The MP3car.com Store
Thread Tools Display Modes
Old 05-10-2007, 04:38 PM   #16
My Photos: (0)
Glad you got it figured out!
vbcrush is offline   Reply With Quote
Sponsored Links
Old 05-11-2007, 01:31 PM   #17
Vehicle: 2002 Pontiac Grand Am GT
My Photos: (1)
Well ok im back with a problem.. Does road runner have some kind of Auto Mic unmute command/feature.. Whenever I mute the Mic in windows.. I open Roadrunner and it unmutes the Mic... Its quite annoying, becuz if I do it, when it comes back into Hibernate, it becomes unmuted again... Thought i had it solved, but apparently not..
Iceplayagt14 is offline   Reply With Quote
Old 05-11-2007, 03:01 PM   #18
hithere's CarPC Specs
Vehicle: 06 Acura TL
My Photos: (0)
Usually (i think), RR mutes/unmutes the mic for satellite input...otherwise, in my prior RR setups, RR doesn't do anything with the mic input. Check setting under "SAT" in RR configurator, there should be a check box or some such...I don't know what other events would trigger this behavior, besides maybe Winamp being opened and set to listen to the mic input somehow.
That's one of my problems with using the mic input at all, the way RR is set up to mute/unmute is a toggle command that can get "mixed up" depending on what you do inside or outside RR with the mute checkbox in the Windows mixer.
hithere is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
No subwoofer bass when using carpc R@b Car Audio 23 08-21-2006 06:50 PM
CarPC next to subwoofer twantrd General Hardware Discussion 3 04-19-2006 07:41 PM
subwoofer grounding problem megagoo General Hardware Discussion 3 12-23-2005 11:41 PM
Sponsored Links
Ad Management by RedTyger
