11-14-2006, 12:57 PM
#46
Car Audio Moderator
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
I check back in now and then to update the list so don't worry about it. That is a good question you ask. You might want to post it as a new thread. I wonder if you could do it with an creative labs and the kx drivers. Otherwise you would need a PRO card that maybe you can re-route signals to.
System under construction
11-30-2006, 07:51 AM
#47
Vehicle: 2000/Chrysler/300M
Quote: Originally Posted by comet28024
The E-MU interfaces are not very processor friendly. We have an EMU-1820 that sounds amazing, but is slow with anything under 1.5Ghz.
laptop has a 2ghz AMD 3000+ CPU so IM not really worried about cpu power
12-16-2006, 09:10 AM
#48
_
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
http://www.motu.com/products/motuaudio/ultralite/
This card might want to be added.
If I can't get the X-Meredian to do what I need it to do, I'll probably be stepping up to the Ultralite.
1/4" jacks are a plus!
one benefit, it seems, to this sound card, is that it has mic inputs built in that act as a preamp with phantom power. If you're going to be using True RTA in the car, this means that you don't need to purchase a seperate preamp for your mic and find somewhere to mount it in the car...if you so desire. Me Likey!
12-18-2006, 08:25 PM
#49
MySQL Error
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
can you go fully active with that motu? i.e. does it have x-over capabilities?
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
12-18-2006, 10:23 PM
#50
Car Audio Moderator
Only with ASIO and VST plugins like Frequency allocator, but not by itself.
01-07-2007, 10:35 PM
#51
Vehicle: 1999/VW/Passat
Anyone know about a usb sound card without hibernation issues ?
One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
01-08-2007, 04:24 AM
#52
Vehicle: 1992 citroën AX MKII
found an other card from terratec: the phase 88
edit: oops..... sorry guys, that one's PCI....
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
01-08-2007, 12:17 PM
#53
MySQL Error
any dac shouldn't have hibernation issues
M10k
My Car Pc Install
01-08-2007, 03:03 PM
#54
Car Audio Moderator
I don't have any problems with my Soundblaster Live but I have seen some users with problems with the Audigy NX...might be due to separate power. I don't really know. For USB devices there is a utility called DEVCON to help out with USB hibernation issues.
02-17-2007, 02:00 AM
#55
I just bought a Behringer UCA202, it's junk. Has just as much noise as the onboard card, picks up HDD and mouse noise. Doesn't even work with RR, and mutes itself in windows for some reason. Tried it on my desktop, has heaps of noise too so it's not just the car PC, and took 3 attempts before windows would pick it up, kept saying "device not recognised". Even after I got it to work, only one channel would output.
To top it off, the build quality is rubbish, the gold plating is all pitted and rough, and the volume knob keeps turning past its stop points.
I'm taking this piece of crap back to the shop as soon as I can!
02-17-2007, 10:16 AM
#56
Car Audio Moderator
Sorry to hear your misfortune. Thanks for your review.
02-23-2007, 01:27 AM
#57
External Sound Cards
I've read this thread with much interest as it directly applies to my situation. I do not have any space left inside the voom pc case for a full blown sound card in the PCI slot. The mobo itself also has a huge heatsink that extends until its right next to the PCI slot (Via EN15000G) which prevents changing the position of the pci slot. So I'm stuck with an external sound card solution (unless someone knows of another clever solution).
I noticed that the M Audio Audiophile USB isnt listed in the OP's list. Was wondering why that is. Is it because of the USB part of it? Because I see that the M Audio Audiophile Firewire is listed. I unfortunately do not have a firewire port on the mobo so that rules out any firewire card. Is the M Audio USB a viable option?
Sorry if this is a silly question. I could barely understand half of what you hard core audiophiles were talking about  . TIA.
JY
02-23-2007, 06:39 AM
#58
Car Audio Moderator
I had to go back and look to see why I didn't include it. First is that I didn't plan ahead when I made the first post and the list is almost maxed out as I can barely add any more info before the forum rejects it for too many characters. I should have reserved a second post to allow for more room. Maybe a Mod can help me out and allow me ot insert a second post in there somehow so I can expand the list.
Second, I think I didn't include it because it was only 2 channel, and at that price you could get the 6 channel Firewire version instead. Still it's a good card to consider. For that price though and if you only need two channels, you might be able to get a really nice USB DAC instead, although most USB DACs don't have line input if you need it. Maybe it has some other features you were looking for? Just some thoughts.
02-23-2007, 01:42 PM
#59
I did notice that the M Audio USB has only two channels. I would really like the M Audio Firewire but again, the mobo doesn't have that option. I would be needing the line input so that leaves out a USB DAC. I'm at a bit of a loss as to which external audio solution would work best for me. The list you have though is helping put things together a bit better for me.
Having good audio was something I left out when planning this project. But all the talk about audio from the audiophiles on this forum is infectious, and now I am needing something a bit higher level then a "consumer" solution.
JY
02-23-2007, 01:45 PM
#60
_
muahhaha
welcome to the dark side!
| Thread Tools |
| Display Modes |
Linear Mode
