just like a hard disk spinning but loud it is not a buzzing sound or a whine.. it is audible when the hard disk is spinning.. try to do a large file copy and see if the noise is introduced.
Old 08-03-2006, 01:33 PM   #66
Silverado3030 is on a distinguished road
Hey you all ..........same problem here F..noise..... mine is horrible..when I'm playing videos/musci tracks the 2/3 second interval going to next song sounds like an avalanch of rocks...does this thing works???? http://www.crutchfield.com/S-zycTnNt...se&i=127SNI135..........
Silverado3030 is offline   Reply With Quote
Old 08-03-2006, 07:59 PM   #67
Will Albers is on a distinguished road
Did you follow any of the steps in the first post?
Will Albers is offline   Reply With Quote
Old 08-12-2006, 02:37 PM   #68
Moridin is an unknown quantity at this point
I have to say guys...FORGET THE iPod!!!!!!!!! I bought a Creative Zen Vision:M and I tell you...sound/image quality (plays movies as well) is absolutely amazing! I bought a Boss HU, installed it, plugged in my Zen and away I went.
Again,
FORGET IPOD!
GO CREATIVE!!!
Moridin
Moridin is offline   Reply With Quote
Old 08-12-2006, 07:10 PM   #69
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
How can you tell any difference when you're using it on a boss hu?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 08-12-2006, 11:37 PM   #70
Old 08-13-2006, 05:32 AM   #71
Nomader's Avatar
exactly..!!
most probably it is the new HU.
Old 08-13-2006, 05:43 AM   #72
what are you guys trying to say...the Boss is not a good HU? Sounds better than my previous JVC!
Old 08-13-2006, 09:43 AM   #73
Nomader's Avatar
no we are saying that u can not actually be sure if it was the ipod for u to blame or your previous HU.
Old 08-13-2006, 09:54 AM   #74
_
no - I'm saying that Boss is NOT a good head unit...neither is JVC...
Jan Bennett
Old 08-13-2006, 11:07 AM   #75
Can you explain your opinion? I know it's no where close to competition level hardware so what makes it so bad?
To clarify my first statement:
My wife has a brand new 60GB ipod video and when I compare it to my creative...its night and day. whether it's using headphones or Home entertainement center, office stereo or even the Boss which is supposed to be "NOT good". That's only sound quality. Image quality is exactly the same story only when plugged to the tv mind you. I don't have the kinds of systems you guys do in my car.
I tried everything, can't get rid of this ground loop intense General Hardware Discussion 3 07-10-2005 09:58 AM
