Old 05-06-2007, 04:12 PM   #1
energiesource is an unknown quantity at this point
CarPC audio help
So since carpc's usually have a computer motherboard, how would you hook up the audio? is there an adapter you can buy or what?
energiesource is offline   Reply With Quote
Old 05-06-2007, 04:47 PM   #2
lbridges is an unknown quantity at this point
on-board sound, add-on sound card, external USB sound, or PCMCIA sound
lbridges is offline   Reply With Quote
Old 05-06-2007, 04:49 PM   #3
was that a question or an answer, the onboard sound device has the 3 plugins for mic, speakers, etc, but i dont know how to connect my car speakers to it
Old 05-06-2007, 05:23 PM   #4
It was an answer, but not to the question you really wanted answered.
To use the on-board sound with the 3 plugs, you will need a 1/8" mini-plug to RCA type cable, connect RCA cable end to an amp, then the amp to your speakers. The power coming out of the motherboard simply isn't enough to drive speakers (it's made for computer satellite speakers which have an amp inside them).
Better this time?
Old 05-06-2007, 06:59 PM   #5
thanks
i have a mustang with the mach 460 system in it, so there are 3 amps running the speakers already, just factory ones, can i set them up to an aftermarket amp or do i need to rewire everything completely?
Old 05-06-2007, 08:14 PM   #6
Sorry, I know nothing about that system. My only advice (if someone with experience doesn't chime in) is to search on Mustang and PM some owners.
Old 05-06-2007, 08:20 PM   #7
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
I've got the mach460 system. I've done away with the front amp (mach 460 has 1 amp up front for the highs/tweeters, and 2 in the rear for the mids/lows) and I'm using an aftermarket head unit with an aux input. Running the built in sound from the MB, speaker output, to the aux input. Works great.
For info on removing the front amp, making the mids/lows work correctly without the front amp, etc (cuz the input from the stock head unit to the front amp is a low level signal and the rear amps were fed from the front amp)... see the MACH 460 tutorial I have on the CarPCNetwork HERE. Using an aftermarket head unit negates the need for the front amp.
//dang it.. lol my pics are missing... I have to fix that real quick. :-\ sorry
W3bMa5t3r is offline   Reply With Quote
Old 05-06-2007, 08:31 PM   #8
W3bMa5t3r's Avatar
Ok, the pics / diagrams are all up and good to go
Old 05-06-2007, 08:32 PM   #9
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
http://www.mp3car.com/vbulletin/faq-...tereo-amp.html
You should make friends with the search function. If you're serious aboiut a vehicle PC project, you're going to search these forums.
A lot.
thanks
Well, if you go with aftermarket amps, you're going to pretty much rewire everything anyway.
Webmaster has been down that road, and is likely a valuable source of information. How much reworking of everything you choose to do is up to you, I'd think....
Good luck.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
How to connect 2 cars (both with CarPC) to have audio, file transfer? urosbe Wireless Communications 8 10-08-2006 03:07 AM
carpc with name brand monitor fasteddie Input Devices 5 08-25-2006 08:09 AM
Audio Muted on startup liquid_smoke Road Runner 4 08-12-2006 02:31 AM
timeouts and bluetooth audio randomness numbers PhoneControl 4 01-09-2006 04:44 PM
some audio questions for my setup PatrickB General MP3Car Discussion 12 05-11-2005 08:37 AM
