The MP3car.com Store
Thread Tools Display Modes
Old 05-10-2007, 11:00 AM   #16
akwash79's Avatar
My Photos: (1)
Well, I moved the amp ground to a separate location and it seemed to sound a little crisper but the noises still persist.
I also hooked my laptop up to the amp and there was no noise whatsoever. Nothing but clean, crisp sound. As soon as I hook the pc up to the amp buzz...buzz...whine...buzz....buzz. This happens with using both the onboard sound and the turtle beach roadie. Arrrggggg.....
If tested independently, neither of the devices are producing noise. It only seems to happen when both are connected together.
Carpc install - 100% completed
http://freecabs.org - for your Windows mobile pocket pc needs
akwash79 is offline   Reply With Quote
Sponsored Links
Old 05-10-2007, 11:06 AM   #17
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Try it with the car running, the car off , the pc plugged into wall power (if you still can). See if it's alt noise, fan noise, hdd noise.....
Cheap amps and cables can sometimes cause problems. And on the other end, high end amps can pick up sounds (noise) in a poor install that a cheap amp doesn't.
Ya gotta find where it's comming from before you can fix it.
Unfortunately, there's usually no easy way to find it. You just have to keep changing things until you find the source. It can be very frustrating and a long process. You just have to keep pluggin' away. I wish there was a definative answer or easy fix to give you, but there isn't. Sorry.
Good luck
P.S. maybe you should remove that 100% completed line in your sig J/K.
greatwhite is offline   Reply With Quote
Old 05-10-2007, 11:08 AM   #18
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
Did you check your gains on the amps and make sure that they are set up properly?
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is online now   Reply With Quote
Old 05-10-2007, 11:28 AM   #19
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
Sounds like maybe you have an issue where both your amp and computer and grounding the ground portion of the RCA cable. Try a ground loop isolator at this point. I am alomst 99% certain it will fix your rproblem and they are cheap <$10.
I could suggest some other things to do, but at this point I don't know if you want to do some surgery on your RCA cables or swap out your amp for a different brand.
durwood is offline   Reply With Quote
Old 05-10-2007, 05:19 PM   #20
akwash79's Avatar
My Photos: (1)
I adjusted the gains and that doesn't seem to be an issue. Thanks for the suggestion though. I think durwood may be correct on this issue and I may have to go with the GLI. They pc and amp only cause a problem when used with each other.
@greatwhite - well technically it is 100%, I just have to turn the volume up a litte and the noise isn't a problem lol. Sucks when changing tracks
Sponsored Links
Old 05-10-2007, 05:36 PM   #21
My Photos: (0)
Coupla ground things I've been dealing with on parallel project you might consider as well... Dunno if it'll help, but it won't hurt.
Clean and tighten the engine ground strap. Also the primary ground from the battery to the frame. Try adding a ground strap from your equipment to the engine as well. If nothing else you may improve how the car runs...
no_luggage is offline   Reply With Quote
Old 05-10-2007, 07:29 PM   #22
JAC
JAC's CarPC Specs
JAC's Avatar
Vehicle: 2000/BMW/328i
My Photos: (0)
Quote: Originally Posted by akwash79 View Post
Where to begin?
I have a M10000 powered by the m1-atx psu. Both amp and pc are wired directly to the battery using 10awg wire and both grounded to the same spot under a bolt in the trunk(I DID sand this down to bare metal). The audio is going out directly to the 4-channel amplifier(no HU).
1st attempt - I used the onboard sound and got alternator whine and buzzing sound whenever the HD was being accessed or duriing mouse movements(on touchsscreen). When removing the RCA wires from the amp, the noise stopped.
2nd attempt - I used the Turtle Beach Roadie USB sound card for audio out. While this improved the sound quality greatly, the same alternator whine still persists. But...... get this......I no longer hear a buzz when the hd is being accessed or during mouse movements, the buzz is now constant and ONLY goes away when the hd is being accessed or the mouse is moved. WEIRD. I hooked up a pair of headphones to the audio out from the roadie and I did not hear any noticeable noise.
Also, my rca cables are no where near the power or ground wires.
My next steps:
1. Try hooking a cd player or ipod directly to the amps to see if the noise is still there(may be difficult to come across one of these without purchasing) I may try using my pocket pc, just need an adapter.
2. Ground loop isolaters - although this really doesn't SOLVE the problem just masks it.
3. Ground amp and pc under 2 different bolts?
4. Better RCA cables(although I really doubt that this is the problem)
Any other suggestions before I lose my mind?
99 Mercury Cougar
akwash79, it sounds like you covered all the bases. Try moving the mini plug from your RCA cables where it connects to the pc (grabbing the plug while inserted to computer and moving it clockwise/counterclockwise or even pulling/pushing it in/out while playing music- listen carefully to see if it's this contact that's creating the buzzing/whine). I had a similar experience with my mobo and tried everything even spent loads of money to fix it when all the while it was the audio connector from VIA that was inferior from the factory, Anyway I fixed it. Please keep us informed..curios to see if this helps.
JAC is offline   Reply With Quote
Old 05-11-2007, 11:18 AM   #23
akwash79's Avatar
My Photos: (1)
I went to ratshack and got the GLI cables they had and connected them in my car. I started my car expecting them not to work......heard absolutely NOTHING!
Then frodo began to load and I was then expecting a severe loss in audio quality but it didn't seem to affect it much if at all. Needless to say I am now very happy with this outcome.
Thanks for all your help and suggestions. Right now I have a Jensen 35w x 4 RMS amp. Do you know what type of amp I would need to eliminate this?
Old 05-11-2007, 11:21 AM   #24
_
My Photos: (90)
so the problem was crappy cables.
That amp isn't helping either.
Jensen is the bottom of the barrel when it comes to car audio.
In case you haven't noticed. You get what you pay for in this world.
Jan Bennett
Old 05-11-2007, 11:26 AM   #25
greatwhite's Avatar
My Photos: (1)
Well, she said!
Cheers
Old 05-11-2007, 11:39 AM   #26
akwash79's Avatar
My Photos: (1)
The strange thing is that the RCA cables on the GLI themselves appear to be a lower quality build than the previous RCAs I was using(the cables on the GLI are much thinner than my others).
Old 05-11-2007, 01:42 PM   #27
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
You should rip open the old cables and check to see what they look like, or just use them in your home. The cheaper cables usually have an open braid which allows higher frequencies through. The better stuff is solid braid, and better has foil wrap over that.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 05-11-2007, 03:37 PM   #28
greatwhite's Avatar
My Photos: (1)
Glad you solved it!
Cheers
BJ
Sponsored Links
vB code is On
Trackbacks are Off
How2 control CarPC from key fob.... NotchbackVW Power Supplies 1 09-21-2007 05:27 PM
OEM Navigation Connectors Mr Castulucci General Hardware Discussion 14 07-22-2007 04:31 PM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 04:04 PM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 05:37 PM
Car PC Audio Design sza Car Audio 4 10-27-2004 09:08 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
