The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 07-09-2007, 04:03 PM   #1
ephyouckay's Avatar
My Photos: (0)
JL Cleansweep same as Sound card?
I was wondering, if i have an external sound card such as the audigy 2 NX would getting a JL clean sweep benefit me much or do they do pretty much the same things?
my carputer still has to go through the Aux in and is connected via the Car2pc module (i know, not the best module for SQ)
ephyouckay is offline   Reply With Quote
Sponsored Links
Old 07-09-2007, 08:30 PM   #2
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
the jl clean sweep doesn't do what a soundcard or dac will do. you need a soundcard (or dac) the cleansweep is used when you're keeping your stock head unit and you want to try to clean up the output before it goes to your amps IIRC
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-09-2007, 09:30 PM   #3
My Photos: (0)
so you're going from computer to sound card to factory head unit?
If so, then the cleansweep might help you. It's all dependent upon whether or not the factory head unit does something to the sound coming from the sound card, like adjust the eq's for example. If so, the cleansweep will balance that signal for you. That's the typical application.. However, since you have a computer, you can actually do the balancing yourself using software eq adjustments. You will need a mic and a program like trueRTA to help you balance you EQ levels. Then from there, make sure you only adjust the volume using your carputer.
ironfinger is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Sound only coming from one port of the sound card. Maheriano General Hardware Discussion 45 08-27-2006 09:21 PM
Sound card issues gboy Newbie 2 02-25-2005 09:38 AM
Sound card / noise Tha Hombre General Hardware Discussion 5 05-15-2004 11:01 PM
Any opinions on the Phillips Aurillium external sound card? UMM General Hardware Discussion 1 02-27-2004 03:39 PM
adding another sound card?? moahdib General Hardware Discussion 7 04-25-2002 06:57 AM
Sponsored Links
Ad Management by RedTyger
