Go Back   MP3Car.com > Mp3Car Technical > Car Audio > Car Audio FAQ
Old 10-12-2006, 11:07 AM   #1
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
DACs
What is a DAC?
From the Stereophile Forums talking about jitter and USB DACs as well as USB two way communications for error correction. VERY good read.
  • Silverstone DAC
    Reviews Here:
  • Douglas hpdaq
    Reviews Here:
    Quote: Originally Posted by ScottFX
    we'll call it the 'douglas' hpdac. since this is a diy board you can use whichever components you'd like. I'm currently running burr-brown opamps and blackgate caps.
    also... since it's a diy board you can wire it with female rca's to connect directly to your amp. This will give you a digital signal within inches (or less) of your x-over or amp. If you are going the x-over route you can also think about cracking that active x-over open and wiring the outputs of the dac directly to the inputs of the x-over.
  • Griffin iMic
    Reviews Here:
  • Hippo HiFi Bloat
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 10-13-2006, 02:01 PM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Here's a Pro Audio DAC
MiniDAC ($1000)
http://www.apogeedigital.com/products/minidac.php
System always under construction
durwood is offline   Reply With Quote
Old 10-13-2006, 02:03 PM   #3
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
nice find, apogee is the standard in pro audio...but at a price.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 10-13-2006, 03:02 PM   #4
Car Audio Moderator
durwood's Avatar
Thanks, although your find is more practical in price.
Yep I agree...Quality=Bling Bling
Old 10-16-2006, 10:43 AM   #5
lorenwade's Avatar
lorenwade is an unknown quantity at this point
You might add headroom to your list of USB DACs. They're audiphile quality... and amazing.
http://www.headphone.com/
lorenwade is offline   Reply With Quote
Old 10-16-2006, 11:30 AM   #6
_
are you referring to these?
http://www.headphone.com/products/headphone-amps/
I'd imagine that the vast majority of those would work if they use 12v power from the wall wart
I don't know why I didn't think about them, seeing as how I've got the headroom sitting right here at my desk with my Sennheiser 595s.
Jan Bennett
Old 10-16-2006, 11:44 AM   #7
lorenwade's Avatar
Yes, those. Thats all headroom makes.
Yea, I'm surprised no one posted it. Not only are their products astonishing quality, their service is superb as well.
And your Sennhesiers appreciate it I'm sure.
Old 10-26-2006, 10:40 PM   #8
MySQL Error
scott_fx's Avatar
if you want to convert any dac to usb you can purchase one of these puppies:
http://www.hagtech.com/hagusb.html no drivers to install or update... this should open up the world of dac's to us.
M10k
My Car Pc Install
Old 10-30-2006, 10:41 AM   #9
MySQL Error
scott_fx's Avatar
and this one too...cheaper:
http://www.coemaudio.com.au/products.php?product_id=96
M10k
My Car Pc Install
Old 11-18-2006, 04:34 PM   #10
MySQL Error
scott_fx's Avatar
this isn't a usb dac, but it could be made into one very easily. I think maybe we should change the title of this thread to just 'dacs' in stead of 'usb dacs'
anyways; Brian, one of the owners of 'twisted pear audio' has been helping me out a ton with an audiophile grade stepped attenuator that i'm integrating into my dac. I've come across a lot of people that just give the quick answers and expect you to buy. but Brian has gone above and beyond the call of duty and is actually excited to see his application to make it into the 12vdc automotive world.
enough about my experience with him, now onto the dac;
http://www.twistedpearaudio.com/opus%5Copus.aspx
thread about the opus dac:
http://www.diyaudio.com/forums/showt...threadid=79456
toslink post:
http://www.diyaudio.com/forums/showt...53#post1059953
his site with other great audio gear:
M10k
My Car Pc Install
Old 11-28-2006, 11:54 AM   #11
crabbdaddy is on a distinguished road
usb tube dac
i guess im getting a little off topic ..please move if needed.
interesting logic behind the design.
tube DAC
http://www.scott-nixon.com/dac.htm
review links are in the above link... its a neat idea for the usb version. seems it only takes 12V AC which a PS could be built to handle.
96 cobra
suspension: MM CC plates, H&R super sport, bilsteins, steeda:bump steer kit, X2's, moly SFC's, triax shifter. MGW handle, cobra knob. Audio:RUX-C701, PXA-H701, MRV-F545, MRD-M1005, SIR-SC-H1, DMHD1000, Polk/Momo MMC6500, MM2104
crabbdaddy is offline   Reply With Quote
Old 11-28-2006, 02:06 PM   #12
_
you might want to check one of the stickeys 'USB DACs'
moving this post and yours to that thread.
Jan Bennett
Old 11-28-2006, 02:17 PM   #13
MySQL Error
scott_fx's Avatar
tube DAC
the stepped attenuator that i got from twisted pear is a 5-12v ac unit also. here is what brian told me about that:
Quote:
It was designed for AC input, but if you supply DC instead, the rectifier diodes will just pass it through. Good news is that it won;t matter which pin you use for +12 and GND. Both ways will work the same.
also, if you were to use that one in an automotive environment you'd probably want to solder the tube to the board. a major factor of tube failure are tubes that aren't seated properly.
M10k
My Car Pc Install
Old 01-02-2007, 10:56 AM   #14
OhSh1rt is on a distinguished road
And shock mount it somehow, anything you do how however, the tube will always have some distortion and from the second you turn it on it begins to deteriorate. Tubes sound great in a guitar amp, but they aren't exactly (at least mathematically) good at reproducing a sound accurately.
-jeffrey
OhSh1rt is offline   Reply With Quote
Old 01-02-2007, 12:15 PM   #15
MySQL Error
scott_fx's Avatar
that may be true; but there are a lot of people that still love that tube amp sound. :-)
M10k
My Car Pc Install
we've discussed usb dac's...has anyone used other dacs? scott_fx Car Audio 2 10-11-2006 02:12 PM
Which DAC ? CyberManiaK Car Audio 6 07-08-2006 01:39 PM
Best bang-for-the-buck PCI Sound card? WebGeek General Hardware Discussion 24 04-28-2006 03:22 PM
On-board Audio VS. Sound Card cadence117 Car Audio 54 01-17-2005 01:21 PM
