Old 07-12-2007, 12:40 AM   #1
brendan is an unknown quantity at this point
want proper front speaker install
ok, so i bought a set of 6.5" alpine component Type R speakers off ebay. more specifically the SPR 17L6.
so anyway, i didn't expect them to be soo big and rather impressive looking as they are not mention deep and heavy. they mount 3" deep and that probably is to deep to mound in my door in the factory location. (1992 ford Taurus SHO)
So my question is should i even use these things in free air (they look like mini subwoofers) or should i build little fiberglass kick panel boxes which i've seen people build and could never figure out why before.
brendan is offline   Reply With Quote
Old 07-12-2007, 08:49 AM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Do you have room to build an MDF baffle board to mount them to in the door?
Second, kick panels are nice for many reasons, mainly for minimizing path length difference (PLD). It will help with your staging, however there are downsides to kick panels too. Space, airspace, etc. Your midbass response will suffer in a kick panel unless you can give it enough airspace, or vent the kick panel to the outside world. Car speakers are specifically designed to work in a door, so when you go the kick panel route, you kind of have to mimic the airspace available in a door and build a strong non-flexing enclosure. I strongly recommend you do some research on that before you decide anything.
I can give you a nice link about the science behind kick panels, but it's very technical. If you are really serious about kick panels or a "proper front stage" I will provide the link.
System always under construction
durwood is offline   Reply With Quote
Old 07-12-2007, 09:34 AM   #3
mezz64's Avatar
mezz64 is on a distinguished road
I'm not sure about the OP but I'd love to take a look at the kick panel link. Post her up!
98' Honda CR-V
http://www.superbluecrv.com
*OBDMPG, the RR OBD Plugin*
mezz64 is offline   Reply With Quote
Old 07-12-2007, 10:18 AM   #4
Car Audio Moderator
durwood's Avatar
I haven't dug through it but plenty of good info in this thread regarding setting up a good front stage. Plenty of physics involved. Grab some and get ready to absorb. The site onwer is on vac right now and the following linked forum is acting up so be patient with it.
http://www.diymobileaudio.com/forum/...ead.php?t=5664
I'm not sure if they ever talk about venting the kicks to the outside of the car using an aperiodic membrane or not. I'm not a kick panel person so I don't make a good teacher for explaining the ins and outs of doing it, but can answer plenty of question regarding setting up a good stage. It's all in that thread though, better hope you have the proper processing and speaker setup/placement to initiate some of the theories involved. It does work.
2002 Montero Limited Install... Squid Show off your project 35 10-06-2009 04:41 PM
[CoupeE46] BMW E46 2001 330ci CarPC ... CoupeE46 Worklogs 54 10-02-2008 08:16 AM
XC90 Install - am I the first?? klokman Worklogs 7 02-13-2007 01:12 AM
Lilliput 619 USB/Driver Problems? Let's research this... (unknown device) akula169 LCD/Display 10 11-20-2006 06:14 PM
Jagputer Install and story log JagPuter Show off your project 19 08-02-2006 09:48 PM
