nope, no problem, but... is that single sub of yours a single voice coil, or a dual voice coil.
Most of the more expensive sub's are dual voice coil, if yours is, and it is 4 ohms. Then you can wire it in series which will give you a restistance of 8ohms or in parallel giving you 2ohms.
If this is the case you have to look up how much your amp can handle at 2 ohms, but it is usually double, so prob. 1000watts ish at 2ohms so you're prob. fine
2006 Mazda 3 Behringer DCX-2496 JL300/4 Focal 6W4311B Focal TN52 JL500/1 JL10w6v2
