The MP3car.com Store
Thread Tools Display Modes
Old 04-14-2007, 01:57 PM   #1
carputerdude's CarPC Specs
My Photos: (0)
vst effects with kxproject
Hi there, I have the KX drivers installed on a Audigy 2 zs, but I can't get any VST effects to show up. I have a vst delay and a vst 31band eq in my winamp directory. I pointed kx setup to that directory on install( when asked for VST directory) but I can't see them anywhere in the kx drivers. They both work fine in winamp with the vst bridge, but I want them in the kx dsp. I am using 6 outputs for 2-channel stereo pass filtered for mids and highs and bass and need to (want to) do time correction for my front stage because my tweeters are about a foot closer than the midbass speakers. So basically how the heck do you do it? the delay's that are with the kx effects seem worthless for millisecond type adjustments. I dl'd the UFX pack and I think my version of kx is too new but I need that for the audigy 2 to work? or do I?...Thanks in advance...Andy
carputerdude is offline   Reply With Quote
Sponsored Links
Old 04-14-2007, 03:17 PM   #2
My Photos: (0)
anyone?
Old 04-16-2007, 07:42 PM   #3
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
vst effects do not work in the KXdriver control panel. You can only use them in a vst host or the winamp vst bridge plugin.
If you want to have a time delay, you need to use '"timebalance" or "smalldelay". I don't remember which kx plugin package they are included in but either one will work with driver version 3538. There are links in the wikipedia to get you to the right place plus some basic guides.
durwood is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Software options for Tuning RedGTiVR6 High End Solutions 454 07-23-2008 09:10 AM
kx and vst carputerdude Car Audio 0 04-13-2007 05:33 PM
VST plugins in streetdeck? cougarz DigitalMods (Scripts / API) 5 01-23-2007 02:24 PM
Screen Transitions, Pic Viewer & Album Art effects DiNASTY Road Runner 40 07-17-2006 11:30 PM
VST Plug-In support - software EQ Quack FrodoPlayer 0 03-31-2006 10:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
