what kind of speakers...
i'll assume 4 reugular (coaxial's) and a sub... seeing as how you already got the amp... either sell it or get a mono amp...
another option... find out the ohm ratings of the speakers... if they're 4 ohm... and all the same power rating, and you amp can handle 2 ohms... you can run them in parallel to two channels of the amp. then if the amp supports bridging... bridge the other two channels and run the sub off that... problem is you have no fading capabilities... so you're hoing the fronts and rears sound good at the same power...
good luck
2006 Mazda 3 Behringer DCX-2496 JL300/4 Focal 6W4311B Focal TN52 JL500/1 JL10w6v2
