The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Car Audio > Car Audio FAQ
Thread Tools Display Modes
Old 01-15-2007, 03:35 AM   #106
Vehicle: 1986/Volvo/740
My Photos: (0)
Quote: Originally Posted by durwood View Post
Did you try to ground the chassis of your invertor? Invertors are notorious for inducing noise. Ground the chassi of your computer to the chassis of the invertor to the same ground as everythign else as your stereo system.
I think I managed to do that... I but a small loop between one of the screws in the chassis to the groundcable going into the inverter but it didn't seem to help... yesterday after I connected the cables to the front set of speakers I noticed that my screen was going crazy to... buzzing sound was much louder and the screen was flickering like mad...
I tried using a extension cable from a power outlet and then I didn't have this problem, sound was amazing so I hope I can get rid of this problem and just start to enjoy my 5.1 setup...
Swedish site for CarPC's
http://www.bilpc.info
Naesstrom is offline   Reply With Quote
Sponsored Links
Old 01-26-2007, 11:09 PM   #107
rumy's CarPC Specs
Vehicle: 2001/JEEP/Grand Cherokee Limited
My Photos: (0)
Hi,
Ok so its been a while, as most of you know i am using the XMD1000 and am gettting ground noise in the line in.
I tried grounding the XMD chassie as most of you suggested and still no difference. I am now using a computer with a DC to DC power supply. when I mute the line in it is perfect, it is also perfect with the line in unmutted, however as soon as I connect the XMD and it is operational it has a buz and hmmm..... i also get the alternator whine, what would u guys recommend!!!
rumy is offline   Reply With Quote
Old 01-27-2007, 09:12 AM   #108
My Photos: (0)
I have gone through the exact same problem since I installed the XMD. Grounding the chassie worked partially, but I still had some noise. I finally took the cable apart and found that the ground in the cable at the serial connector wasn't very good. I resoldered it and it made a very big difference. There still is a very slight whine but is 10x more tollerable than before.
Just saw this. It may be the solution
http://store.mp3car.com/ProductDetai...Code=SAT%2D007
Car-mada-puter Epia MII12000, 40gig HD, 512mb ram, Morex 3688 case, M1-atx and XP Pro.
llajumpvid is offline   Reply With Quote
Old 01-31-2007, 10:00 AM   #109
My Photos: (0)
a question for RedGTiVR6
Hello mate,
I am a bit of a novice at all this stuff but have still managed to fit a freeview tuner and DVD/Divx player into my Mk4 Golf GT TDI 150 (both display onto MFD). However, I am getting background noise. I have a ground loop isolator but am not sure where each wire attaches.... stupid i know! Could you please help with either a diagram or by posting where each of the four cables attach (Red and black input And Red and black output). Thanks
bilalsadak is offline   Reply With Quote
Old 03-31-2007, 08:08 PM   #110
LinuxRacr's CarPC Specs
LinuxRacr's Avatar
Vehicle: 01 Turbo Mazda MP3
My Photos: (0)
I'm curious about this as well, as it is the latest problem that I must eliminate.
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Starting over again with new build! Here
Completion Progress Bar: [*********99%]
LinuxRacr is offline   Reply With Quote
Sponsored Links
Old 06-11-2007, 12:10 PM   #111
My Photos: (0)
great thread! i have a similar problem...
i'm running my laptop off of a diehard deep cycle marine battery, through a black&decker 400w inverter. everything was peachy the first few days, but last night the inverter (only the inverter, no speaker noise or anything) started making a huuuge high pitched whine. after reading some of these posts i'm kicking myself in the *** for not thinking to ground anything.
my question is... could i get away with only grounding the battery? i'd rather not have to pull apart the inverter to ground the chassis.
i also assume that my inverter is toasted... anyone care to prove me wrong???
thanks for the help!!!
barrcode is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
I tried everything, can't get rid of this ground loop intense General Hardware Discussion 3 07-10-2005 08:58 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
