How does the RCA modified Bloat compare to the GIGAPort AG USB Sound Card (
http://www.esi-audio.com/products/gigaportag/) for connectivity?
Clearly, the DAC gives superior sound quality but it only has a right and left channel, correct?
If you had a multi speaker setup, would you attach multiple Bloats to feed all your speakers? For example, in a 5.1 scenario, would you get 3 Bloats... 1 for the front left and right, 1 for the rear left and right and 1 for the centre and sub?
Can you then configure the sound drivers to output the different sounds required for 5.1 surround through the 3 different bloats to get 5.1... i.e. low frequency for the sub and mono for the centre and then separate the front from the surround etc?
Perhaps I'm talking complete nonsense and complicating matters?? It's just I have a multi-speaker setup in my car which is being fed by a multi-channel amp. If I understand things right, I would need to feed each channel their own sound and therefore, require multiple Bloats to achieve this?
