Go Back   MP3Car.com > Mp3Car Technical > Car Audio > Car Audio FAQ
Old 05-03-2009, 06:45 PM   #76
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
To control the processor inside of it, yes.
Defiler is offline   Reply With Quote
Old 06-27-2009, 07:35 AM   #77
hadaak is an unknown quantity at this point
Any updates on this subject?
I found this amp:
http://www.aliencaraudio.co.uk/produ...mplifier_00345
hadaak is offline   Reply With Quote
Old 06-27-2009, 11:43 PM   #78
jschrauwen's Avatar
jschrauwen is on a distinguished road
I found this amp:
That's 5ch and not 5.1ch meaning no center channel. I don't see an optical input option with it either.
1990 RHD JDM 300ZX TT 2+2 5sp T-Top
491RWHP / 18psi / 94 octane
jschrauwen is offline   Reply With Quote
Old 06-28-2009, 02:30 AM   #79
MeeM is on a distinguished road
You mean no subwoofer channel. 5.1 means 5 satellite speaker channels plus 1 subwoofer channel.
And yes, that amp does not have optical input. I guess if someone had a DSP with optical input, they could connect their car PC to the DSP, and then connect the speaker outputs from the DSP to this amp.
MeeM is offline   Reply With Quote
Old 06-28-2009, 04:00 AM   #80
jschrauwen's Avatar
I don't think so. 5ch as in that amp is designed to drive a set of front and rears and a sub.
5.1 drives a set of front and rears and a center ch and a sub.
Old 06-28-2009, 04:13 AM   #81
ptk
ptk is on a distinguished road
the spec of that 5 channel amp is indeed for front, rear and sub.
a 5.1 amp is actually call a 6 channel amp. and MeeM is correct in that the .1 usually refers to the sub channel. There are plenty of 2.1 and 4.1 amps around, which are actually 3 and 5 channel amps respectively.
it's just a matter of terminology. Both of you were correct in your own assertion.
I use a Diamond Audio D5 5.1 amplifier. They have stop making it. It's fantastic for a compact 5.1 install. I drive it with a Alpine H700. To date, other then going high end sound like Red is doing, Alpine h700 remains the easiest way to create fantastic 5.1 sound field.
CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
ptk is offline   Reply With Quote
Old 06-28-2009, 07:50 AM   #82
what about this one:
http://www.aliencaraudio.co.uk/produ...ound_Amp_00346
Old 06-28-2009, 07:58 AM   #83
this one look cool !!! I'm not a spécialist
can this one be used without an alpine headunit?
http://cgi.ebay.fr/ws/eBayISAPI.dll?...3D12%26ps%3D33
Old 06-28-2009, 08:36 AM   #84
jschrauwen's Avatar
^^^ I guess I'll have to agree and disagree with you. The .1 designator in an amp also has a separately assigned channel for the sub whereas I'm not 100% that that's the case in all 5ch amps.
"Alpine h700 remains the easiest way to create fantastic 5.1 sound field" - I again might have to disagree with you on that. I chose the Comell LV675 MB specifically because it had SPDIF out as is the case I chose the Performance Teknique ICBM5.1 amp that utilizes SPDIF input. No DA converters needed, no extra cabling. Just one single optical cable from MB to amp for me to create "fantastic 5.1 sound field". I believe if you go back through this thread you'll see that.
5.1 amps with optical inputs
Old 06-28-2009, 02:46 PM   #85
how do you deal with the volume?
I'm very interested in this kind of install. I h'aven't bought anything right now. just searching for info....
Do you have any guide or how to?
Old 06-28-2009, 08:23 PM   #86
I have my desktop connected to a 5.1ch amplifier via an optical cable. The Master Volume in Windows does not function when using optical, but the Wave volume and the other levels can be adjusted. So if you're using a front-end like RideRunner, you'll have to map the volume control to Wave instead of Master to get it to work.
Old 06-29-2009, 01:11 AM   #87
ptk
jschrauwen
with regards to 5 channel amps, I do opined that it's probably better to label it as 4.1 if it's designed with sub channel in mind. while's it's not wrong either as 5 channel or 4.1, 4.1 is more precise.
as for PT ICBM 5.1. I will agree that it's a fantastic product, and was initially within my plan. However, as I wanted abilities not offer by ICBM (per channel EQ, Time Delay, cross over etc), i eventually opted for H700 to create a good sound field.
and it's not true that there is no DA by using direct optical to amplifier. The DA is within the amp itself. While in the case of using a sound processor, the DA is within tthe sound processor. The only difference is the analog sound path is much shorter if the DA is within the amplifier as compare to siting within the sound processor. The flip side of cause, considering the level of EM noise, having DA away from the amplifier might subject to less noise.
Old 06-29-2009, 04:44 AM   #88
Hi MeeM,
Which optical Amp are you using?
is it standalone (no need for additional unit)?
is it 5.1?
Thanks.
Old 06-29-2009, 08:15 AM   #89
Hi MeeM,
is it 5.1?
Thanks.
Hi Hadaak,
Just to remind that this is referring to my desktop PC in my room, not the car PC in my car . It's a Kenwood KRF-V5100D. Yes, it is 5.1 (and apparently "7.1 channel ready", according to the sticker on the front) It's a home theatre receiver and amplifier. It only does 5 channels, namely the two fronts, the centre, and the two rears. It has a separate sub-out to connect to a powered subwoofer.
Old 07-02-2009, 03:06 PM   #90
OK
I thought you were talking about thr carpc.
What are you using in the car?
Clarion DSP -- Optical inputs justav6 General Hardware Discussion 7 01-03-2008 01:51 PM
For those who want true 5.1 Dolby Digital and DTS antimatter Car Audio 89 06-29-2007 12:54 PM
Hifonics Zeus AMP for DIGITAL 5.1 decoding!!! kenski Car Audio 31 08-15-2006 11:11 AM
Comments on 5.1 car amplifiers ptk Car Audio 8 07-31-2005 02:31 PM
5.1 and stereo mbaratta Car Audio 19 05-25-2004 08:09 PM
