Old 04-23-2007, 03:18 AM   #1
n3xus210 is an unknown quantity at this point
Need new power for cd player
I have had my 95 grand prix se for a while now and its always had some wierd electrical stuff, the seat belt chime+light come on only when the seatbelt is off, headlights on, and the unlock button is pressed down, there is a funny buzz comming from the dash when the headlights are turned on while the car is off, etc. All fuses in the car are good. All wire connections are secure. I removed the stock radio to install a new cd player using a wiring harness made for my car. My cd player will only turn on when my headlights are switched on, when I try inserting a cd, the cd player flickers and takes the cd in very slowly, now I cant get my cd out. Is there a way to rewire the power to my cd player so I can make it work right without having to spend hundreds of dollars on a mechanic to fix it?
n3xus210 is offline   Reply With Quote
Old 04-23-2007, 03:19 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
this forum is for CarPC's...
And just wire it direct to the battery with some alligator clips or something.
Old 04-23-2007, 09:48 PM   #3
Dennis5587's Avatar
Dennis5587 is on a distinguished road
sounds like its time to start saving for anew car...
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 04-24-2007, 10:26 AM   #4
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
sounds like you might have wired your radio's power wire conencted to the wrong wire-probably dimmer or illumination wire. Make sure you have it wired with a constant 12V and switched ignition, not dimmer and illumination unless the radio has a wire for that.
Also, I will restate this...this site is dedicated to installing carpcs, not headunits. There is a sticky that you might to read. hint hint
System always under construction
durwood is offline   Reply With Quote
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Power Question/Setup Question, minibook pc seamonkey420 Newbie 4 05-17-2004 10:47 PM
Cheap 5.6 In-dash Monitor, Power Acoustik DVD player, FM Modulater falconey Classified Archive 2 05-11-2004 12:07 AM
