The MP3car.com Store
Thread Tools Display Modes
Old 05-15-2007, 08:23 AM   #1
Tim Lake's CarPC Specs
Tim Lake's Avatar
Vehicle: 1999 Nissan Primera
My Photos: (0)
Should i run a long usb cable for audio?
I am getting interference over my audio cable from the USB DAC to the amp. Would it be better (in terms of interference) to run a longer usb cable from the PC to the DAC and a short cable from the DAC to the amp.
If it was a choice of long usb and short audio cable or short usb and long audio (and all other variables remained fixed) which is better?
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Bluetooth, 802.11g, GPS
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
NLited XP with Road Runner and MapMonkey
Tim Lake is offline   Reply With Quote
Sponsored Links
Old 05-15-2007, 08:36 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
I'd think the longer USB cable would be less susceptible to EMI than the long audio signal cables.
I'm not the expert, though.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-15-2007, 08:40 AM   #3
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
I would have to agree with DP, however you need to indentify what this "interference" is. Please be more descriptive. Is it a constant noise, does it change with speed, is it only there when the car is on, etc etc...
durwood is offline   Reply With Quote
Old 05-15-2007, 08:52 AM   #4
Tim Lake's Avatar
My Photos: (0)
It is a kind of quiet hissing which sounds like its picking up the sound from inside the PC. This is logical since the audio cable runs right next to the case. My install makes it near impossible to run it anywhere else which is why I was thinking I could move the DAC to the boot (trunk) and then run a very short signal cable to the crossover. This would mean the USB cable would run where the audio currently does, hopefully without picking up the same interference.
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Old 05-15-2007, 09:31 AM   #5
Car Audio Moderator
durwood's Avatar
My Photos: (0)
Then your problem is something else. YOu have the silverstone DAC I see. Read through the last few pages of this thread. YOu will find your answers there probably.
Old 05-15-2007, 09:42 AM   #6
Tim Lake's Avatar
My Photos: (0)
Cool thanks, looks like running it thorugh a powered hub might be my solution then
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Old 05-15-2007, 09:46 AM   #7
Car Audio Moderator
durwood's Avatar
My Photos: (0)
Maybe, I should have pointed out the mod done to the card was a bigger improvement, but the hub idea might be cheaper and easier to try.
Old 05-15-2007, 09:52 AM   #8
Tim Lake's Avatar
My Photos: (0)
Yeah, I already have a hub I plan to wire onto the 5v line from my Carnetix p1290 so I will try it on that and see how we go. The thing is it used only get this interference intermittently until I reshuffled wires (including running the audio cable near to the pc housing)
VIA M10000
512Mb RAM
30Gb 2.5" HDD
Silverstone USB DAC
Consult (ODB)
CarTFT K500
Carnetix P1290
Sponsored Links
vB code is On
Trackbacks are Off
Newbie build-up: Ampie CarPC EEEEeeee36 Newbie 56 03-28-2008 09:03 PM
USB DVD/RW issues kamikaze2112 General Hardware Discussion 1 08-04-2006 10:43 AM
Wanted broken BU-303 or usb cable Mazda6PC Classified Archive 1 10-31-2005 05:48 PM
My USB/Wifi troubles. JPuma General Hardware Discussion 0 09-23-2005 11:44 AM
a few ?'s regarding how long of a USB cable i can use and running stuff on it ummagawd General Hardware Discussion 15 02-15-2005 01:43 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
