The MP3car.com Store
Thread Tools Display Modes
Old 06-27-2007, 10:06 PM   #16
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
Ben- that method is flawed. For one, if you use 0db test tones you will never get the full potential out of your amp. It will sound very quiet when you try to listen to dynamic music. Secondly, a multimeter will never tell you if your amp is clipping, you would need an o'scope for that instead. Never rely on your amps power rating and your speaker is not a resistor. Resistance does not equal impedance and a speakers impedance changes with frequency.
durwood is offline   Reply With Quote
Sponsored Links
Old 06-28-2007, 09:05 AM   #17
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 07-08-2007, 05:10 AM   #18
Firebird's Avatar
Vehicle: 1995 Pontiac Firebird
My Photos: (0)
Hi!
Can i set the volume control, that the Main and Wave control moves together when i raise or lower the volume with the buttons?
Greetings
US Cars @ www.rollingthunder.at.tf
Firebird is offline   Reply With Quote
Old 07-09-2007, 02:27 AM   #19
Firebird's Avatar
My Photos: (0)
At MediaEngine, you can set this option, and then the volume controll is better.
Old 07-09-2007, 03:10 AM   #20
Firebird's Avatar
My Photos: (0)
Oh, I mean at the centrafuse frontend.
Sponsored Links
Old 07-09-2007, 04:57 AM   #21
emperorjj1's Avatar
Vehicle: 06 Cobalt SS Supercharged
My Photos: (0)
Quote: Originally Posted by RedGTiVR6 View Post
Matching the gains appropriately actually does have a bit of a SQ benefit.
Part of the reason for setting gains is that every amplifier has an ideal voltage it wants to see. This voltage is some times hard to find from the manufacturer.
If the HU is not clipping (which is what we're trying to make sure of) you will have nothing but a clean signal, no matter how much you turn the gains up. You will notice more height, depth, and dimension as far as imagining and staging, not necessarily tonality, etc.
Stage two of this is as follows:
Mute the output of each pair of speakers all at once. Unmute and listen to the least efficient set of speakers (in our car it's the 5s) with a DB meter and get a reference setting on pink noise. Then mute those speakers and un-mute another set of speakers in the car. Adjust the gain on the amp then to make these speakers output at the same level as the most inefficient set of speakers. Do this for all speakers.
You will achieve maximum efficiency this way. With maximum efficiency, you will have more head room, which means more stage, etc. If the components in the amplifiers aren't working together, the components are all fighting each other. It's a symbiotic relationship.
wait a minute if the HU doesnt clip then you could set the gains at whatever? is it possible to check clipping on rca's? (supposivly ive herd the rockford fosgate units dont distort so i want to test the clipping thing)
emperorjj1 is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Change behaviour Volume control DbXL Centrafuse 0 07-09-2006 11:09 AM
Roadie Volume Control tjp12100 FrodoPlayer 0 06-21-2006 03:30 PM
External volume control, knob, powermate, or something else? stimps Input Devices 3 12-10-2005 01:12 AM
Volume control in Xenarc 700TSV BMW-7 LCD/Display 3 04-06-2005 11:08 PM
hardware volume control ODYSSEY General Hardware Discussion 18 04-20-2001 10:43 AM
Sponsored Links
Ad Management by RedTyger
