If what your saying is accurate, it sounds like nothing you did. Since it does start with a jump, just not on its own, you have tested the starting system, move next to the battery. Let the battery charge on a charger for a while and retest. Likely it is the cause. You also should test the alternator, make sure its putting out a good 13+ volts at idle.
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
