Old 06-18-2007, 01:47 PM   #1
Aftermarket head unit NO SOUND
I ordered a touch screen with VGA/radio/built-in AMP weeks ago. When I installed on my BMW E36, I found that there was no sound from the speakers but head unit powered on. I was told that BMW OEM AMP will not work with after market head unit. I checked the AMP, there are two groups of wire attached to AMP. I believe one group comes from OEM head unit and the other one goes to speakers. Can I bypass the AMP and hook up two groups of wire directly? Or there is a solution to keep using the OEM AMP?
Any suggestions will be greatly appreciated.
Apologize for my English if I made any mistake or confusion.
dyyzff is offline   Reply With Quote
Old 06-18-2007, 03:47 PM   #2
Yes it is possible to bypass the factory amp, you may need to run new lines either directly to the speakers or to where all of the speaker wires are centralized at the amp and use filtering caps. But if you are not planing on integrating a computer in that setup, you may want to check out a different web-forum dedicated to car audio, or a bmw specific website.
" In the beginners mind there are many possibilities, but in the experts mind there are few. "- Shunryu Suzuki
PROGRESS:
[DONE&DONE] (Considering a redesign)
pancit175 is offline   Reply With Quote
Old 06-19-2007, 03:20 PM   #3
Hi pancit175, thanks for the answer. But what is filtering caps? I do want to integrate a computer since the head unit I got is a touch screen monitor.
Thanks again.
Old 06-20-2007, 08:45 PM   #4
When I said filltering Capicators, I could have said "pasive crossovers". For instance, the radio puts out a full-range sound, whereas the tweeters can only handle higher frequencies. Allowing a full-range sound to go to the tweeters can and will damage them because of the bass frequencies. And with a pasive crossover to block the mid to low bass, you protect your tiny tweeters.
PROGRESS:
Old 06-29-2007, 12:29 PM   #5
Pancit175, thank you so much. I learned something.
Old 06-29-2007, 08:49 PM   #6
Word
PROGRESS:
Seat Ibiza Mk4 Alana Head Unit - need sound in! onlineamiga General Hardware Discussion 5 02-11-2007 05:02 AM
USB head unit? dgr Car Audio 4 11-25-2006 09:55 AM
Head Unit coupled with an Amp garto Car Audio 3 10-09-2006 08:28 AM
choosing a head unit demonr Car Audio 3 09-17-2006 12:56 AM
New Head Unit Recommandation shamel Car Audio 6 09-14-2006 12:19 PM
