Old 07-10-2007, 01:01 PM   #1
HarleyTeKk is an unknown quantity at this point
Connecting all devices together to get audio.
So I have an after market alpine deck. Ive got a 7" touchscreen with built in tv Tuner. and I have a pc for in the car. Im running 2 12 subs going to a 2 channel 1000watt amp and my door speakers/ tweeters run to a 600 watt 4 channel amp. How do I connect all the devices to get audio from all?
HarleyTeKk is offline   Reply With Quote
Old 07-10-2007, 02:57 PM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
aux. input on the alpine.
Will probably take an adapter from alpine to get aux. in though.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-12-2007, 03:52 AM   #3
Naesstrom is on a distinguished road
I'm not sure what u mean but the way most people do it is by connecting the soundcard in the PC with the different amps, most soundcards have options for running Stereo/2.1/4.1/6.1/7.1 etc. the .1 is the subs just to be real clear!
your setup seems to be a 2.1 since u dont want the tweeters and front door speakers to be on different sound channels, just get 2 3.5mm->RCA cables and a pair of RCA splitters.
Then check the manual for the soundcard what to connect where. the splitters is to get your front speakers and tweeters to the same channel.
Swedish site for CarPC's
http://www.bilpc.info
Naesstrom is offline   Reply With Quote
Old 07-16-2007, 01:55 PM   #4
Naesstrom,
well I was looking to keep the Alpine unit for stereo. but if I go the route you are describing how do I connect the audio out from the TV tuner to finish up the setup? better yet is there a way to keep the alpine deck in the picture?
thankx for the input by the way guys.
PCI Audio vs. USB Audio vs. Onboard Audio waltwalt Car Audio 12 07-26-2007 09:36 AM
OEM Navigation Connectors Mr Castulucci General Hardware Discussion 14 07-22-2007 05:31 PM
connecting carpc to audio system ArcticGenes Car Audio 10 07-31-2005 08:15 PM
Virtual Audio Cable tj!2k4 Software & Software Development 0 07-22-2005 03:58 PM
designing audio system 1DeepG Newbie 3 06-29-2005 09:48 PM
