The MP3car.com Store
Thread Tools Display Modes
Old 06-08-2007, 10:01 PM   #1
Grimoire's CarPC Specs
Grimoire's Avatar
Vehicle: 2003 Pontiac Vibe GT (Dent is fixed! XD
My Photos: (0)
NO Sound...no nothing!
Alright, I JUST finished my sub box. I wire it up, and hit the stereo. Sounds great! However, needs some tweaking, so Im playin with my Soundstream Van Gogh VGA 800.5 Amp. Between that and the Pioneer Premier DEH-P680MP HU, I was getting some good sounds. A bit of rattle, but nothing to really complain about. I wasnt going through the computer, it was all HU, I had both doors open, passenger and Driver... So once I got things sound decent, I left the music going and started to close the passenger door. The sound cut off, then came back on. I stopped closing the door and though 'short'. So, I tapped on the wire heading to the passenger speaker, it was very very taunt, so I pulled it a bit to get some slack, I heard scraping, as the wire scraped over bare metal, So my sleaves were cut. Then them music stopped all together.
I pulled the speaker off, and put a megometer on the line, 0.0v. I put it the positive and then ground it to the car, 1.3v. NOW, go back to the amp, and the Sub lines are getting -1.8v. Even though I put the positive meg post on the positive Amp post, and neg to neg. I flipped the cables and still the same.
the other speakers are getting less than 1 volt, except, 2 of them...one is getting 19.3v and the other is getting 23.0v! These are going directly to the speakers from the amp. Power from the battery to the amp is 12.55v, which is what its always been and the remote is 11.3. I did have a ground loop isolator on there, but took it off, no change. So, I have no sound from the HU or computer.
Anyone have any thoughts? Im baffled. PLEASE help...if you need any more info, let me know.
Grimoire is offline   Reply With Quote
Sponsored Links
Old 06-08-2007, 10:44 PM   #2
lbridges's CarPC Specs
Vehicle: 2002 Toyota/MR-2
My Photos: (8)
A voltmeter is not a great help with handling these sorts of problems.
Don't test anything more with suspect wiring. If you have somehow scraped off the insulating material, or shorted across wires you could or likely will damage the amp output section.
Pick up some cheap wire, and just run it on top of the carpet or whatever directly from the amp to the speakers. See what works and what doesn't. That will guide you to what needs to be replaced.
lbridges is offline   Reply With Quote
Old 06-09-2007, 12:07 AM   #3
Grimoire's Avatar
My Photos: (0)
When DOESNT a multimeter help!?!? :P
Alright, not a problem, I have some more wire laying around here. Ill re run the lines tommorow and get back to this. If anyone else has any more ideas, or had a similar problem, Im all ears.
Sponsored Links
vB code is On
Trackbacks are Off
iTunes vs Amp : sound quality natedawgg MacCar 5 05-10-2007 06:32 PM
Creative Labs Sound Blaster® Live!™ 24-Bit External USB 1.1 SpyderHatch Classified Archive 12 11-28-2005 04:12 PM
sound quality between carputer going through the HU and carputer going to amp lookinco Car Audio 9 08-07-2005 11:27 AM
Pro Logic vs digital surround sound lookinco Car Audio 2 08-28-2004 09:29 AM
got sound? masch Newbie 20 11-17-2003 09:01 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
