The MP3car.com Store
Thread Tools Display Modes
Old 06-14-2007, 07:16 PM   #1
zerocover's Avatar
Vehicle: 2007 volvo s40
My Photos: (0)
optical to RCA
So I bought a new volvo s40 with the normal audio system thinking that Ill just upgrade it myself with all my audio stuff from my old car.
Turns out the volvo runs fiber optic cables to mini amps in each door!
Why would anyone do this?!!
Is there an optical (digital) to RCA (analog) adapter I can use?
zerocover is offline   Reply With Quote
Sponsored Links
Old 06-14-2007, 07:48 PM   #2
Takes it in the Rear
kevinlekiller's CarPC Specs
kevinlekiller's Avatar
My Photos: (0)
There is no adapter, you would need some sort of hardware that can convert the digital signal into an analog signal.
Why do you want to use the amps in the door? You can just pass some new wire to the speakers from your old car.
kevinlekiller is offline   Reply With Quote
Old 06-14-2007, 07:54 PM   #3
zerocover's Avatar
My Photos: (0)
Wait what... No!
I have fiber optic out put from head unit. I want Rca output. I want to use my new head unit with fiber output to run my subs and amp which use Rca input.
For sure id need some hardware but which?
Old 06-14-2007, 07:58 PM   #4
stiv's CarPC Specs
Vehicle: ford exploder
My Photos: (0)
i know of spdif toslink to rca converters
man i bet that factory digital sounds pretty good, are you trying to integrate a carputer?
stiv is offline   Reply With Quote
Old 06-14-2007, 09:29 PM   #5
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
I'm not sure if it's optic like you're thinking of.
It might be the MOST fiber optic communication system in many new cars today.
If it's the MOST system, a simple RCA to tos-link converter won't do a thing for you.
You need to double check that the fiber optic out that you have is in fact JUST a fiber optic signal for audio and not a bus for other communications.
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 06-15-2007, 09:40 AM   #6
zerocover's Avatar
My Photos: (0)
Quote:
The data network in the S40 consists of a high and a low speed CAN bus, a fiber-optic bus for Infotainment (MOST, Multimedia Oriented Systems Transport) and a number of local network on subordinate buses (LIN, Local Interconnect Network).
A data bus is the channel for transferring data (communication) between different units in a network.
****, most. Is there any hope?
Old 06-15-2007, 10:35 AM   #7
_
My Photos: (73)
There aren't any adapters avaliable for the MOST systems yet unfortunately.
The market has been hoping for it for a while now.
Jan Bennett
Sponsored Links
vB code is On
Trackbacks are Off
Digital Optical out on Motherboard VS Soundcard fire Car Audio 2 01-28-2007 08:54 PM
Coaxial Digital VS Optical Digital MeeM Car Audio 5 06-01-2006 12:55 AM
Optical Input To Rca Output Converters! Crazystick Car Audio 18 01-06-2006 03:51 AM
List of EQs with optical input Jackboot Car Audio 9 11-23-2005 02:27 PM
minimum distance between power & rca wires michaelrj9 Car Audio 11 08-30-2005 01:02 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
