The MP3car.com Store
Thread Tools Display Modes
Old 04-04-2007, 09:54 PM   #1
Vehicle: Honda Civix LX 2000
My Photos: (0)
Do i really need an amp?
Yea, do i really need an amp? I'm planning on using: Creative Sound Blaster Audigy 2 NX External Sound Card.
Can't i just connect the wires from that to the speakers?
What are the pro's and cons of doing this?
Sinabl is offline   Reply With Quote
Sponsored Links
Old 04-04-2007, 10:01 PM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
the pros, easy.
the cons, it WILL NOT WORK AT ALL
To answer the question. Yes you need an amp.
2k1Toaster is online now   Reply With Quote
Old 04-04-2007, 10:02 PM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Or a headunit with aux in capability.
But the headunit has an amp built-in, albeit a very low power one.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 04-04-2007, 10:05 PM   #4
2k1Toaster's Avatar
My Photos: (1)
Well it is still an amp...
The question was not "do I need an external amp?" Go technicalities!
Old 04-04-2007, 10:08 PM   #5
My Photos: (0)
Ok so is it possible to take out the cd stereo system (sony mp-40) and replace it with the 7" liliput screen and place the cd stereo system in the cup holder area? Will i be able to get all the wires there? Am i better off just buying an amp? How much is that and how do i power the amp itself?
Old 04-04-2007, 10:11 PM   #6
My Photos: (26)
It's your ride. You tell us....
In all reality, anything is possible. Now, whether you're willing to invest the time, money and materials to make it happen is another metter entirely.
How much is an amp?!?!?!
You can get cheap ones for under a hundred bucks or get top-of-the-line sound quality and spend thousands. It all depends on what you need, what your budget is, and what qualities you want in an amplifier.
Seriously, if you odn't know how to power an amplifier, you're better off replacing your headunit with something that has an AUX IN (short for auxilliary input).
My Worklog
Old 04-04-2007, 10:13 PM   #7
2k1Toaster's Avatar
My Photos: (1)
Do whatever you want. If you are planning to relocate the HU, then why keep it at all? The only reason to keep a HU is when you don't want to modify anything at all.
An amp takes power, ground, and a remote line. That't it. Some "premium" stock sound systems have external amps that you can connect with, but most are built into the HU.
For an amp with the same quality as the built in amp, it is like $50 on eBay.
Old 04-04-2007, 10:13 PM   #8
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
this question was just asked (the thread is still on the first page of the audio sub forum) and had valuable replies. I know you're new but you should practice searching before posting and then if you need more info then post. welcome to the madness btw
here ya go:
http://www.mp3car.com/vbulletin/car-...-need-amp.html
if you want a stock equivalent (power wise) then you should check out the sonic impact t-amp (parts express sells them) you can take the circuit board out of the plastic casing and it'll be pretty tiny so you can hide it anywhere..even in your pc case probably
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 04-04-2007, 10:14 PM   #9
symon_say's Avatar
Vehicle: 05 Fiat Palio
My Photos: (1)
Men you need to read LOOOOOTTTTTTTTTTT of FAQ.
Design [000000000-]90%
Parts [000-------]30%
Installation[----------]0%
Integration[000-------]30%
symon_say is offline   Reply With Quote
Old 04-04-2007, 10:25 PM   #10
Redian's CarPC Specs
Redian's Avatar
Vehicle: 2004 Subaru Impreza WRX
My Photos: (0)
yeah um, im with symon on this one... if you dont know how to wire an amp, you shouldnt really be tyring a computer and jumping headfirst into it without researching alot
believe me, i know from experience ^^
2004 Subaru Impreza WRX CarPC Install
Install: 90%
"When you go 0-60 in 4.5 seconds, you don't need a made up character called fast. Thats what makes a Subaru, a Subaru."
Redian is offline   Reply With Quote
Sponsored Links
Old 04-04-2007, 10:41 PM   #11
MySQL Error
scott_fx's Avatar
My Photos: (0)
Don't be detered though; it isn't that hard but they are right, you need to read a lot more
M10k
My Car Pc Install
Old 04-04-2007, 10:48 PM   #12
symon_say's Avatar
My Photos: (1)
In fact is really easy if you have some interest, and you love what you're doing, but men, you need to know who to install your system before you try installing a CarPc.
You should check at www.caraudio.com or www.bcae1.com and learn at least the basics of funtion and installation this way you understand what this people that will help us are trying to say.
Sponsored Links
vB code is On
Trackbacks are Off
Engine Noise due to ground loop or amp? matt11601 Car Audio 29 05-07-2008 07:18 AM
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 10:16 PM
Can I run this amp with this sub, how do ohms work, help/recommendations... mikeym Car Audio 37 02-12-2007 11:10 AM
Car Audio People, Help me pick an amp / Jeep GC w/ Infinety System hevnsnt Car Audio 3 12-07-2004 06:34 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
