Quote: Originally Posted by
Arrow
If the amp wont come on with the volume turned very low, then it's probably a connection issue. You probably have a bad connection somewhere. If your inline fuse is not blown on the 4awg wire, but you aren't getting power, then either your connection to the battery is not good, or your ground is not good. Remove your connection from the battery, then scrape any corrosion or oxidation off the connector and battery post. Also, be sure your ground is good. Remove your connection to the chassis and be sure the area is scraped clean of paint and corrosion. Also, you should use the same grounding point on the chassis for both amps.
If this doesn't fix the problem, then there is a possibility that you alternator/battery doesn't supply enough current to power both amps. A capacitor will only help if the amp is cutting out only on the quick hard bass hits.
Thanks for your time , but i have now sorted it you know the 60a fuse the big one near the battery well people was saying check ya fuse but i had changed that twice, any way i got the volt meter out i check the back of the 4 gage wire nuffing no reading wen to the front checked were battery fine checked the fuse fine then i looked in side the gold port you know were u screw down the wire the big round gold thing and in side was burnt and really smelled burnt any way changed the hole thing and works perfect
thanks
