The MP3car.com Store
Thread Tools Display Modes
Old 06-03-2007, 09:49 PM   #1
My Photos: (0)
Need Advice
hey every one. ive installed a 600watt pioneer amp in my van and its getting hot way to fast. what do i need to do to find out what the problem is? circut city said i had too many speakers running to the same channel. its a 4 channel amp but ive only got 1 set of rcas running from my head unit. and 2 6 by 9s are wired to the radio and 2 to the amp so im not understanding where the heats coming from. and i have 2 subwoofers i want to hook to the amp but im afraid ill burn the amp if i keep running it.
abecedarian is offline   Reply With Quote
Sponsored Links
Old 06-04-2007, 10:09 PM   #2
Vehicle: 2001 Ford Explorer XLT
My Photos: (0)
I a 600w pioneer 4 channel amp also and im running all 4 of my 5x7 speakers to it and they run incredibly. I dont think you really need to run 2 through the head unit and 2 through the amp. It might also depend on what gauge wire your running to your amp. I have 4 gauge running up to a distribution block which splits into 4 gauge for my sub amp and 8 gauge for the amp( the 8 gauge is only running baout 3 feet though. Also, what gauge wire do you have running from the amp to your speakers? you really need at least 16 gauge (standard speaker wire) Finally check the impedence on your speakers and what your amp is rated at. Dont forget that depending on how they are wired (parallel vs. series) changes the impedence. Here is a sight that might help you decide what wire you need.
http://www.the12volt.com/wiring/recwirsz.asp
Unless your on a budget, runng your subs on a seperate amp will really make a big difference. Hope this helps a little bit since we have the same pioneer amp.
ford01explorer is offline   Reply With Quote
Old 06-05-2007, 09:09 AM   #3
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
Moved thread and edited the title to be more appropriate.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Small Car, budget complete setup advice Scouse Monkey Car Audio 16 07-18-2007 08:10 AM
Advice for system II 1fasbu Engine Management, OBD-II, Engine Diagnostics, etc. 1 01-11-2007 11:07 PM
need some advice building a car PC! dsmstunna Newbie 3 01-23-2006 01:03 PM
Before I lay cables, here is my USB device layout. Advice? Bailey General Hardware Discussion 11 03-13-2005 09:03 AM
lilliput buttons advice Moneyfink Fabrication 1 03-07-2005 07:51 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
