08-15-2006, 03:46 AM
#16
Well I´ll have to consider where I will place the amp.
I dont know what I will miss if I have a standard amp without surround. Can I still watch all dvd´s on the market in my car?
I dont know much about crossovers, equalizers and stuffs and I would like to have the system to run by itself without too many features that require extra remotes and push of a lot of hardware buttons just to switch from mp3 to dvd for example. Still would be nice to have 4.1 surround though!
Black SolarCell Portable Bluetooth Gps reciever for sale, Contact me!
BMW E46 320 Touring project thread, making the perfect multimedia car ;)
BMW E46 WORKLOG
08-15-2006, 02:25 PM
#17
Vehicle: 90 RHD JDM 300ZX TT 2+2 5sp,92 MX3 GS-ZE, '00 Audi A4 2.8 Quattro, Ducati TT2 Replica
-no optical input-
Audiobahn A5100T
5.1 Surround Sound 6-Channel Amplifier
Key Features:
Class A/B Mosfet Power Amplifier
2 Ohms Stable Stereo
1 Ohm Stable (Subwoofer Channel Only)
4 Ohms Stable Bridged
Full MOSFET Power Supply
Non-Regulated Power Supply
Double Sided Circuit Board
Interior Circuit Board Illumination
L.E.D. Illuminated Edges & Heat sinks
On/Off switch for illumination
Illuminated Audiobahn name plate
Clipping L.E.D. Indicators under the Volt Meter (Blue L.E.D. Volt Meter)
Internal Cooling Fan
18dB Bass Boost
Soft Start Circuitry
Variable Sub Sonic Filter 20-50Hz
Signal To Noise Ratio: 100dB
High Quality Bipolar Audio Stage
Hi Pass Variable Crossover for 1/2/3/4 channel: 30Hz to 500Hz
Band pass variable crossover for center channel: 30Hz to 8000Hz
Low pass variable crossover for subwoofer channel: 30Hz to 120Hz
Variable Bass Boost for subwoofer channel: 45Hz, 0 ~ +18dB
Phase shift for subwoofer channel: 0 degree to 180 degrees
Dimensions: 12.7"(w) x 2.2"(h) x 23"(d)
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels: 6 - 5.1 Surround Sound
RMS Power (4 ohms): (Front) 125W x 2, (Center, Rear) 75W x 1 & 2, (Subwoofer) 300W x 1
RMS Power (2 ohms): (Front) 200W x 2, (Center & Rear) 130W x 1 & 2, (Subwoofer) 500W x 1
RMS Power (1 ohm): 800W (SubChan is Only Stable Chan @ 1 ohm)
Bridged RMS Power: --
Peak Power Output: --
Min. Impedance Unbridged: 2 ohms, 1 ohm subwoofer channel
Min. Impedance Bridged: 4 ohms
THD @ Rated RMS Power: 0.02%
Speaker Level Inputs: No
Amp Preamp Outputs: No
Built-in Crossover: Refer to features
High-Pass Crossover: N/A
Low-Pass Crossover: N/A
Subsonic Filter: N/A
Signal-to-Noise Ratio: 100 dB
Channel Separation: N/A
Bass Boost: 0 - 18dB
Bass/Gain Remote: N/A
Fan Cooled: Yes
Fuse Rating: 40A x 2
Warranty: 1-year SE
http://www.audiobahn.com/
-may be a discontinued unit also-
Waiting on CT650 for +19 months to install my first CarPC 15/7/08
08-15-2006, 05:59 PM
#18
Vehicle: 2001 Pontiac Grand Am SE
You can still have surround sound with a standard amp. What most people do who want surround is buy a 4 channel amp and a 1 channel amp. The 4 channel amp powers the surround channels, and the 1 channel amp powers the subs. If you did that there would be no buttons to push and no remotes needed either.
08-18-2006, 11:11 AM
#19
Vehicle: 1992 citroën AX MKII
Quote: Originally Posted by Will Albers
Quote: Originally Posted by Red GTI VR6
I simply cannot find any solid information for this amplifier. I google it and I only come up with two links, both to mp3car.com.
I can't even find it on the Autotek web site.
I'd love to add it to the list, but if it's not even avaliable to end users, we can't quite add it just yet.
I think that one is an emphaser, instead of an autotek
edit: hmmm, looked it up and it IS an autotek, my bad
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
08-23-2006, 06:11 AM
#20
Vehicle: 2003 VW Passat v6 (called Klaus)
Anyone know what the requirements are for the ODR series?
Will the RS-A9/RS-A7 accept linear PCM over the optical lines? does this become an ideal amp for those wanting Optical in on an amp, who dont necessarily need 5.1?
08-23-2006, 06:57 AM
#21
It ain't easy being a green moderator
Location: Steps out the front of Henson's workshop or Sydney
Vehicle: 2001 Nissan 200sx
I think Pioneer's ODR was a proprietry system made just for their amps
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
08-23-2006, 10:11 AM
#22
Current state of affairs
So basically, given the lack of products that work (ie, Alpine D550 needs a HU, so does the ODR by the sounds of it, others have discontinued) and either a "sorry, we dont have that any more" response, or no response at all.... regarding "remaining stock/etc"....
It comes down to this: there aren't any current options for an amp that accept a digital signal, using either Optical or Coax...
I can't believe this.
So basically the only options  currently, are - a 1/4" mini-jack -> RCA adapter, and RCA "splitter" or Y cables. (effectively just stereo sound) into a 4+ channel amp.
- a USB/Firewire/PCI/etc sound card with RCA's running to a 4+ channel amp
- optical/coax digital to an external Decoder/EQ with 6channel RCA -> amp(s)
does that somewhat accurate?
the closest anything seems to be, to the ideal product, is that Pioneer Decoder (DEQ-P7650) that does 50x5 (MAX?) as well as 6channel RCA out.. anyone know what its RMS is? im not after "boom boom boom". I'll leave that to 17 year olds in <insert local typical car with stereo 3x price of car here >... I just want decent quality sound, and the flexibility of a carputer.
i briefly considered the alpine deck with touch-screen ipod control (to use with a D550 over optical) but at $AU2000 its a bit steep, given what it does (or doesnt do, actually)...
Am i missing anything, or is that a pretty depiction of the current state of affairs??
08-23-2006, 10:25 AM
#23
_
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
Quote: Originally Posted by pengu
the closest anything seems to be, to the ideal product (for me), is that Pioneer Decoder (DEQ-P7650) that does 50x5 (MAX?) as well as 6channel RCA out.. anyone know what its RMS is? im not after "boom boom boom". I'll leave that to 17 year olds in <insert local typical car with stereo 3x price of car here >... I just want decent quality sound, and the flexibility of a carputer.
please note my addition. There is not an ideal solution for everyone. The Pioneer you've mentioned doesn't have the functionality that I would need for instance.
My question to you, how do you propose to control that piece?
Just because people are into audio doesn't mean they are snotty little kids.
The install in my car and equipment is worth more than the car.
Don't fault people because of their interests. To each their own you know...
Currently, there is not an option out there that is ideal for the CarPC market. Thus the reason for this thread. To outline all of the options that are out there and to facilitate conversations on new products as they are found or become avaliable.
Regarding the RMS power. Chances are it's no different than a typical HU. Which isn't much at all.
08-23-2006, 10:55 AM
#24
sorry for the confusion.. should have actually typed what i was thinking lol.
the pioneer offers the built-in amp (which may or may not be enough, depending on needs) as well as 6ch RCA out (ie, to run to "real" amps, if u need to )
u raise a good point. ive been looking at the alpine stuff so long i expected to see "requires IP-bus (the pioneer equiv. of AI-Net, no?) compatible control unit" somewhere...
as for the last bit. apologies if i caused any offence. I didnt mean to fault you for being into audio, or anyone that is.. My comment was based on the average car seen/heard here (australia) that would fall into the "boom boom boom" classification... Most of them seem to cause more noise from the rattling of boot (er. u call it a trunk, right?) lids/etc than actual music being played. making a boot (trunk) lid rattle is nothing to be proud of, in my opinion...
08-23-2006, 01:05 PM
#25
_
hehe - most kids do what's popular, and that's whats popular. It's not just limited to Australia. Unfortunately it's like a phenomenon...spend the money on the system, and forget about the rest of it..
kinda like buying a motorcycle then forgetting that you should probably get full coverage if it's a new bike....
08-23-2006, 01:20 PM
#26
xtronic currently has a 5.1 digital amp with optical/coaxial inputs in development. Check it out at the bottom of the page http://www.xtronic.be/
08-23-2006, 05:55 PM
#27
How long has it been "in development"?
TBK in Korea has an amp that looks great (spec-wise) but it either doesnt exist, or they dont want to actually sell any.
10-21-2006, 09:31 PM
#28
Xtronic emailed me back on that amp about 5 months ago and said they had no idea when it would be available. I wouln't hold my breath on that one guys.
Brent
1999 Nissan SE-L - turbo toy
1993 Nissan NX - Turbo Racer
Standalone fuel management (AEM EMS) on both
carPC
10-23-2006, 10:07 PM
#30
I would like to try the Zenec ZE-5.1D if i could find somewhere to buy it
| Thread Tools |
| Display Modes |
Linear Mode
