Old 05-19-2007, 03:40 PM   #1
Nerd2's Avatar
Woohooo, no annoying noise!
Hi all,
I don't know if anyone can remember, but I was having some problems with an annoying crackling noisy when I tried to go HU-less.
http://www.mp3car.com/vbulletin/car-...e-new-amp.html
Well, I'm back at it a month later, with a few upgrades/modifications.
Different 4-channel XS 600W amp, now located 2ft from PC
PC & Amp grounded very close to each other, and to a sanded bit of bodywork.
Power cables now run down side of car - data still down middle.
No USB soundcard, now a Creative Audigy 2 ZS PCI.
So all my cable runs are now pretty short, however I do have a long cables from my amp in trunk, to where the old HU was, soldered onto the existing speaker cables, and around the sides to my speakers.
Anyway, today I plugged it all in, and ta-da! Simple, crackle-free, no-HU sound. Would be interesting to know which of the modifications I did fixed the problem, but I suspect it was either the new soundcard, or the changed amp.
Yaay.
but i'm proud of this! kxproject crossovers are fun too!
Nerd2 is offline   Reply With Quote
Old 05-19-2007, 06:55 PM   #2
madkad's Avatar
well done mate, I know the feeling of them noises
I had them and it was pc noice coming through the amps but yer once sorted its mint
Car Computer 98%[|||||||||-]
Install Plan 100%[||||||||||]
Styling 20%[||--------]
Install 0%[----------]
My Car Computer Before The Crash | Car Computer Forum |Dust overheating pc, AMAZING |
madkad is offline   Reply With Quote
Old 05-25-2007, 01:13 AM   #3
maniaxzero's Avatar
damn i have the same crackling noises with my HU-less onboard sound setup. I dont know where to start diagnosing. I really dont wanna buy a new amp and a new soundcard
maniaxzero is offline   Reply With Quote
Old 05-25-2007, 03:45 AM   #4
Nerd2's Avatar
It's probably not ur sound card, on the basis that my soundcard is 'onboard' (i.e., on the motherboard). Try and make sure your grounds are firmly grounded, your power cables are away from your speaker cables
Old 05-25-2007, 05:31 AM   #5
madkad's Avatar
if your amp is conected right to your pc then you will find that the amp is getting the sound from the pc
there is a inline jack thing that can put that noise to the background so you cant here it, but i dont know the name of them
Old 05-25-2007, 06:03 AM   #6
rijndael's Avatar
i believe what you are looking for is called a "Ground Loop Isolator" (GLI). you can buy them at Circuit City for 15 bucks. all you do is take the 1/8 jack RCA splitter that you hooked up to your sound card into your amp...instead of placing it to your amp, the RCA ends go into the connection on the GLI...then from the GLI into your amp...voila...no more "Alternator whine" or static...
one thing you have to realize is that not all cars are the same...and the GLI will get rid of most of the noise...but some cars you just cant get rid of it at all...but it will be drastically reduced
rijndael is offline   Reply With Quote
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 02:36 AM
Bloomin' alternator whine Vodkapete Car Audio 4 05-03-2007 05:25 PM
Got rid of BUZZ noise!! bleunetizen General Hardware Discussion 3 10-30-2005 07:20 PM
Troubleshooting: NOISE RedGTiVR6 Car Audio FAQ 0 03-26-2005 10:31 AM
Annoying Static Noise and whinning when car running M11VNY Car Audio 2 03-21-2005 06:46 AM
