Old 07-09-2007, 04:55 PM   #1
dodguy is on a distinguished road
Trunk Rattle
Does anyone know how to make their trunk stop rattling after putting subs in the back? I think I've narrowed it down to the lid vibrating against the car itself and the key port in the back. I drive an 03 Jetta GLS if it matters. Thanks. Any help would be appreciated.
PS.
I've already put expanding foam in the trunk lid, along with carpet padding everywhere i can think of, and that didn't help at all. I've also line the inside lip of the trunk lid with a soft rubber weather stripping (not visible unless you open the trunk) which didn't help.
HELP ME PLEASE!!!!!
dodguy is offline   Reply With Quote
Old 07-09-2007, 08:28 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Put some earplugs in, turn up the bass and find out what's rattling and seal it off somehow. It's really all you can do.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 07-09-2007, 11:50 PM   #3
JimmyFitz's Avatar
JimmyFitz is on a distinguished road
Check your license plate, too.
2005 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 07-10-2007, 12:06 AM   #4
Cutrara is an unknown quantity at this point
I've heard heard of some guy taking out all of the screws the hold the trunk plastics in and putting an o-ring on them and tightening them up.
Cutrara is offline   Reply With Quote
Old 07-10-2007, 12:38 AM   #5
Wants to make it harder
monkeyracer's Avatar
monkeyracer is an unknown quantity at this point
ok, it's most likely your plate, otherwise it could be something on the lid, the lid itself, both, tons of different things. you are starting right by trying to isolate it with the foam and the rubber strips. Your best bet is to do as DP suggested, get really good earplugs, crank it and listen to where things rattle. press on different parts of the trunk lid, etc.
You may never fully be able to stop it though. I've said in a previous thread about trunk rattle that 'why do you care if other people hear your trunk rattle?'
monkeyracer is offline   Reply With Quote
Old 07-10-2007, 02:39 AM   #6
wont the earplugs keep me from hearing the rattle?
Old 07-10-2007, 07:47 AM   #7
A rattle is metal vibrating against metal. You do't need to hear it so much as feel it. The pitch f the trunk rattle will be a far different frequency thn the subwoofer, so the rattle will be painfully obvious.
The earplugs are so that you don't go deaf crawling in your trunk with the subwoofer thumping away.
If you choose to dig into your trunk right next to a cranked up subwoofer without any hearing protection, go right ahead. don't say you weren't warned.
If uyou choose to eschew the earplugs, take photos of your ears after teh eardrums are blown out. Gory stuff like that is eerily cool.
Old 07-10-2007, 08:54 AM   #8
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
as others have said, you have to identify the rattle first before you can try to get rid of it. Problem is that you can chase it away but it always ends up somewhere else. You are on the right track with different materials. It's probably going to to take a combo of deadening material, closed cell foam, and isolation to get things to stop rattling.
System always under construction
durwood is offline   Reply With Quote
Heat preventing system boot... archaic0 General Hardware Discussion 6 06-29-2007 10:46 AM
problem with trunk rattle Jesse911 Car Audio 6 06-07-2007 02:58 PM
Ideas on hardening trunk lid from exterior prying or lock cylinder pulling jbeletti General Hardware Discussion 4 01-02-2007 09:03 AM
Remote Trunk popper install HELP! pcmofo Fabrication 5 11-06-2006 05:34 PM
Help Mounting PC In Trunk S40 silv3rman Fabrication 5 08-04-2006 11:19 PM
