Old 05-01-2007, 06:05 PM   #1
canadamatt is an unknown quantity at this point
weird sound interference only when engine is on!
I have a inovatek in-car LCD screen head unit. with the engine off, everything plays great including the screen but when i turn on my engine a very annoying noise is produced out of the rear speaker. my rear speakers are amplified. this sound's frequency is directly proportional to the revolutions of my engine.
does anyone have an idea why this sound is being produced?
canadamatt is offline   Reply With Quote
Old 05-01-2007, 07:09 PM   #2
WarX is an unknown quantity at this point
your rear speakers are amplifier? re-route the RCAs at least 18inches away from the power wire... so power wire on ONE side of the car, the RCA's on the opposite side of the car
WarX is offline   Reply With Quote
Old 05-01-2007, 07:14 PM   #3
Dennis5587's Avatar
Dennis5587 is on a distinguished road
yeah, i got a great idea... but I really think all you need to do is
ps: search alternator wine
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 05-01-2007, 10:33 PM   #4
How is that anyways? I've never tried Alternator Wine
Old 05-01-2007, 10:35 PM   #5
XC-C30's Avatar
XC-C30 is on a distinguished road
maybe somethink like motor-oil?
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 05-02-2007, 05:22 AM   #6
took your advice
i looked up alternator wine and i disconnected my RCA cables from the amp while my engine was on. when i disconnected the cables the sound went but then when i plugged them back in it came back on. does this help anyone deduce the problem?
Old 05-02-2007, 06:37 AM   #7
RodeoTristan is an unknown quantity at this point
Try changing the earth of the amp to a different point. Check all connections running to and from the head unit to the amp ect because that can also cause interference.
RodeoTristan is offline   Reply With Quote
Old 05-02-2007, 12:41 PM   #8
UV7
UV7's Avatar
UV7 is an unknown quantity at this point
What you are describing is a symptom of a ground loop. A ground loop occurs when there is a difference in potential between ground points. The most likely culprit in this case is your amplifier's ground. Ideally, all electronics would ground to the same point, thereby eliminating any possibility of a difference in potential, but this just is not possible. Since the majority of the electronics in the car ground to the frame, the best possible location to ground the amplifier is also going to directly to the frame, or as close to it as possible. Seat bolts, bracket bolts, etc., anything that will make solid, metal-to-metal contact as close to the frame as possible is going to be a good ground. You also need to ensure the ground point is clean and clear of any resistance. You will want to grind away any paint, remove any insulation, padding, dirt, carpet, etc., from the ground location so that the amplifier's ground makes as much contact as possible with as little resistance as possible.
I hope this helps.
True knowledge exists in knowing that you know nothing. True wisdom comes to each of us when we realize how little we understand about life, ourselves, and the world around us.
-Socrates
UV7 is offline   Reply With Quote
Weird video interference problem! HELP! lookinco LCD/Display 15 05-22-2007 12:21 AM
Creative Labs Sound Blaster® Live!™ 24-Bit External USB 1.1 SpyderHatch Classified Archive 12 11-28-2005 05:12 PM
Noise (from engine and other sources) HELP!!! sstylos Car Audio 6 09-20-2005 01:41 PM
Invertor causing a "buzz" sound fireball106 Power Supplies 11 01-18-2005 01:09 PM
got sound? masch Newbie 20 11-17-2003 10:01 AM
